Any issues with my new audio system?
Discussion in 'Audio & Video' started by jobe, Aug 15, 2020.
  1. Aug 15, 2020 at 1:35 PM
    jobe
    jobe [OP] New Member
    Jobe
    Las Vegas, NV
    2016 sr5 crew max
    pioneer dmh wt8600nex (also maestro rr, wiring kit harness and dash kit)
    alpine xs69c in the front doors
    jl jd1000/1 class d mono amp
    2 jbl 12tw3s in a box behind my back seat (2016 tundra crewmax)
    2 packs of noico 80 mil 36scft
    1 pack of noico red 150 mil 36scft car sound insulation, heat and cool liner self adhesive closed cell deadening material
    Any one see any problems with my new system? amp for the subwoofers and 69s off the head unit. is the head unit powerful enough to power these 69s? i have an amp under my passenger seat. i know i have to rewire everything for the new amp but do i have to rewire the new door speakers too? i have the truck gutted to put in the sound insulation so it wouldn't be a big deal. any pro tips or suggestions? thank you so much!!!
    PWMDMD likes this.
  2. Aug 15, 2020 at 2:08 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Looks good to me. Have you considered doing 6.5" components over the 6x9s. Better midbass response.
    Head unit should be enough to power the door speakers, but youll eventually want to run a 4ch amp to power the doors. You could future proof your list by installing two extra sets of RCA's from.the headahead unit and going up to a 2ga power wire. If you wanted to install a 4ch in the future you'd need a distro block and you'd be good to go
    Factory speaker wiring will be sufficient, but if your not lazy like I am, replace the wiring.
    jobe[OP] and AZBoatHauler like this.
  3. Aug 15, 2020 at 2:18 PM
    AZBoatHauler
    So.Arizona
    I agree. I went with the JL C1 components in all 4 doors.
  4. Aug 15, 2020 at 3:10 PM
    jobe
    Jobe
    Las Vegas, NV
    2016 sr5 crew max
    im sorry can you elaborate more on the rcas? do you just mean have some extra wires hanging out so i dont have to dig back into my head unit? also i have a fuse distribution block in my shopping cart now so thanks for the advice! also took the 69s out and put two pairs of jl c1s in so i guess i should just get a jl jd 400/4 amp and do it all right now?
    AZBoatHauler likes this.
  5. Aug 15, 2020 at 3:49 PM
    AZBoatHauler
    So.Arizona
    Or a 5 channel.
  6. Aug 15, 2020 at 8:30 PM
    Danimal86
    Daniel
    Sacramento, CA
    If you run a mono amp and a 4ch, you'll have 3 sets of rca's coming from the head unit.
    Make sure to get ofc power wire not cca, and don't get a fuse holder that takes those glass tube fuses. They are garbage.
    Usually the most youll get on the sub channel of a 5ch is 600w. Might come up a little short for op.
    But if he can make 500w to the subs work, definitely a great option.
    AZBoatHauler[QUOTED] likes this.
  7. Aug 15, 2020 at 11:16 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Those 6x9s need more power.
    jobe[OP] likes this.
  8. Aug 16, 2020 at 2:31 AM
    jobe
    Jobe
    Las Vegas, NV
    2016 sr5 crew max
    i switched the 69s out for 65s but i am wondering which ones to get now cause i thought it was supposed to have seperate tweeters that i put in the corner and the jl c1s dont have that so ill have to watch some videos and learn what is the best. i ordered the dmh wt8600nex (pretty excited) and a sub box for 2 12s. now i am just trying to figure out what door speakers to get and i am getting a jl jd400/4 for them. been looking up wires for a while now. by any chance can anyone post a link to the cable kit they would buy to wire the two amps. ty!
  9. Aug 16, 2020 at 6:13 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    C1s will have a separate tweet with integrated crossover. C1X is coaxial.
  10. Aug 16, 2020 at 6:36 AM
    619Tundra
    Have you looked into Focal Flax components?
  11. Aug 16, 2020 at 9:55 AM
    jobe
    Jobe
    Las Vegas, NV
    2016 sr5 crew max
    Thank you guys so much! i got the the dmh wt8600nex from crutchfield along with everything i need to keep my toyota features. i got the jl jd 400/4 amp and a jl jd 1000/1 class d mono amp. i got a pair of the jl 12tw3 d4s with a box for behind my seat and 2 pairs of the jl c1-650s for my doors. i also have noico 80 mil and noico sound insulation foam that i have been installing and an audio distribution fuse block. ill try to take a lot of pictures to show you guys but man i am very excited. i am well over 3500 dollars into this audio upgrade. i still need to buy a one (or two?) wire kits to wire everything up if you guys know of some good packages i would appreciate links. thank you!
    619Tundra likes this.
  12. Aug 16, 2020 at 10:01 AM
    jobe
    Jobe
    Las Vegas, NV
    2016 sr5 crew max
    also do i need to put the pillow stuff into my speaker boxes? its a sealed box btw
  13. Aug 16, 2020 at 10:35 AM
    Danimal86
    Daniel
    Sacramento, CA
    You might be able to get away with a 4ga wiring kit (up to 1k watts), but you'd be better with a 1/0ga kit. Check with crutchfield, sometimes if you order a head unit they'll give you a deal on a wiring kit.
