Anyone running 6112 @1.9 with 5160s and 35” Tires?
Discussion in '2.5 Gen Tundras (2014-2021)' started by FactoryW, Jan 15, 2020.
  1. Jan 15, 2020 at 12:37 PM
    FactoryW
    FactoryW [OP] New Member
    Will
    2014 Tundra SR5
    just installed 5160 and boss 4x4 1.5” shackles and have some pre assembled 6112 @1.9 ready to get installed but debating on maxing them out instead.
  2. Jan 15, 2020 at 12:50 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    1.9" will be very tight with 35s, also depends on your wheel offset and how much trimming you want to do
  3. Jan 15, 2020 at 1:17 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Max them out.
    95_BPmedic likes this.
  4. Jan 15, 2020 at 2:12 PM
    Platinum714
    Platinum714 A--A
    Ken
    Orange County, CA
    2019 platinum 4x4 magnetic gray
    I agree...max it out, but will depend on the rim. I got close to 35" (34.5") with 315/70/17's on Icon Rebound's. Didn't have to do any BMC, just mud flaps.
  5. Jan 15, 2020 at 3:04 PM
    FactoryW
    Will
    2014 Tundra SR5
    @Platinum714 I already did BMC since I had a friend that could do it. And cut bumper trim some and removed mud flaps. Planning on doing Methods with 0 offset and 35” Toyo MT. I just wasn’t sure if 1.9 setting is enough. Sounds like I gotta go to top setting
  6. Jan 15, 2020 at 3:09 PM
    t4r2tundra
    t4r2tundra New Member
    2019 Platinum 4x4 - Smoked Mesquite
    See sig for mods...
    top setting may be just enough. For reference, I have method 0 offsets on 35" Nitto Ridge with BMC and front liner mod. I'm on 3/1.5" level. Does not rub body mount (about 1/4-3/8") clearance. I did the BMC myself.
  7. Jan 15, 2020 at 3:09 PM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    there is an entire thread about this but the answer is no they won't fit.
    I'm on top setting with an aggressive BMC and 35s. They wouldn't have fit with out all the trimming I had to do.
  8. Jan 15, 2020 at 3:56 PM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    I had 5100s set at the middle setting with 1 coachbuilder shim on each side for a total of ~ 2" of lift and I was able to fit 35s with no cab mount chop. This was with stock UCAs and wheels with a +25 offset. I do have a high clearance front bumper but I think that I could have made these fit with a stock bumper with bumper shims and some trimming. (I did rub the front sway bar at full lock).
    Every truck is different (a friend with a 3" lift and similar offset wheels rubbed the cab mount with 34s). 35s will be tight and there is no guarantee but it should be possible with some work.
    Edit: I missed the post about going with 0 offset wheels. 35's will not fit with 0 offset wheels with the shocks set at 1.9" (Not without a whole lot of trimming.
  9. Jan 15, 2020 at 4:06 PM
    mcchase
    mcchase New Member
    chase
    I’m at 1.9 setting on 6112. I fit 315/70/17 duratracs on method 313 rims. 25 offset though
    Flyinryank likes this.
  10. Jan 16, 2020 at 8:12 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    When are you getting 37s :spy:
    Berdine[QUOTED] likes this.
  11. Jan 16, 2020 at 10:48 PM
    junior
    junior Member
    Zach
    Santa Cruz, CA
    2016 Tundra TRD Off Road
    Black Rhino Rapid 17" 35x12.5 Mickey Thompson Baja Boss Bilstein 6112 at 2.5" w/ 1 Coach Builder Shim on each side JBA UCAs Bilstein 5160 Dobinsons HD Leaf Springs Firestone Airbags + Daystar Cradles Leer 100XR Decked Drawers
    I would go with the 2.5 max setting... I tell you that having had mine installed first at 1.9 and then 5 months later paying even more $$$ to have them raised and the truck realigned :(
    cmiller219 and Platinum714 like this.
  12. Jan 17, 2020 at 9:23 AM
    Berdine
    Binghamton, NY
    I want 40s! But not ready to cut up the new truck. But maybe by summer, haha
    Alexstundra[QUOTED] likes this.
