Another rims and tires thread
Discussion in 'Wheels & Tires' started by Caldider, Jan 3, 2019.
  1. Jan 3, 2019 at 3:25 AM
    Caldider
    Caldider [OP] New Member
    Calvin
    2007 Gray DC
    OK I'm pretty new to this metric sizing system for vehicles. I've been an old school guy I guess and am used to the standard sizing system lol. I'm wanting to get new rims and tires soon. I think I've narrowed it down to 18x9 Method NV or Roost wheels. Not 100% sure on tires yet but thinking 285/75 or 295/70 tires. I've got a mild leveling kit, I'm thinking its 1.5" in the front and not sure on the rear (bought the Tundra with it). Where I get lost is the offset area, what do you guys think would work? I would like the tires to be flush, maybe even a little "poke" Thanks
    OR18TRD likes this.
  2. Jan 3, 2019 at 4:33 AM
    OR18TRD
    OR18TRD Pândâ Crëw
    PDX
    2018 Panda Crewmax
    Suspension: front- Bilsein 6112 set at 1.9”; Rear- bilstein 5160 with maxtrac 1” shackel. Wheels: Method MR308 roost wheels 18x9” +18 offset. Tires: 275/70/18 Goodyear wrangler DuraTrac’s Removed front mudflaps and moved front wheel well liner forward. Bakflip MX4 Tonneau cover Line-x premium bed liner aFe CAI Rear differential breather moved behind taillight Debadged Windows tinted 20% ESP locking long box rear seat storage OEM all weather mats
    +25 to +35 give that flush little poke.
    I have the method roost wheels they are +18 and stick out about 1.5” or so that’s with 275/70/18’s
    I have the 6112/5160’s set at 1.9” in front and a 1” maxtrac shackel in back.
    I had 295/70/18 and even with removing mud flaps and moving the front wheel well liner forward and heating and molding they were still rubbing in reverse at lock. I didn’t want any of the tire options in 285/70/18 and 285/75/18 was taller than the 295/70/18’s so I went back down to 275/70/18 for now. I’m hoping BFG makes the KM3 in 285/70/18 soon. AE66FE4C-A6AF-4431-9E97-83B431AF38BD.jpg 9CF3F9BB-2897-45A1-B54C-6DCC17DE2A8B.jpg64AB9261-F2A3-4B67-B4A9-F578A478B654.jpgSometimes I think they look good and sometimes I think they could be bigger. I do like that I still get 12mpg in town and 16 on hwy.
  3. Jan 3, 2019 at 5:30 AM
    Caldider
    Calvin
    2007 Gray DC
    Thank you for the reply, and pics. Very nice truck BTW.
    You have the right amount of tire sticking out IMO. How do you like the Roost wheels?
    I forgot to mention I currently have 275/70R18. Is that the stock tire size for the Tundras?
    OR18TRD likes this.
  4. Jan 3, 2019 at 10:54 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    TRD Rear Anti-sway bar, TRD Pro skid plate, Bedrug bed mat, Icon Rebounds 285/75/17 Cooper Discoverer XLTs, Bilstein 6112s/5160s, Diamondback SE
    Welcome from Texas. Like OR18TRD said, +25 to +35 mm should be a good offset. I'm also old school (in my 50's), and it took me some getting used to the metric tire sizing system of late. I used this website to learn and compare tire sizes: 275/70R18 is not the stock size. I don't remember what the stock size is (maybe 255/70/18?), but 275/70R18 is roughly 33" in diameter by 11" wide. I ran that size on a stock suspension and rubbed the front little mud flap behind the bumper while in reverse and turning. But that was with 18x9 MB 352 wheels with +25mm offset. Interestingly enough, the more the wheel/tire sticks out, the more chance of rubbing the front fender well behind the bumper. Those with stock offset don't usually rub with 275/70R18 and stock suspension.
