Anyone running 39 km3 on their tundras?
Discussion in 'Wheels & Tires' started by channlan, Jan 27, 2021.
  1. Jan 27, 2021 at 10:13 AM
    channlan
    channlan [OP] New Member
    Just curious if anyone has run 39 km3s on their tundras? I'm running 37s without any issues but I think our trucks would look awesome with a little bigger tires.
  2. Feb 12, 2021 at 11:28 AM
    Fillup21
    Fillup21 New Member
    Felipe
    2014 SR5 4x4
    7" BDS Coilover lift
    Have you had any running with the 37’s?
  3. Feb 12, 2021 at 11:30 AM
    GreatBallsOfFire
    GreatBallsOfFire "I wanna go fast" - Ricky Bobby
    Seth
    Fairbanks, AK
    2017 Pyrite Mica Sequoia Limited
    I think there are a couple of dudes running 40s but I’m not sure what sorta lift that would take. I can just barely fit 37s... 39s would be awesome but without some major mods I won’t be even close to clearing the body mount.
  4. Feb 12, 2021 at 3:38 PM
    channlan
    I have some rubbing at full stuff but nothing serious. Been running it for about 6 months.
  5. Mar 10, 2021 at 2:04 PM
    BlackSheep
    BlackSheep caffeinated member
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    held together by duct tape and baling wire
    I've been on 37s for a couple years now...really wanting to try out 39s. I'd need gears for sure, cuz I'm still on stock 4.30s, and a high clearance front bumper, but I think I'd clear the UCA and the cab mount. I agree, OP, 39s on these trucks would look awesome.
  6. Mar 10, 2021 at 2:16 PM
    Getmeacoors
    Getmeacoors From the far Norcal
    California
    2019 sport 4x4 MGM
    Alot
    38 13.5 20 toyo mt. But I have about 8 inch lift. No rubbing unless fully stuffed and full turn on body mount but minimal. Wouldn't rub if I did the bmc better but it was my first attempt
    Darkness, ColoradoTJ and toyofan87 like this.
  7. Apr 16, 2021 at 1:51 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Was thinking 40s but then read all of the mods needed and the potential steering rack issues so I just started looking at 39s (39x13.50r17 on 0 offset). Did a quick google search and it looks like KM3 are the only 39s out there.
  8. Apr 17, 2021 at 1:05 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    Reg Cab Gang
    Kanati makes a 39x12.50r17
  9. May 5, 2021 at 6:08 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    I pulled the trigger. KM3 39x13.5r17
    I trimmed the rear section of the front fenders, and the front of the rear fenders. No rub in full lock.
  10. May 5, 2021 at 6:30 PM
    BlackSheep
    Scott
    Kansas City, MO
    :eek: That’s the sexiest thing I’ve ever seen, even if it’s white :boink:
    Cruzer[QUOTED] likes this.
  11. May 5, 2021 at 6:48 PM
    BlackSheep
    Scott
    Kansas City, MO
    Think I could fit those with 3" front lift? :monocle:
    Darkness, PermaFrostTRD and Doc9413 like this.
  12. May 5, 2021 at 6:51 PM
    kidrman
    kidrman New Member
    2020 Tundra CrewMax
    I don’t see why you couldn’t, just a little trimming. Jk
  13. May 5, 2021 at 7:52 PM
    channlan
    That looks so good. You running any spacers?
  14. May 5, 2021 at 8:55 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Thanks! No spacers. The 13.5” wide tires on 8.5” wide wheels stick out nicely.
  15. May 7, 2021 at 5:54 PM
    BlackSheep
    Scott
    Kansas City, MO
    God, I keep staring at this pic. I gotta do this. I need to put more miles on my truck, at the rate I’m going, I’ll have my current tires another four years :rofl:
    Darkness and Cruzer[QUOTED] like this.
  16. May 7, 2021 at 6:21 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    At least I'm not the only one staring at it :rofl:
    Darkness and Sunnier like this.
  17. May 8, 2021 at 5:33 AM
    BlackSheep
    Scott
    Kansas City, MO
    @Cruzer a few questions...
    How hard were those 39s to balance?
    Is the ride alright?
    How’s the contact patch with 13.50” tires on 8.5” wheels?
    What psi do you have them set at?
    How’s the throttle response feel with 5.29s?
    300BLK likes this.
