Anyone else have this issue and how to fix??
Discussion in '2.5 Gen Tundras (2014-2021)' started by johnredcorn, Jan 1, 2026.
  1. Jan 1, 2026 at 1:49 PM
    johnredcorn
    johnredcorn [OP] New Member
    2017 Silver Limited 4x4
    Crew cab. Both passenger side doors.
  2. Jan 1, 2026 at 1:54 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Yes, assume it's a clip in part you can buy, never fixed it.
  3. Jan 1, 2026 at 2:02 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    They're called "window felts". I only have part numbers for my truck, which is a Standard Cab, so they won't be relevant to your truck.
  4. Jan 1, 2026 at 4:55 PM
    johnredcorn
    Thanks. Is it an easy fix? Any long term issues leaving as is?
  5. Jan 1, 2026 at 5:52 PM
    Corndog123 likes this.
  6. Jan 1, 2026 at 6:07 PM
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
  7. Jan 1, 2026 at 9:21 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    From what little I've read here, it should be pretty straightforward. If you leave it as is, I would imagine that eventually the partially detached portion will tear off, this will likely allow environmental debris to then fall between the glass and the outer door and collect inside the door which may wreak havoc with the mechanical and electrical components. Organic material might even begin to decay producing an odor and cause corrosion.
  8. Jan 2, 2026 at 4:55 AM
    ChesterTundra
    Central FL
    2020 Tundra SR5
    Wynnded described it well. You’ll have more water in the door and likely clog the door drains with debris, leading to bad things.
    23Tundy, johnredcorn[OP] and Wynnded like this.
  9. Jan 2, 2026 at 6:00 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Belt moldings. There’s an integrated plastic clip at the back of the front door, front of the back door. A 90 degree pick tool is perfect for releasing it. The rest is held on over metal tabs that grab the inside flange. Drop the window, press down firmly and roll the inner edge up towards you. You’ll feel it click off the tabs. Goes under the mirror a bit but that section is short enough to slide out.
  10. Jan 6, 2026 at 1:56 PM
    johnredcorn
    Thanks all. Got me in the right direction.
