Anyone go from aftermarket wheels back to stock and why?
Discussion in 'Wheels & Tires' started by Muleycrazy13, Jan 1, 2018.
  1. Jan 1, 2018 at 11:41 AM
    Muleycrazy13
    Muleycrazy13 [OP] New Member
    Buckeye, AZ
    2024 Chevy Silverado 2500HD Duramax
    I've noticed a few people switching back from aftermarket wheels to stock TRD wheels or to a set of PRO wheels. Is there any reason for this I'm just curious.
  2. Jan 1, 2018 at 5:00 PM
    Berettafan
    Berettafan New Member
    2017 CM
    I did. Was more about bigger tires feeling too heavy.
    Also not wild about the look of 25 offset either. Looks good from side and 3/4 angle but head on not so hot. The TRD wheels are not bad looking at all.
    blue16, waj30 and Black Wolf like this.
  3. Jan 1, 2018 at 5:15 PM
    FiveOhh
    FiveOhh New Member
    Josh
    Charlotte, NC
    2015 Black Tundra
    I personally think the TRD wheels are some of the best looking wheels for the Tundra.
    Scpringle likes this.
  4. Jan 1, 2018 at 5:19 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Is it common for aftermarket to have that much offset? Also, you went back because of the tire weight? Did you go back to stock tire?
  5. Jan 1, 2018 at 5:20 PM
    Berettafan
    2017 CM
    Yes I did.
  6. Jan 1, 2018 at 5:21 PM
    There are all kinds of aftermarket rims with various offsets. Positive and Negative.
    jeremyd likes this.
  7. Jan 1, 2018 at 5:25 PM
    CJ21
    CJ21 CJ-21
    DELAWARE
    2016 Tundra platinum
    Clifford Alarm, 7" BDS lift with Fox coil overs, 20x12 with -44 off set fuel Mavericks , 35" TOYO Open Country Tires , Bush Wacker pocket fender flare ,2" rear Leaf springs, Bull Bar,
    That Would Be like leaving your New Girl To go back to the Old One...LOL.......There's A REASON IT DID NOT WORK OUT!!!!!!:annoyed:
    :wave:
  8. Jan 1, 2018 at 5:26 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I’m in the dark with this offset stuff. I’ll have to educate myself. I’m guessing positive offset pushes the wheel out?
  9. Jan 1, 2018 at 5:28 PM
    CJ21
    CJ21 CJ-21
    DELAWARE
    ZERO OFFSET
    The hub mounting surface is even with the centerline of the wheel (dashed line to left).
    POSITIVE
    The hub mounting surface is toward the front or “wheel side” of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars. An example of a positive offset wheel is the Polaris RZR 1000 which comes stock with a +38mm offset. Higher offsets restrict design and leave the wheel looking flat, with little to no depth in spoke design/lip.
    NEGATIVE
    The hub mounting surface is toward the back or brake side of the wheel. “Deep dish” wheels are typically a negative offset and benefit the design process by allowing sharp angles, deep spokes and incredible layering.
    Tundra1078, Pudge and Prostar 190 like this.
  10. Jan 1, 2018 at 5:29 PM
    CJ21
    CJ21 CJ-21
    DELAWARE
  11. Jan 1, 2018 at 5:30 PM
    CJ21
    CJ21 CJ-21
    DELAWARE
    I am running 20x12 -44 Offset
    Berdine and Prostar 190 like this.
  12. Jan 1, 2018 at 5:31 PM
    My FN BFD rims have a +12mm offset. Seems to be just about right for my setup. Depends also on your tire size too.... oh...and lift...
  13. Jan 1, 2018 at 5:36 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Thanks! Based on that picture I would say the negative offset would push the wheel/tire out more?
    CJ21 likes this.
  14. Jan 1, 2018 at 6:43 PM
    mgh-pa
    mgh-pa Perpetually a New Member.
    2016 Tundra DC SR5
    I have a set of Ray 10s that will hopefully be here this month. I will try them out and see if I like the offset (my biggest concern). I really wanted Pro wheels but could never find any locally or priced well enough to allow shipping. If my Ray10s are not working for me, I will sell them on here in less than a day I'm sure ;)
  15. Jan 1, 2018 at 6:52 PM
    marcelo73
    marcelo73 New Member
    So Cal
    2016 Toyota Tundra Crewmax TRD PRO QUICKSAND
    295/70 18 Coopers
    Ray 10s are great looking wheels, I actually emailed them inquiring about 18's for Tundras, apparently they are enroute but all spoken for. I will be selling my PRO wheels to finance Ray 10s or other comparable. Would you happen to know how much each of these wheels weigh?
  16. Jan 1, 2018 at 6:54 PM
    mgh-pa
    2016 Tundra DC SR5
    I think around 28lbs.
  17. Jan 1, 2018 at 7:52 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    I like the way my OE wheels look. I also like that they're mostly tucked in under the wheel wells and that weight will be more properly balanced on the wheel bearings with stock wheels. I also like that I can find stock wheels for relatively cheap if I mash mine up off-road.
    BTBAKER likes this.
  18. Jan 1, 2018 at 8:06 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Stock wheels are +60 offset. The more negative, the more it sticks out. So a +25 offset will stick out 35mm more than a stock wheel. Also, if the new wheel is 9” wide, since it’s an inch wider than stock, half of that width will also add to how much it sticks out further than stock. (The other half goes to the inside)
    TundraBoss likes this.
  19. Jan 1, 2018 at 8:35 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Thanks! Makes sense now.
