Another 35" tire thought
Discussion in 'Wheels & Tires' started by Tracker, Sep 25, 2018.
  1. Sep 25, 2018 at 7:50 PM
    Tracker
    Tracker [OP] New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    So I have a 3/2. I'm on 20's with a +1. My research says theres a good chance I will have to cut the body mount. But what if I added a 1" body lift? I know the frame doesnt move but could this help at all? Also on that idea would I need brake line extensions or steering extensions?
    SoCal619 likes this.
  2. Sep 25, 2018 at 8:02 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    You’d only be moving the body in correlation to the tire. Issue will still be there since the tire will hit the body mount, which is unchanged even with a body lift. With the right spacing wheels, the body mount and 315/70s aren’t an issue.
  3. Sep 25, 2018 at 8:12 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    no body lift if need be get good 1/2” spacers. Also maybe get tires that measure 35 x 11.5 instead of 12.5
    Tracker[OP] likes this.
  4. Sep 25, 2018 at 8:23 PM
    TunderStorm
    TunderStorm New Member
    Michael
    2018 TRD SR5 CM MGM +
    - Toytec/Eibach 3/1.5 + TC UCAs - Fuel Vapor 18x9+20 w/BFG KO2 35’s - TRD sway bar - Go Rhino nerf bars - badge delete - Bakflip MX4 - ESP storage - Rockford Fosgate 10’s +++ - TRD shift knob - Weathertech front mats - Escort 360 hardwired - Window tint Future mods: N-Fab M-RDS front bumper w/40” Black Series RC Lightbar
    I have a 3/1.5 (+TCUCAs) and 35’s with 18x9 +20 and no cmc
    I’d try it. The chop will only cost you $150 or so worst case
  5. Sep 25, 2018 at 8:31 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    It's the +1 offset that's the problem. Done right the CMC isn't noticeable. You could try increasing caster with the eccentrics or reducing caster (not a good option IMO) with different UCAs. Wheel spacers will make it worse. I'm not a fan of body lifts because the increased length of the attachments to the frame make a weaker connection between cab and frame. (At least in my mind) In an accident I would be worried about having major issues, but that's just me.
    dcsleeper408 likes this.
  6. Sep 25, 2018 at 9:27 PM
    Tracker
    Shane
    I plan on bumper spacers regardless. I narrower tire might be a good way to go.
  7. Sep 28, 2018 at 5:45 AM
    ELKAHOLIC
    ELKAHOLIC New Member
    2018 MGM DC
    35’s on a readylift 3 with a 1.5 AAL in the rear. 1.5” spacers on stock rims/ 35/12.5/R18. No body rub, and had to cut about an inch of plastic off the front...
    May be worth trying some spacers.
  8. Sep 28, 2018 at 6:32 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Spacers on a +1 offset wheel are just gonna make the tires make a wider arch and exacerbate the problem. You having spacers brings the tire out to right around the sweet spot for offset.
    Mountun Goat likes this.
  9. Sep 28, 2018 at 6:55 AM
    TunderStorm
    Michael
    That truck/stance looks almost perfect imo. 9 wide wheels with a +1 would be more aggressive than that and look even better imo. No spacers needed
  10. Oct 3, 2018 at 8:22 PM
    Fraser
    Fraser New Member
    Brady
    British Columbia
    2018 Cement CrewMax
    What wheels are you running there Elk?
  11. Oct 3, 2018 at 8:49 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    Would a stock wheel mean:
    8” wide +60mm is about 6.86” backspace.
    Adding an1.5” spacer would mean 6.86 minus 1.5 = 5.36 or +21.84mm
    Is that right?
    How did you cram a 12.5 wide on an 8 wide. Lol :eek2:
    Looks good ... more pics. :D
  12. Oct 4, 2018 at 3:02 AM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    You need your offset more +20-35mm, the wheels you have now will require BMC qith 35s, unless you go 33s, just do the bmc, or get bigger lift
    Big J and dcsleeper408 like this.
