Appreciate all the Knowledge/ Experience
Discussion in 'New Member Introductions' started by Tank4Cy, Dec 4, 2021.
  1. Dec 4, 2021 at 9:34 AM
    Tank4Cy
    Tank4Cy [OP] New Member
    Shawn
    2007 SR5 Tundra TRD
    Added 20 inch wheels.
    New to Tundras.com. Greatful owner of a 2007 TRD Tundra 5.7. Bought it in 2010 and I have a little over 195,00 miles racked up. She's been a great truck, but needs a little "attention," here recently. I appreciate all of the knowledge/experience shared in this community. And I'm reaching out to tap into some of that said knowledge/experience.
    Truck ran normal. Parked her for the night. Wouldn't start the next morning. Battery replaced recently along with cable clamps. Have plenty of juice to start, but just a noice from the ECM area of the dash. Put a code reader on it. 4 separate codes dealing with cam position sensors. Figured maybe a bad starter. Tapped on the starter, actually more difficult than I intended, and got it to turn over. Then she stalled and on a couple more starts, as well. This time only one code, P0335 noting bad cam shaft sensor "A." Fourth start and she runs without stalling, but code P335 still present and no check engine light, either. Do I need to replace only the "A" cam sensor (position 1), or is my starter faulty... or both?
    Thank you,
    Tank4cy
  2. Dec 4, 2021 at 1:21 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  3. Dec 4, 2021 at 7:20 PM
    Tank4Cy
    Shawn
    2007 SR5 Tundra TRD
    Thank you, Bakershack. I will resend it right away.
    Bakershack likes this.