  18. May 8, 2021 at 6:32 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    The shop didn’t seem to have any issues balancing them. They feel great on the road, I’ve gone up to 90mph with no issues. The max psi on the tire is 45lbs so I drive around with them at 35lbs. The ride is smooth, I don’t really feel any bumps with so much tire. It’s very quiet for MTs, the most quiet MTs I’ve had so far. Definitely can’t take corners like I did with 37s.
    I usually air down to 12lbs and my previous tires (STT Pros, X-MTs) they will noticeably flatten out (on 37s) especially the front wheels. I aired down to 12lbs on these KM3s and it was hardly noticeable BUT when I hit the obstacles they we’re definitely soft, pliable, and wrapping itself around the rock/tree log. My belief is that with narrow wheels and wide tires that it is harder to pop a bead because the tire, in its pre-mounted state, is about the same width as the wheel at the rim so it’s not trying to retract itself like it is on a 10 or 12” wide wheel - just my theory.
    I think throttle response is great. When I step on the pedal from a dead stop it just goes.
    BlackSheep[QUOTED] likes this.
  19. May 8, 2021 at 6:58 AM
    BlackSheep
    Scott
    Kansas City, MO
    Thanks for the response :thumbsup:
    My RWs are 8” wide I believe...wonder how that would work out
  20. May 8, 2021 at 6:59 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Most 13.5 wide tires recommend the minimum width to be 8.5" wide. Might not be safe on 8"?
  21. May 8, 2021 at 7:05 AM
    BlackSheep
    Scott
    Kansas City, MO
    Yeah that’s what I was thinking...my 12.50s on 8” wheels are about as wide as I can go I think.
  22. May 20, 2021 at 6:00 PM
    channlan
    @Cruzer if you were to go 40s were would it rub? I'm thinking of skipping 39s and going straight to 40s.
  23. May 21, 2021 at 7:04 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Yes, I think it would rub.
    These KM3s are not as square as most MTs, they are actually coned in where the tread meets the sidewall. Here were my 37" MTs, you can see its pretty square at the corner.
    Here are the KM3s
    Here it's more noticeable. If it wasn't coned in it would be close to the top of the rear fender.
    Also, with bigger tires come bigger problems. I took it out on the trails on its maiden voyage and damaged my front diff :mad: Wasn't expecting that, thought I would break a CV axle first, which I would have preferred.
    To beef up the front end I ordered RCV axles ($2k), I'm having large chromoly inner tie rods made, already have the CB outer tie rods. But we can't do sh!t about beefing up the front diff internals.
    Darkness likes this.
  24. May 21, 2021 at 7:09 AM
    BlackSheep
    Scott
    Kansas City, MO
    Yikes...not an inspiring start to your ride on 39s. Gives me a little pause about going that route myself...
  25. May 21, 2021 at 7:27 AM
    channlan
    What kind of damage was done to the diff? I thought that the 5.29 gears would be enough to compensate for the heavier tires.
  26. May 21, 2021 at 7:30 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    I'm taking it to the shop on Monday but I'm thinking a spider gear is shot.
  27. Jun 13, 2021 at 4:42 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Thought I'd give this thread an update.
    Turns out I snapped a stub shaft and the crazy thing is that Toyota does not sell this stub shaft. You would have to buy a whole front differential assembly, which would include the stub shaft. I was lucky that I had a spare differential laying around.
    Since fixing this issue 3 weeks ago I have broken 3 CV axles and a steering rack. Thinking about going big? Might want to think again.
    Darkness, ColoradoTJ, dorton and 6 others like this.
  28. Jun 13, 2021 at 6:10 PM
    BlackSheep
    Scott
    Kansas City, MO
    Damn that’s crazy. Are you going to drop back to 37s?
  29. Jun 13, 2021 at 6:20 PM
    Half Assed
    Heartland Florida
    Reg Cab Gang
    Damn. That's why I ordered 37s for mine.
    Bigger isnt always better, I learned that the hard way too.
    And 13.50s on a 8" wheel i would run that. Ive run 12.50 on a 6" wheel no problem. There will be a crown to the tread though, i just lowered tire pressure.
  30. Jun 13, 2021 at 6:30 PM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
    All this convo, maybe I'm in the wrong place or just fucking stupid
    But what lift are ya'll running with these 39's? Haven't seen that mentioned
