Ardnut's Tow/Hunt Rig
Discussion in '2nd Gen Builds (2007-2013)' started by Ardnut, Aug 4, 2016.
  1. Aug 4, 2016 at 2:17 PM
    Ardnut
    Ardnut [OP] New Member
    TX
    Figured I would share what has been done so far.
    New Components:
    Fatbob CO's at 3"
    ZONE uca's
    Differential Drop
    Firestone Ride Rite Bags
    1" Block
    ProComp SS Rear Shocks
    7029AA30-84CE-4C96-A8D1-22C136406F44_zps_0877fa78081aec5a448e9bf491a45c8623a23712.jpg
    Fancy looking, decent ride. Obviously no king but it feels firm and takes bumps well.
    4A4A21BF-2596-43BE-B745-7064A48D4E0B_zps_85db72c20a5f18142c2b78d3cc8157ed20400080.jpg
    Originally planned on AAL's, but since I have an empty bed most of the time I decided on a 1" block for a level stance. Might adjust the coils down some for a more factory rake once I complete the BMC and try to stuff the 37's in there.
    [​IMG] [​IMG] DBACA1B2-028F-4A0B-8D0D-2E43A8CBDD20_zps_6c2c0afe1e0c1a84b58c18c35c66e5db41b068d6.jpg
    DCA97EE9-F1CE-4AB6-8AB1-629EF6D4029F_zps_5016512346169f889e29cdae38d62a19cb2f0095.jpg
    I just used an existing hole in the frame that was the perfect size for the stem. Reach right over the tire and fill the bag to desired PSI. If I end up towing more than once a month I might change that setup, but its an easy no messing around setup.
    BBAD4FEE-A3DF-4C7B-BA4B-37ED5D7836B4_zps_97fbf7bfb7495f3a643093ba88cc866b0a8fc6c8.jpg
    That's all for now.
    Once these tires wear down a little more I'll be looking at 37's. Maybe new bumpers. Wouldn't mind a full replacement on the front with the 700lb coil on the Fatbob.
  2. Jan 21, 2017 at 6:01 AM
    Ardnut
    TX
    Small update, found some RW's on Craigslist and traded my stock wheels plus $400 for them and 35x12.50's nittos
    Before:
    After:
  3. Jan 22, 2017 at 12:19 PM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Like the work that you're putting in man! What are your plane for recovery and onboard air?
  4. Jan 22, 2017 at 1:30 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Looks good dude!
  5. Jan 22, 2017 at 2:03 PM
    LML 3500HD
    Looks great.
    I would seriously consider air bag saddles if you plan on off-roading much.
    Ardnut[OP] likes this.
  6. Jan 22, 2017 at 2:17 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Way better looking with more rubber on there. I agree with ColoradoTJ. Air bag cradles are the way to go. Just put some thin sheet rubber between the air bag and cradle so you don't get any clanking noise. Good luck !
  7. Jan 22, 2017 at 2:23 PM
    Ardnut
    TX
    Cradles are sitting in my garage, just waiting for 5 spare minutes to throw them on. Our 2nd child is due any day now
    :annoyed:
  8. Jan 22, 2017 at 2:25 PM
    CM-LENNY
    San Diego, CA
    Congrats in order soon on all the cradles you will be dealing with.
  9. Jan 22, 2017 at 2:27 PM
    Ardnut
    TX
    Eventually want to go after market on bumpers and get a winch up front. Onboard air is in the pipeline but have a basic 12v pump for now that is covering needs
    ColoradoTJ likes this.
  10. Jan 22, 2017 at 2:55 PM
    LML 3500HD
    I would just do a 10lb CO2 tank. Trust me, you will be money ahead, have more uses for it, and it is way faster.
  11. Jan 23, 2017 at 9:26 AM
    Ardnut
    TX
    You would recommend a co2 tank over a wired in compressor with a small tank?
  12. Jan 23, 2017 at 12:56 PM
    LML 3500HD
    Yes I would. I have owned both, and CO2 tanks work best for me.
    Ardnut[QUOTED][OP] likes this.
  13. Feb 13, 2017 at 9:11 AM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    I have a very similar setup to you with Fat Bob's COs and I am considering buying these UCAs..
    What spring rate do you have on your COs? I went with 700lb and I feel it's a bit stiff. Also at 3" they are probably compressed pretty well.. Wondering what your experience is?
  14. Feb 13, 2017 at 10:20 AM
    Ardnut
    TX
    Yes, spring rate is 700 and not as smooth as stock ride. Removing the sway bar helped but I am planning on a ranch hand style replacement up front and potentially a winch so that's why I opted for the hd coil. With stock 275/55r20 tires my front end from ground to top of the well was 39.6" on driver and 40" on passenger
    zcarpenter92 and Backslider like this.
  15. Feb 13, 2017 at 10:26 AM
    Backslider
    Tooele, UT
    I also installed an aftermarket bumper (Go Rhino BR10) and am in the market for a winch... Went with the heavier springs for the same reason. Thanks for responding, makes me feel better about my setup!
