anyone had the "flex Lockup" SHUDDER on a 4.7 w/5Spd trans??
Discussion in '2nd Gen Tundras (2007-2013)' started by lugnuttz, Apr 6, 2018.
  1. Apr 6, 2018 at 4:43 AM
    lugnuttz
    lugnuttz [OP] New Member
    Dave
    09 Dc 4x4
    i just recently got this truck 09 Dc 4x4 5spd auto 4.7 with a lot of miles on it (131K) from a local small privately owned used car STEALER
    im getting a "shudder" from the driveline around 30-45 MPH and the specifics seem to match up with a tundra TSB that covers the 07-08 trucks with a 6Spd and 5.7L
    yes i know i have a diff trans and diff engine
    has this "flex lockup" malfunctioning torque converter been used on other tundras? or is there any other common issues known to the 4.7/5spd driveline that could explain this ??
    any help is appreciated
  2. Apr 19, 2018 at 4:08 PM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    I would check to be sure either your front or rear drive shaft U-joint is not going out on you. Grab the drive shaft and rotate it back and forth. If there is any movement or clunking sound, the U-joint is toast.
