Anyone install an electric power outlet?
Discussion in 'Lighting' started by pamtnman, May 10, 2018.
  1. May 10, 2018 at 6:17 PM
    pamtnman
    pamtnman [OP] New Member
    God's Country
    '17 Tundra TRD CrewMax
    Working through the list
    Has anyone here installed an electric power outlet in their Tundra? Some Tacomas had it as an option, and it was really helpful. I'd like to get one on the Tundra, and I am curious what others have experienced. I think some of the winches have power outlets on them, which would resolve it. Thanks
  2. Aug 29, 2018 at 12:41 PM
    brayan975
    brayan975 El PINGU
    Brayan
    Miami
    2016 Black Tundra
    2 Inch Wheel spacers Red plastic dip emblem Red tailgate letters Rock Lights RGB pod lights Bull bar with LED bar
    power80 and pamtnman[OP] like this.
  3. Aug 29, 2018 at 5:33 PM
    pamtnman
    God's Country
    Thank you. You're right, this is a better solution than cutting and hard wiring an outlet
    brayan975[QUOTED] likes this.
  4. Aug 29, 2018 at 5:36 PM
    blizz86
    blizz86 New Member
    Depending on what you need to use it for I would look into an inverted with alligator clips to hook directly up to the battery.
  5. Aug 30, 2018 at 9:56 AM
    pamtnman
    God's Country
    Real basic power tools like circular saws, drills, etc.
  6. Aug 30, 2018 at 10:13 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Saws draw a ton of power, you're probably looking in the range of at least a 1500w inverter. You might be better off looking at some 2000w generators.
    NewImprovedRon likes this.
  7. Aug 30, 2018 at 10:15 AM
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    Yes,
    I have on the bed.
    Powerout plus DC outlet both
  8. Aug 30, 2018 at 2:13 PM
    PlatPro
    PlatPro New Member
    Randall
    A silk gloved hand with brass knuckles underneath.
    2014 Platinum, TRD Pro Suspension , Truxedo Bed Cover, Vent Shade Rain Guards, Tint match windows,TRD Exhaust, Linex, Custom Dyno Tune, TRD SwayBar, and just started.
    If you don’t already own a small portable generator, I would go that route. You will use it a ton. My Honda E2000 has been a wonderful power supply......I have a 3500 watt inverter installed in my truck. It is mounted in back of the back seat. The outlets come out the back of the center console. The inverter is wired directly to a second battery under the hood. I have a marine battery tender mounted under the hood that is used to charge the battery. I have an alarm on my phone that reminds me one night every other week to plug in. I use it maybe 5 times a year... I will take some pics for you. Would I do it again? Probably not because I always seem to use that little generator.
  9. Oct 13, 2018 at 5:53 AM
    power80
    power80 New Member
    2018 Tundra Crewmax Limited 4x4
    I previously owned a 2016 GMC Sierra. It had the 110V power outlet onboard which was great for plugging in the laptop on the road. I must say, I was pretty disappointed that the 2018 Tundra that I purchased did not have this as a standard feature. I will definitely be purchasing one of these inverters.
    I previously owned a 2016 GMC Sierra. It had the 110V power outlet onboard which was great for plugging in the laptop on the road. I must say, I was pretty disappointed that the 2018 Tundra that I purchased did not have this as a standard feature. I will definitely be purchasing one of these inverters. Thanks for sharing!
  10. Oct 13, 2018 at 6:14 AM
    nowayout
    nowayout New Member
    NY
    17 CM
    Even the Ram has the outlet. How could Toyota think its necessary to put into one truck (Tacoma) but not the other (Tundra).
    power80 likes this.
  11. Oct 13, 2018 at 7:19 AM
    Professional Hand Model
    Hand Protectors
    Bought this about 13 years ago. Works great for powering phones and Li-Ion batteries. Charges faster than line voltage! Charger articulates to accomodate different angles.
    brayan975 likes this.
  12. Jan 4, 2019 at 5:21 PM
    Fiestee23
    Fiestee23 A CHICK'S TRUCK
    SOCAL
    White sr5 4wd
    Screenshot_20190104-171618.jpg Screenshot_20190104-171901.jpg I think I want this in the back of my truck. Mainly for camping, or tailgating. I know I will need a second battery set up. So.... Gotta think bout that too... What u guys think of this set up?
  13. Jan 4, 2019 at 6:33 PM
    AlmightyCrash
    AlmightyCrash Tundra Rookie, Jeep Veteran
    Crash
    San Leon, TX
    2015 Tundra MGM SR5 TSS CrewMax
    I installed a hardwired system with outlets in the bed and in the rear of the center console.
    kcaustin66 and Fiestee23 like this.
  14. Jan 5, 2019 at 3:23 PM
    Fiestee23
    SOCAL
    White sr5 4wd
    Do you have pix or a build on it
  15. Jan 5, 2019 at 4:13 PM
    kcaustin66
    kcaustin66 New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    More info please
    Fiestee23 likes this.
  16. Jan 5, 2019 at 5:13 PM
    AlmightyCrash
    Crash
    San Leon, TX
    I’ll do a write up when I have time Monday and post it. :)
    Fiestee23[QUOTED] and potoghi like this.
  17. Jan 7, 2019 at 3:01 PM
    AlmightyCrash
    Crash
    San Leon, TX