    Something like this should work.
    https://www.crutchfield.com/p_575RFK1/Rockford-Fosgate-RFK1.html
    You don't have to get this one. Just make sure you get ofc (oxygen free copper) wire and not (copper clad aluminium).
    Another option:
    https://smile.amazon.com/dp/B075K5STX3/ref=cm_sw_r_cp_apa_i_i1woFb8RB4FKD
    You'll need 3 sets of rca's total, anyone's will work.
    Once you figure out a wiring kit, get a distro block that has 2 4ga outs and get a short run of 4ga to go to each amp.
    Yep. Hit Walmart and get some pillow filling.
    aparker813 likes this.
  14. Aug 16, 2020 at 11:24 AM
    aparker813
    aparker813 New Member
    Most likely not, unless the airspace of the box is too low. Polyfil is used to make a speaker think it has more airspace than it does, but those TW3 subs are made to excel with minimal airspace.
    For the wiring, check out Knukonceptz for some quality but inexpensive wire. Wherever you get your wire, make absolutely sure you get OFC (oxygen free copper) and not CCA (copper clad aluminum). CCA requires a much larger size wire to carry the same current and corrodes super fast. Not at all worth the savings.
    619Tundra and jobe[QUOTED][OP] like this.
  15. Aug 16, 2020 at 11:27 AM
    jobe
    Jobe
    Las Vegas, NV
    2016 sr5 crew max
  16. Aug 16, 2020 at 11:30 AM
    aparker813
    I ended up not using it but I ordered one of these and was pleasantly surprised at the build quality. Real nice combo distribution block modeled after the hundred and some odd dollar Audison model that you can't even find anymore.
    jobe[QUOTED][OP] likes this.
  17. Aug 16, 2020 at 1:34 PM
    jobe
    Jobe
    Las Vegas, NV
    2016 sr5 crew max
  18. Aug 16, 2020 at 9:09 PM
    619Tundra
    I bought some Black Hole Stuff from my Focal dealer. This stuff makes the bass sound so much richer. Woofers don't think. For the wire and RCAs use Knuconcepts. For fuse blocks and grounding blocks use kicker products.
  19. Aug 16, 2020 at 9:28 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I like KnuKonceptz for cables as well.
    http://www.knukonceptz.com/
    Used them for RCAs, speaker, and power wires.
    Ran 0ga for amp and battery cables, just because I could..
    0e33q5g2_zpssm0sqsag_813d798ec184e0790e7f6a565431d9931eaa976f.jpg e74i36du_zpshny0zage_3e6560b7c52791fe5d88d898422190220a9f005b.jpg
    8a47udpx_zpsqbtdzyfv_96373ae435c4ebb9d550bdfed78c776c46ef5aaf.jpg gvap7jp5_zps2iu2ff0k_dbf216b8dd86d54836468820fe4aabe9cccddc0c.jpg
    jobe[OP] and 619Tundra[QUOTED] like this.
  20. Aug 16, 2020 at 9:54 PM
    619Tundra
    Is that 0 gauge straight to the amp? What size of fuse did you use?
  21. Aug 17, 2020 at 2:10 AM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    I did the same thing, because I knew I would want to upgrade in the future. I m still working it all out, but the monoblock I ve chosen requires 3 runs of 0 guage, so I am thinking about a second battery in the back of cab.
    1lowlife[QUOTED] and jobe[OP] like this.
  22. Aug 17, 2020 at 6:24 AM
    jobe
    Jobe
    Las Vegas, NV
    2016 sr5 crew max
    let me know what you decide that sounds insane!!
  23. Aug 17, 2020 at 8:19 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    619Tundra[QUOTED] likes this.
  24. Aug 17, 2020 at 10:05 AM
    jobe
    Jobe
    Las Vegas, NV
    2016 sr5 crew max
  25. Aug 17, 2020 at 10:12 AM
    1lowlife
    DADA
    2014 MGM DC SR5
  26. Aug 17, 2020 at 10:45 AM
    jobe
    Jobe
    Las Vegas, NV
    2016 sr5 crew max
    yeah my friend was saying it was a bad idea. ill take it back and get a different one. its hard to find 12" sub boxes for behind the seat. maybe ill make my own.
  27. Aug 17, 2020 at 11:23 AM
    Danimal86
    Daniel
    Sacramento, CA
  28. Aug 17, 2020 at 11:27 AM
    Danimal86
    Daniel
    Sacramento, CA
    Are you going to go with a sealed or ported box?
    I had two 10tw3's in the stealthbox (sealed) and i ended up selling it and went with a ported box from tech12volt and its much better.....i'd recommend ported.
    You could check with tech12volt and see how much it will be just for a box if you already have the speakers. tech12volt@gmail.com
  29. Aug 27, 2020 at 12:56 PM
    jobe
    Jobe
    Las Vegas, NV
    2016 sr5 crew max
    i took my woofer box back and have been shopping for a new one. i sent tech12volt a message and also i fount this. what do you guys think?
    https://*********.com/shop/toyota-t...x-ported-subwoofer-box-dual-10-12-subwoofers/
    also i think i need a different amp i have been trying to look it up a lot. i have a jl jd 1000/1 with 2 jl 12tw3 d4s. if you guys have any suggestions for a better amp. price doesn't matter i just want the best bass i can get so the best box and whatever amp would be best with these two 12's! thanks!
  30. Aug 27, 2020 at 1:06 PM
    AZBoatHauler
    So.Arizona