    With 1.5" of lift, it might be a tight fit for 295/70/18s, but probably doable by pushing in the front plastic and removing the front little mud flap. I removed that front plastic (behind the bumper) entirely and don't rub with 1.9" of lift and 285/75/17s (roughly the same size as 285/70/18s). That tire size is about 33.8" in diameter and 11.2" wide (about 1/2" smaller in diameter than the 295/70/18s. Main reason I went with a 17" tire/wheel combo is because of slightly less expensive tire options and a bit more sidewall.
    Either way, be sure to post pictures of whatever setup you go with!
  5. Jan 3, 2019 at 12:47 PM
    OR18TRD
    OR18TRD Pândâ Crëw
    PDX
    2018 Panda Crewmax
    Thanks you.
    I really like the roost wheels. I use to run the black steel wheels on some of my old toyota pickups and liked the way they looked. These kind of reminded me of them with a modern twist. I was going to paint the center ring and I might still do it :notsure: They kind of look like the old manual locking hub ring which I like. I have the TRD exhaust that has the chrome tips and I like just a touch of bling on the white and black. I call them the panda nips and tips :D
    The +18 offset is a little low I would have liked a +25 or +30 but there were no wheels I liked with that offset. I’m not a fan of the faux beadlock look. The other wheels I liked had even lower offsets. I also got these for $178 plus 20% off making them $142 from Discount tires on a blackfriday sale. Made it hard to pass up for under $150 a wheel. :thumbsup:
    equin and Caldider [OP] like this.
  6. Jan 3, 2019 at 3:48 PM
    Caldider
    Calvin
    2007 Gray DC
    Thanks for the replies guys. Here's what I'm working with. RevTech level. Looks like 1inch ish?
    2ndgenny, equin and OR18TRD like this.
  7. Jan 3, 2019 at 6:15 PM
    equin
    Ed
    DFW, TX
    If the puck/spacer is 1” thick, then I think it should provide about 2” of lift (roughly spacer thickness x 2 = amount of lift). I’m not familiar with Revtek spacers, though, but I thought they advertise a 3” lift (probably a 1.5” spacer would be my guess).
    With 3” of lift, it should be easier to fit 295/70/18s or 285/75/18s.
  8. Jan 3, 2019 at 6:50 PM
    Caldider
    Calvin
    2007 Gray DC
    Thank you for the reply. I was curious how all that stuff works out. Thanks again
  9. Jan 3, 2019 at 7:21 PM
    Law323
    Law323 Yes, Gorilla beats T-Rex EVERYTIME!!
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Looks like you have a 2”-2.5” up front.
    You can roll just fine on your 275/70’s or if you want more, 295’s will do/look great.
    I’m getting my roosts in in a week or so. You’ll do just fine with that offset!
    Good luck!
    Caldider [OP] and OR18TRD like this.
  10. Jan 3, 2019 at 7:22 PM
    OR18TRD
    OR18TRD Pândâ Crëw
    PDX
    2018 Panda Crewmax
    3” you have more options.
    Revtek makes 1.5” to 3” from what I’ve seen. I don’t think thats a 3” on his maybe 2.5” looks more like a 2” lift I had a 2” on my 2007 Tundra. Allowed me to run 305/55/20 tires had the TuRD off-road bilstein 4600 shocks it road ok. The 6112’s ride better.
    You’ve got lots of tire size options just depends on how much wheel well modification you’re willing to do. Also a good alignment guy can work wonders.
  11. Jan 4, 2019 at 4:41 AM
    Caldider
    Calvin
    2007 Gray DC
    Alright, I need your guys opinions. Which wheel would go good with the color of my truck? Looking at the Method Roost. I saw a similar color truck with the chrome blacked out and looked pretty good with the bronze.
  12. Jan 4, 2019 at 9:13 AM
    equin
    Ed
    DFW, TX
    Forgot to say earlier that your truck looks really good. I like that ARB bumper/winch combo.
    Anyway, you can't go wrong with Method wheels. Personally, I think it would look pretty nice with bronze wheels, but either color works great.
