Anyone use "BOLT" hitch lock?
Discussion in 'Towing & Hauling' started by TucsonTundra1794, Jul 26, 2021.
  1. Jul 26, 2021 at 8:46 AM
    TucsonTundra1794
    TucsonTundra1794 [OP] ASCM #6-11 I'll buy if you're willing to ship
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    jewsNbrews likes this.
  2. Jul 26, 2021 at 8:50 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    No issues with mine. I don't tow though, just have a hitch step secured with one so it doesn't "walk off"
    BravoDeltaRomeo likes this.
  3. Jul 26, 2021 at 8:57 AM
    biebs96
    PA
    I have the hitch pin, two pad locks and a trailer coupler lock. I love all of them and the convenience they offer.
  4. Jul 26, 2021 at 9:06 AM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab, Beta Variant (I call it my Land Yacht)
  5. Jul 26, 2021 at 10:19 AM
    ezdog
    ezdog New Member
    Gateway To The West
    I have them on all of my trucks and have never had a single bad thing to say about any of them.
    Obviously really convenient and I just got back from a 6K mile journey towing for half of it and again nothing to report at all which is exactly what I want from all of my towing gear!
  6. Jul 26, 2021 at 10:21 AM
    Kanobi13
    Kanobi13 New Member
    No issues with mine im sure they did not have it on correctly
    Backslider and jewsNbrews like this.
  7. Jul 26, 2021 at 10:27 AM
    NWPirate
    NWPirate Tesla kool-aid connoisseur
    Zach
    WA
    2017 SR5 TRD CM 2004 TRD Snow Goat
    I've got one, had it for a few years. While I haven't had any problems with it, I'm not 100% confident in it.
    I'd like a more positive connection if that makes sense. When it clicks in, it doesn't feel like a standard padlock.
    Probably going to toss it soon.
  8. Jul 26, 2021 at 10:32 AM
    LittleTRD
    LittleTRD New Member
    James
    Central California
    2015 Tundra Crewmax
    Camburg UCA's, Fox Factory 2.5's Front & Rear, Coachbuilder +3 Shackles, Decked Bed System, Snugtop Rebel Shell, switch pros 9100, and baja designs for all additional lighting.
    I've got the same setup as @ezdog with the B&W Hitch paired with the BOLT Receiver Lock. I've been using it to tow with for about 4 years now with no issues. The only bad thing I will say about it, is the lock mechanism side is pretty large, so it blocks a lot of the safety chain hole making it difficult to get the chains on.
    ezdog and jewsNbrews like this.
  9. Jul 26, 2021 at 10:43 AM
    ezdog
    ezdog New Member
    Gateway To The West
    This is true but all of the other heavy duty locks that I have tried are about the same,they might not seem as bulky but are just always in the way anyway.
    If you look at my B&W you see the Infinite Rule Pin Locks on it,I got the entire set including the Hitch Pin and while it is an amazing machined lock it was just as intrusive on that side as the bolt but a whole lot harder to use too.
    All of the others seem like Junk to me though so it will be one of those two for me unless I find something better?
    LittleTRD[QUOTED] likes this.
  10. Jul 26, 2021 at 10:46 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    This is exactly what I think happened. I have a keyed pin on now and I always pull the pin after locking to make sure it's connected. Maybe 1 out of every 40 times the lock didn't attach and I have to do it again.
  11. Jul 26, 2021 at 10:55 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    My last key operated hitch lock (with cover) seized up after months of non-use.
    Hauling gravel, rock, dirt, using gravel roads etc....and all the fine dust made it's way into the key hole, mixed with rain and it was like concrete in there. I had to grind it off.
    LarryDangerfield likes this.
  12. Jul 26, 2021 at 11:13 AM
    ezdog
    ezdog New Member
    Gateway To The West
    Tougher to steal that way!
    What do you do now?
    I am maniacal about keeping mine sealed if I can.
  13. Jul 26, 2021 at 11:39 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    I found out the night before I was going camping and had to grind the pin off.
    Right now I'm just using a standard dummy hitch pin, no lock. I generally keep a recovery hitch on it (not my trailer hitch), in case anyone bumps me.
    I'll look into the above lock. It just may mean, I have to periodically inspect it and/or lubing the keyhole to make sure it doesn't seize up.
  14. Jul 26, 2021 at 11:43 AM
    DaBoro54
    DaBoro54 Beach Fisher
    Leveling kit, 285/70R18 EXOs
    i have had one for a few years. They seem to have a better lock that does seize. I just spray it about every 6 months and mine has seen beach salt. It’s a good lock
  15. Jul 26, 2021 at 12:35 PM
    ezdog
    ezdog New Member
    Gateway To The West
    Evidently they are the largest supplier to the OEM Lock Chanel of manufacturers too so they are already all the way deep into AutoLock Stuff and have been for a long time.
