Amp temperature
Discussion in 'Audio & Video' started by PWMDMD, Mar 20, 2020.
  1. Mar 20, 2020 at 9:24 AM
    PWMDMD
    PWMDMD [OP] New Member
    Worcester, MA
    2020 Tundra Platinum
    Just a general question. I have an Infinity Kappa 5-channel amp powering four speakers and a sub. I was just beating on it pretty good for about an hour while driving and I wanted to see how warm it was and it was perfectly cool to the touch. This is a fan-less unit...shouldn't it be warm?
  2. Mar 20, 2020 at 9:29 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Why make an issue of a non issue? Lol. Staying cool is a good thing. Heat kills electronics.
    PWMDMD[OP] likes this.
  3. Mar 20, 2020 at 9:32 AM
    PWMDMD
    Worcester, MA
    I'm not sure I have my gains up enough on the four door channels. My understanding is gain, while not a volume knob, is meant to match the output voltage of the HU to the input voltage sensitivity of the amp and a gain that is too low results in the inability to drive the amp at its maximum level. That said, I don't want to turn them up too much and damage anything. James suggested putting the gains up to about ½ and I have them well below that because I don't want to take the speakers to the ragged edge but don't want to leave too much on the table either.
  4. Mar 20, 2020 at 9:34 AM
    Danman34
    Danman34 New Member
    Danny
    All turning gains higher does is introduce possible distortion and clipping into the speakers. If it sounds good to you, that’s all that matters. What are you using as a processor to send signal to your amp?
  5. Mar 20, 2020 at 9:35 AM
    PWMDMD
    Worcester, MA
  6. Mar 20, 2020 at 9:39 AM
    Danman34
    Danman34 New Member
    Danny
    That unit is already sending a clean, high voltage signal to the amp. This is ideal for being able to keep gains on the amp low. You would increase gains if you’re using a cheap unit that only puts out a 2.0v preout. But anything in the 4-6v range you really won’t need to have the gain any more than halfway. How did you set the gains?
  7. Mar 20, 2020 at 9:41 AM
    PWMDMD
    Worcester, MA
    The least scientific way possible. James suggested ½ and I cut it in half to ¼...lol
    No voltmeter, oscilloscope or distortion detector...lol
  8. Mar 20, 2020 at 9:53 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    if you want to get nerdy, download the audiotools app to your phone.
    https://studiosixdigital.com/audiotools-modules-2/
    bunch of great tools and it'll let you run pink noise through your system to dial everything in. i posted this thread that talks a little about it. i'm using a TwK88 for the processor though.
    PWMDMD[QUOTED][OP] likes this.
  9. Mar 20, 2020 at 9:55 AM
    PWMDMD
    Worcester, MA
    Thank you!
    smslavin[QUOTED] likes this.
  10. Mar 20, 2020 at 10:35 AM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    what else are you going to under quarantine? :cheers: :rofl:
  11. Mar 20, 2020 at 11:13 AM
    PWMDMD
    Worcester, MA
    Cool app. Using my iPhone 11 Pro Max mic
    1. I get a relatively flat curve using the realtime analyzer using pink noise until the crossover frequency of the sub which makes sense.
    2. Distortion was anywhere between 0.5% and 2.0% depending on the frequency - had that cranked up pretty loud.
    3. Polarity tests shows sub, midwoofers and Lt/Rt dash speakers are all negative but all door tweeters came back positive? These are connect to the door mid-woofers through a harness supplied by James. Any ideas?
  12. Mar 20, 2020 at 11:53 AM
    _SP_
    _SP_ New Member
    Shawn
    2014 1794 Edition
    de-chromed
    My AudioControl Amp has a nice UI via a laptop or iPad app. Lets you do soooooooOOo much stuff. Time control ect..
    Nothing about temps though. I rant it Hard as I could and it does not get warm to the touch. But im no where near using all 1200 watts at 4 ohms
  13. Mar 20, 2020 at 12:47 PM
    PWMDMD
    Worcester, MA
    I really like the Audiocontrol gear. Has anyone messed around with the tuning settings in the DSR1?
