Any IT guys here
Discussion in 'Off-Topic Discussion' started by fisherman951, Oct 16, 2019.
  1. Oct 16, 2019 at 8:05 PM
    fisherman951
    fisherman951 [OP] MT dreams
    Tony
    2017 crewmax 4x4
    So I have the Orbi RK50 system and I’m tired of this things showing no internet connection for WiFi. The computer that’s plugged in thru the Ethernet cable works perfectly fine. I tried calling orbi but they just told me to reset everything which didn’t work. Who can help me out? Or have any ideas. I don’t wanna really can it as I paid 300 bucks in November for it so hopefully I can get it to work
  2. Oct 16, 2019 at 8:18 PM
    TheBeast The Beach
    mesh networking ? I have the EERO and it has been excellent.
    firmware upgrade maybe ? does it come with an app that handles upgrades ?
    did it always suck or is it recent ?
  3. Oct 16, 2019 at 8:23 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    I was able to use it on Saturday and checked updates and it was up to date thru the app. When it works it’s awesome I get reception everywhere and speeds are good since I have charter.
  4. Oct 16, 2019 at 8:26 PM
    ManoTundra
    ManoTundra New Member
    T
    NorCal - NE Bay
    2018 MGM Limited CM
    Not too familiar with the Orbi, how does it get its internet feed? Like do you have a router or modem from your ISP wired to it? You said it was working, for how long before it stopped?
  5. Oct 16, 2019 at 8:30 PM
    Tun-D
    Tun-D New Member
    Don
    Sacramento CA
    2019 TRD Sport MGM
    I thought the idea of the dedicated frequency for for multiple access points to communicate, leaving the normal WiFi frequencies avail for devices was great for a large house. Unfortunately, I tried two different versions of the Orbi and found the reception to be worse than just one cheapo router - TP-Link off Amazon. I returned both units to costco. I've tried multiple netgear devices for internet/home WiFi and have never had success with them.
    fisherman951[OP] likes this.
  6. Oct 16, 2019 at 8:34 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    So I have internet thru cable company so they gave me a router? That I just connected to my computer thru Ethernet wire. Then I added the orbi so I could have WiFi and it worked maybes for 6 months and now nothing at all. I never really bothered with it as we have another source of WiFi at the house but it’s super slow and sucks. So that’s why I want the other one fixed cuz it’s a lot faster.
  7. Oct 16, 2019 at 8:39 PM
    ManoTundra
    T
    NorCal - NE Bay
    2018 MGM Limited CM
    Did you recently update the PC or FW on the router from your cable company? You could try going from router to Orbi. Reboot the router, once up for a few, plug in the Orbi and let it boot up. See if you get any internet after that boot sequence. Also, if you dont have any special settings on your router, like MAC filtering, try a factory reset of it but I'd probably check with your cable company first to see if that would mess anything up on their end.
  8. Oct 16, 2019 at 8:42 PM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    x2 on eero. Been running it for about a year now and it’s been rock solid
    TheBeast[QUOTED] likes this.
  9. Oct 16, 2019 at 8:53 PM
    lewi3069
    lewi3069 New Member
    2017 Crew Max 4x4 Sunset Bronze
    I work in IT (Cybersecurity), and have a decent home lab. I'm sure we can figure something out.
    • What is the population density where you live?
    • Are there a lot of people near you, if you "search" for wifi do you see a lot of other networks near you? If so, do a lot of them have a similar name?
    • Are you comfortable installing an app like "wifiman" by Unifi to get a look at the channel usage.
    • How many devices are connected to your wifi?
  10. Oct 16, 2019 at 8:59 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Nothing with a similar name my 2 networks are the currently connected to and leave it alone
    What is that app about? 3 iPads and 3 cell phones are connected to WiFi
  11. Oct 16, 2019 at 9:02 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    If you're stacking the Orbi on top of the cable company's modem/router combo, it's possible that you're running into an IP conflict on the two. This used to happen a lot before brands started using different default IPs, like 192.168.1.1.
    You will probably be better off factory resetting it and starting from scratch.
    Also, for what it's worth, I'm running the Orbi with two satellites and it's been amazing for me. The only thing I had to change outside of the out of the box config was the daisychaining option, as my satellites would sometimes piggyback on each other and make the mesh eat shit.
    ManoTundra likes this.
  12. Oct 16, 2019 at 9:09 PM
    lewi3069
    lewi3069 New Member
    hmm... That could be an issue, but I wouldn't expect it to work for a while and then degrade (I might be mis-understanding if it worked in the first place). It sounds like support had him reset it already.
    The "other networks are what I'm refering to when asking about the similar name. Those are generally default from the ISP and aren't smart enough to run on another channel. Looks like you may have more networks near you. It's hard to say if the channel is being saturated until I see a screenshot of wifiman or similar app. I'll have to look into the system some more to understand the options that are available, as I run Unifi at home which is more of a pro-consumer/business grade device.
  13. Oct 16, 2019 at 9:12 PM
    lewi3069
    lewi3069 New Member
  14. Oct 21, 2019 at 1:22 PM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    What's your wireless environment like? lot of neighbors?
    If you're on Android you can use Wifi Overview 360 Pro, it will show you all the wifi signals around and help find what channel is best.
    Or leech off a neighbor who left default password on.
    I went through 2 TP Link devices in less than a year. Radios died on them. No radio signal broadcaster at all. I got Cisco wifi cert so I know a bit about these things.
    Ended up going to Asus RT-AC1900P. I get a 20% increase in wifi signal at the location where my wifi's desktop is over what TPLink junk was putting out.
  15. Oct 21, 2019 at 1:23 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    I unplugged everything for a couple hours (had to run errands) came home plugged everything back in and it’s been working now. Hopefully it keeps going lol
    ManoTundra and Pinay like this.
  16. Oct 21, 2019 at 1:24 PM
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    or reboot....
  17. Oct 21, 2019 at 1:47 PM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    Orbi should be decent at fending off the neighbors via switching channels - at least enough to not crash.
    Have you tried running the ISP provided modem/router in bridge mode, and using the Orbi as the router?
    With FiOS - I had Verizon enable the ethernet jack on my ONT (outside house), and run a Cat6 straight into my Google Wifi. No ISP provided equipment. For cable its different, to a degree, but you can still usually bridge through to your own equipment.
  18. Oct 21, 2019 at 2:08 PM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    What color are the lights on it?
    Solid blue, magenta or amber?
