anyone know what these ports are for?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mike59, Oct 1, 2021.
  1. Oct 1, 2021 at 10:19 AM
    Mike59
    Mike59 [OP] Kentucky Traveller
    Central Kentucky
    2021 Tundra DC Limited 4x4 SSM
    just picked up this truck yesterday. 1st one I have owned since my 1995 F150 died a while back (rusted away). I have no idea what those 4 black holes in the bed are about. Line-X Bedliner to be installed next week.
  2. Oct 1, 2021 at 10:21 AM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    That's where the tonneau cover drain tubes pass through the bed on mine.
    Mike59[OP] likes this.
  3. Oct 1, 2021 at 10:32 AM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    You should have plugs for those holes
    I think they are about 12 bucks through Toyota
  4. Oct 1, 2021 at 10:37 AM
    Mike59
    Central Kentucky
    yeah they're blocked by plastic or rubber stuff, just curious about their purpose.
  5. Oct 1, 2021 at 10:49 AM
    2mchfun
    I used those to run lines to my bed mounted Rolls Royce Trent 7OOO tow/haul ass mod. Next up (2) GAU 8 30mm's off each front fender. Stock is just boring!!:headbang:
  6. Oct 1, 2021 at 10:49 AM
    THORYOTA
    THORYOTA God of Thunder
    Thor
    Asgard
    2021 MGM TRD CM "Mjölnir"
    cover drain tubes. If you get a hard cover with a drain system, you drill a hole through it and plug in the tube.
  7. Oct 1, 2021 at 11:08 AM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    Access ports for adding your rear bed wiring!
    Mike59[OP] and HighDesertSurfer like this.
  8. Oct 1, 2021 at 11:47 AM
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    They are drains. Most trucks have removable plugs in the bed to serve as drains. I guess Toyota expects some hard use out of the Tundra to need drains that size. Maybe they saw this picture? Jackstands were a good idea. It wouldn't take much to max out our payload with water.
