Are these gears the same
Discussion in '1st Gen Tundras (2000-2006)' started by MeanGreenmachine, Feb 28, 2025.
  1. Feb 28, 2025 at 1:48 PM
    MeanGreenmachine
    MeanGreenmachine [OP] New Member
    2001 green tundra limited ac
    On the 1st gen rear differentials on these tundras the open diffs that are 43/11 and the lsd diffs that are 44/12 close enough that it will function the same and not mess anything up?
    also when I put a new diff in is there a seal I need to buy? Or what seals the diff off
  2. Feb 28, 2025 at 2:06 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    You want use same gear ratio front and rear. Differential have a pinion seal behind the yoke and axle seals inboard of the axle flanges.
  3. Feb 28, 2025 at 3:37 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    ...and a paper gasket between the third member and the housing, although many just use RTV
    FrenchToasty likes this.
  4. Feb 28, 2025 at 5:05 PM
    MeanGreenmachine
    My truck is
    *FGR=43:11=3.909 open diff
    The diff I’m looking at is
    *FGR 44:12 =3.90 lsd diff
    Does anyone know the part number for that paper gasket? what’s rtv?
  5. Feb 28, 2025 at 5:18 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    rtv = room-temperature-vulcanizing silicone
    I use the high temp red/orange on almost everything
  6. Mar 1, 2025 at 2:24 AM
    w666
    Maryland
    I recently changed out mine. Faced with the difference between 3.909 and 3.90 I chose to stay with the 3.909 original ratio. Most of the "advice" I found on the Internet said that the difference was insignificant, but I didn't want to take any risk at all.
    Beware that the companion flange might be different on your "new" carrier depending on what year/vehicle it was salvaged from.
  7. Mar 1, 2025 at 5:48 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    I did this exact swap, below are the ratios stamped into each ring gear.
    Open
    LSD
    Toyota only stamps them to the hundredths decimal place. Send it.
