Any John Deere Lawn Tractor Experts Out There?
Discussion in 'Off-Topic Discussion' started by NewImprovedRon, Jul 3, 2023.
  1. Jul 3, 2023 at 10:12 AM
    NewImprovedRon
    NewImprovedRon [OP] New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    I have a John Deere LX280 lawn tractor and recently sharpened the blades and replaced them. When replacing the blades, the Deflector Cup (goes above the blade and keeps crap out of the spindle) on one blade came loose and I pushed it back on and replaced the blade. Afterward, the mower made a rubbing/friction sound from that side of the mower. I suspect that I did not seat the deflector cup securely as required and there is friction between the cup and the blade but would like to tap into an expert's opinion. How are the deflector cups attached? Just press on? Thanks for any help!
    WILLINH and 2mchfun like this.
  2. Jul 3, 2023 at 11:19 AM
    NewImprovedRon
    Ron
    NW Arkansas
  3. Jul 3, 2023 at 12:38 PM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Wish I could help. I have a cub cadet zero turn with 3 blades and they don't have any kind of deflector or shroud above the blades.
    Can you manage to get some decent pics?
    NewImprovedRon[OP] likes this.
  4. Jul 3, 2023 at 1:07 PM
    2mchfun
    Maybe look at a parts diagram and see if there is anything that could have broken down over time. Thinking maybe a rubber type of washer between the cup and the blade would solve your problem and the original might have just rotted away. Just a guess though. Good luck!
  5. Jul 3, 2023 at 2:07 PM
    NewImprovedRon
    Ron
    NW Arkansas
    Thanks, Ron. I'll get the mower on my lift this week and see if I can get some pics.
  6. Jul 3, 2023 at 2:12 PM
    NewImprovedRon
    Ron
    NW Arkansas
    Thanks for the thinking, Dan. The parts diagrams I have seen don't show washer between the cup and the top of the blade. When I looked up the part number (M157142 - Deflector Cup) on Amazon, one of the reviews of the part said that it just attaches by way of a pressure fit around the spindle. It must clip in some way and has some slots in the cup along with the hole that the spindle sticks through for the blade bolt. I'll hopefully know more when I get the mower lifted.
    2mchfun[QUOTED] likes this.