    It is really a genius idea and seems to be implemented in a fairly robust way to me for the most part too.
    They also sell them as OEM for Commercial DCU Topper Doors so that the whole truck ca use the same key at least for the newest tops,again a great idea!
    TucsonTundra1794[OP] likes this.
  16. Jul 26, 2021 at 9:31 PM
    odymar
    odymar New Member
    Marcus
    South Carolina
    21 SW CM SR5 4WD
    I used the BOLT lock on my Jeep and loved it so I decided to get one for the Tundra when I bought it. I decided to put a set of Hammerloks on the safety chain holes because I was worried about the clearance you described. Probably not totally necessary, but it makes hooking up a lot easier.
  17. Sep 15, 2021 at 11:38 PM
    1stgentundradriver
    1stgentundradriver Each sticker adds at least 5hp
    Josh
    Silverdale Washington
    2006 DC 4x4 Limited
    A few
    I’ve got a Bolt hitch lock like what @ezdog has. I’ve had times where I locked the hitch pin in and yanked on the lock itself to make sure it was on and fallen backward because it popped off. I couldn’t tell a difference when I locked it on that it wasn’t seated properly. So I just make sure that it isn’t coming off each time by wiggling it. No issues with towing and no issues with the lock function not working. 30 bucks is steep though in my opinion but it’s kept my B&W hitch in my receiver which I like. 7B938C58-57F4-44B3-AA73-1D4489F7CDFA.jpg
    Here is my hitch and the other side of the bolt lock (the lock itself is facing away). I pull a car hauler and I ordered a 7” drop for use on multiple trucks.
  18. Sep 16, 2021 at 2:29 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
  19. Sep 16, 2021 at 9:16 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I used something like that once, seized on the truck and I had to cut it off.
    And cutting off took just seconds, so they really don't do much for security. If someone wants your hitch, they can get it in under 20 seconds.
  20. Sep 16, 2021 at 10:44 AM
    ezdog
    ezdog New Member
    Gateway To The West
    Maybe,Maybe not.
    https://www.youtube.com/watch?v=-Lq6_N5K1L4
    Randy Morton likes this.
  21. Sep 16, 2021 at 11:14 AM
    Randy Morton
    Randy
    It all depends on whether you're facing a pro, or an amateur. The pro will come equipped and take what he wants. He'll also go for the easiest first and leave the hard jobs for the amateur.
    A friend gave me the ball mount for my Tundra, it's an actual Toyota part, and I use it as simple protection for the truck. He came out of the store one day and found that someone had hit the back of his truck and the weren't able to get off the hitch. He didn't have a lock, so they pulled the pin and drove away with his ball mount and ball. The lock makes that a little harder to do.
  22. Sep 16, 2021 at 11:15 AM
    andnyleswillriot
    andnyleswillriot Not Remote Working
    Breckenridge, CO
    2016 DC w/ Black Topo Topper
    Toytec 3" w/2.5 Coilovers. SPC UCA's. Method Roost Bronze Wheels. 35" BFG KO2's. SPC Upper Control Arms. 2019+ TRD Pro Grill. LED headlight bulbs. 2020 OEM LED Fog lights. Tech12volts Remote Start. MobArmor Magnetic Phone Mount. Topo Topper.
    I mean if you really hate carrying an extra key, just keep it in your glove box haha It's not as if you're really going to be taking it on and off that much.
  23. Sep 16, 2021 at 11:39 AM
    ezdog
    ezdog New Member
    Gateway To The West
    I think you must mean that you are not going to be taking it on or off that much.
  24. Sep 16, 2021 at 12:10 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    If using the bolt lock, it's keyed to the truck key. You'll have it on you always if you're in your truck and it's on your truck. That's the appeal to this pin lock.
    NewImprovedRon likes this.
  25. Sep 16, 2021 at 12:13 PM
    1stgentundradriver
    Josh
    2006 DC 4x4 Limited
    A few
    Exactly.
  26. Sep 16, 2021 at 12:24 PM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    YUP, around this town if it isn't locked down, some A hole will try to steal it.
    jewsNbrews and FrenchToasty like this.
  27. Sep 16, 2021 at 1:12 PM
    ezdog
    ezdog New Member
    Gateway To The West
    It is one of the appeals of the Bolt but they also do seem tougher to snap off and easier to use than others I have used.
    Just because you might not take it off a lot you cant assume everyone else doesnt.
  28. Sep 16, 2021 at 1:56 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    mine was fine until the little cover it came with to keep the keyhole free of grime disappeared. from then on it was a challenge to get off and i eventually had to abandon it for fear of it seizing in place.
  29. Sep 16, 2021 at 2:13 PM
    Fishhead
    Fishhead New Member
    I’ve had one several years now. I usually tow about 20k a year. Never had an issue.
  30. Sep 16, 2021 at 2:53 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Had mine for almost two years, never been taken off. Not assuming anything.
