Anyone tried these rear tow hooks from Ebay?
Discussion in '3rd Gen Tundras (2022+)' started by The Dutch Man, Aug 8, 2024.
  1. Aug 8, 2024 at 6:04 AM
    The Dutch Man
    The Dutch Man [OP] New Member
  2. Aug 8, 2024 at 6:32 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    Better off spending your money on a proper hitch recovery point Like a Yankum 2" Hitch Receiver Recovery point. The NYTOP those are imitating are probably made in the same factory and the NYTOP's actually look pretty bomber. The fleabay ones look a little flimsy. I can't find anywhere on NYTOP's website where they state where their stuff is made so that usually points to made in China, so the ebay one's are probably a carbon copy but the pic's make it seem like the steel is fairly thin on the fleabay's.
    I'd spend my money on a hitch recovery point.
    https://yankum.com/products/2-inch-hitch-receiver-recovery-point
    Now if they start making imitation NYTOP front recovery points for about $200 that might be a different story.
  3. Aug 8, 2024 at 6:39 AM
    teab
    Ty
    Denver
    Looking side by side the NYTOP's the NYTOP appear to angle the gusset plate in the orientation of the pull forces rather than perpendicular which will make it stonger. It is very obvious the NYTOP's are a much thicker steel. If I had to use my eyecrometer I would estimate the fleabays at about 1/4" to 3/8" thick and the NYTOP's at about 3/4" thick.
    The recovery strap in the fleabay one looks like a seatbelt doesn't it? Kind of funny.
  4. Aug 8, 2024 at 6:43 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
  5. Aug 8, 2024 at 6:47 AM
    teab
    Ty
    Denver
    And also buy a kinetic recovery rope while you're at it so you don't snap shit when you pull hard on it?? There are other cheaper ropes on Amazon but Yankum is the gold standard
    https://yankum.com/products/python-kinetic-recovery-rope
  6. Aug 8, 2024 at 6:52 AM
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
    I always remember a saying my grandfather told me in this situation..."Buy cheap, pay twice!"
    BravoDeltaRomeo and teab like this.
  7. Aug 8, 2024 at 6:53 AM
    The Dutch Man
    Good points everyone. The NYTOP rear look cool and are priced at just over $300. The EBAY ones I received an offer for $179.00. Not a huge price difference but I figured that now I am starting to add some mods I was curious if anyone had tried the cheaper knock offs.
    Now my first next mod is the Reverse Lights from Diode Dynamics. Debating the SSC1 Pro's vs. the SSC2 Pro's.....hummmm
  8. Aug 8, 2024 at 6:53 AM
    The Dutch Man
    Buy once, cry once!
    BravoDeltaRomeo likes this.
  9. Aug 8, 2024 at 6:57 AM
    teab
    Ty
    Denver
    Exactly get a good hitch recovery point and there is no reason for rear recovery points when there is a perfectly good hitch there. The hitch is there so use it. Also each "recovery" point only pulls on one side of the hitch bolts and if you use the hitch then you pull on both sides like it was intended to be used.