    Caldider [OP] likes this.
  13. Jan 4, 2019 at 9:16 AM
    ebpgh
    ebpgh New Member
    1 vote for the bronze.
  14. Jan 4, 2019 at 5:27 PM
    DiegoC
    DiegoC Cardi T
    Diego
    2016 White Tundra Limited ( Wannabe Sport)
    ReadyLift SST 3/1 Level Lift
    Go bronze. I just ordered a bronze set of NV 305s w/some 35 Toyo MTs. I have a 3in lift
    2ndgenny and Caldider [OP] like this.
  15. Jan 4, 2019 at 5:36 PM
    Caldider
    Calvin
    2007 Gray DC
    Thanks. Took a little to get used to that bumper but it grew on me. Bought the truck with everything on it so can't really take credit lol
    equin and 2ndgenny like this.
  16. Jan 4, 2019 at 5:37 PM
    Caldider
    Calvin
    2007 Gray DC
    I really dig the bronze. Just hope it looks ok with the color of my truck. Did you get your installed already? I'd like it see pics
    DiegoC and 2ndgenny like this.
  17. Jan 4, 2019 at 5:41 PM
    2ndgenny
    2ndgenny •STOCK PILING BUILD PARTS•
    Hinton Alberta, Canada
    Oh8 Limited DC Bush Beater!
    OME 3.5” 613’s & Dakar leafs, SPC UCA’s Daystar bag cups and bags. Arb bumper/2” rigid led fogs. Debadged. Smoked tailights/3rdbrake. Magnaflow catback.
    Welcome! X4 bronze. Nice truck. Looks like my 08 DC also with an arb. Although mine isn’t the ranch hand one. Both colors will look awesome though.
  18. Jan 4, 2019 at 5:57 PM
    OR18TRD
    OR18TRD Pândâ Crëw
    PDX
    2018 Panda Crewmax
    I had this same conundrum... even started a thread... most said bronze so I went black :devil:
    Bronze is the new black so everyone goes bronze, if I go black then I’ll be different :laughing:
    https://www.tundras.com/threads/bronze-vs-black.34592/
  19. Jan 4, 2019 at 6:17 PM
    Caldider
    Calvin
    2007 Gray DC
    Lol. I was thinking the same thing, as far as bronze is the New Black. Nobody in my town had them yet. Everybody has black. I'm sure that's the same everywhere though.
    OR18TRD likes this.
  20. Jan 5, 2019 at 5:22 PM
    Caldider
    Calvin
    2007 Gray DC
    Really eyeballing these now. SCS wheels
    OR18TRD likes this.
  21. Jan 7, 2019 at 9:05 PM
    DiegoC
    DiegoC Cardi T
    Diego
    Caldider [OP] and equin like this.
  22. Jan 7, 2019 at 9:32 PM
    Caldider
    Calvin
    2007 Gray DC
    That looks good! I ended up ordering the SCS Ray10. Should be here Wed!
    DiegoC and OR18TRD like this.
  23. Jan 9, 2019 at 3:57 PM
    Caldider
    Calvin
    2007 Gray DC
    They showed up today! Can't wait to get home and see them in person!
  24. Jan 9, 2019 at 4:02 PM
    Degausser
    Degausser New Member
    Kevin
    GA
    2017 Limited MGM CrewMax 4x4
    See sig for mods
    Great choice. That dark bronze should look really good with the color of your truck.
  25. Jan 9, 2019 at 4:11 PM
    Caldider
    Calvin
    2007 Gray DC
    Thank you! I sure hope so lol. I was hesitant at first but I think they will look good.
    Fyi I'm surprised how fast they got here. I think I ordered them the night of the 5th.
    Degausser likes this.
  26. Jan 9, 2019 at 4:16 PM
    Degausser
    Kevin
    GA
    See sig for mods
    I considered going dark bronze when I got mine. I ended up going gunmetal and love the way mine turned out, but I sometimes wonder how it would look with the bronze.
