AMP steps coming in today, any install tips
Discussion in '3rd Gen Tundras (2014+)' started by 94slowbra, Mar 1, 2018.
  1. Mar 1, 2018 at 1:36 PM
    94slowbra
    94slowbra [OP] New Member
    john
    new orleans
    2016 TRD pro
    just like the title says, my non PnP amp steps are arriving today and i will be installing them tomorrow. any install tips from those that have done them before? ive read the directions and they dont seem overly complicated. thanks in advance for the help!
  2. Mar 1, 2018 at 2:31 PM
    duece292
    duece292 Pennsylvania Hillbilly Deluxe
    Greg
    Green Bay, WI
    They're fairly easy to do, just follow the directions step for step. A few tips after installing close to 100 sets....
    Spray some white lithium grease on the gears before mounting the motor to the linkage.
    A little dielectric grease in the plugs will go a long way towards preventing corrosion.
    Start the cap screws that hold the boards to the linkage but don't fully tighten. After everything is hooked up, cycle the boards a few times and then tighten. This will prevent binding and will allow the board to settle evenly from end to end.
    The amp wires are color matched to the door trigger wires. But if you are going to test the truck wires they'll go to ground with the door open. Hold your tester on the wire and have someone push the black plunger on the door jamb and the wire will test positive.
    Everything else should be easy peezy. Good luck!
    Tundra Fan, 619Tundra and geno0506 like this.
  3. Mar 1, 2018 at 2:35 PM
    Danimal86
    Danimal86 What's a Dickfir?
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    ^ what he said
    and have some silicone lube handy to help get the light wires through the grommets.
  4. Mar 1, 2018 at 2:44 PM
    94slowbra
    john
    new orleans
    2016 TRD pro
    awesome insight. thanks
    duece292 likes this.
  5. Mar 1, 2018 at 2:46 PM
    tomsinamerica
    tomsinamerica New Member
    Tom
    Wilmington, NC
    White 2016 Tundra DC ltd
    I just ordered mine today too! Great advice @duece292, thanks!
    geno0506 and duece292 like this.
  6. Mar 1, 2018 at 2:54 PM
    BayRunner
    BayRunner New Member
    2017 Tundra Platinum
    Seriously thinking about these. SVCustoms is offering a very good price.
    ChucklesToy and geno0506 like this.
  7. Mar 1, 2018 at 4:02 PM
    geno0506
    geno0506 GENO
    Michael
    San Antonio, Texas
    these helped me as well as the great brothers here!
    http://www.tundratalk.net/forums/tu.../720361-amp-research-install.html#post9035066
    https://www.youtube.com/watch?v=FvNGJLMrVic&t=484s
    If you have a torque wrench, these are a must, I got them at WallyWorld, they almost same price as Amazon!
    https://www.amazon.com/Stanley-85-7...948406&sr=8-1&keywords=stanley+hex+socket+set
    https://www.amazon.com/Stanley-85-7...rd_wg=RFFDr&psc=1&refRID=2TBHPTHS9FP7VF4DF88E
    Also the little grommets for the plastic motor cover suck so I used zip ties, they are firmer and close tighter!
    Screen Shot 2018-03-01 at 5.56.32 PM.jpg Screen Shot 2018-03-01 at 5.57.10 PM.jpg
    Also I bought extra long zip ties and zip tied the harness and wires firmly!
    The instruction are pretty easy to follow!
    I did cross the control purple wires wrong and thanks to duece292 above, I rewired them correctly, purple with tiny black streak to the same, and plain purple to plain purple!
    Good luck!
    NewImprovedRon, RangerBP and 831Tun like this.
  8. Mar 1, 2018 at 5:37 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    The 2018 and 2017 wiring is completely different and the instructions don't address that. Luckily somebody figured it out in the thread below, it starts in post #16.
    https://www.tundras.com/threads/amp-research-side-steps-on-2018-tundra.18022/
    Edit: that probably should be placed in the "How To" section as I am sure quite a few people will find it helpful.
  9. Mar 1, 2018 at 6:35 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    When one of you guys get your boards in, could one of you get me the measurements of the T-nuts that slide into the boards for mounting to the linkage. I want to buy a couple, but would prefer to find them local and not have to order them from Amp, if I don't have to.
    geno0506 likes this.
  10. Mar 1, 2018 at 7:00 PM
    geno0506
    geno0506 GENO
    Michael
    San Antonio, Texas
    Do you mean C
    Im sure if you call support they would send some some free!
  11. Mar 1, 2018 at 8:54 PM
    94slowbra
    john
    new orleans
    2016 TRD pro
    Mine are going in tomorrow, I'll let you know.
    Louisiana? What part are you from. I'm in New orleans
  12. Mar 2, 2018 at 12:00 AM
    Cuzican
    Cuzican New Member
    Louisiana
    Yes, Item C.
    I'm on the other side of the state just north of Lake Charles.
  13. Mar 2, 2018 at 7:02 AM
    Berettafan
    Berettafan New Member
    2017 CM
    SVC is the only place to buy these.
    Contact them for the best price.
    No kidding.
  14. Mar 2, 2018 at 7:19 AM
    jason.bird
    jason.bird New Member
    Idaho Falls, Idaho
    2018 Toyota Tundra SR5 Sport
    I really want to buy these for my 2018 Tundra. Are there any issues with ice and snow? I live in Idaho and we definitely get our fair share of snow.
  15. Mar 2, 2018 at 8:56 AM
    geno0506
    geno0506 GENO
    Michael
    San Antonio, Texas
    619Tundra, ChucklesToy and ZPMAN like this.
  16. Mar 2, 2018 at 10:42 AM
    ZPMAN
    Minnesota
    Only tip i have is don't run out of beer.
    hogpiolet and geno0506 like this.
  17. Mar 2, 2018 at 12:53 PM
    Berettafan
    2017 CM
    we got a decent amount this year and I had no issues. have read of some though.
  18. Mar 2, 2018 at 1:02 PM
    jason.bird
    Idaho Falls, Idaho
    Nice truck and thanks for the reply!
    I've read that they can freeze and can burn out the motor. I'm wondering if they come with a toggle to turn them on/off or if a person could add a toggle to disable them.
  19. Mar 2, 2018 at 4:52 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    I had electric running boards on my last two F-150s, they were OEM but are manufactured by Amp for Ford. Long story short, the Ford owner's manual advises to turn them off if there is chance of them freezing (I.e. slush or freezing rain). I followed the instructions and never had a problem. Take it for what its worth.
  20. Mar 2, 2018 at 5:19 PM
    jason.bird
    Idaho Falls, Idaho
    Was there just a button or toggle?
  21. Mar 2, 2018 at 5:50 PM
    geno0506
    geno0506 GENO
    Michael
    San Antonio, Texas
    5 year warranty is great!
  22. Mar 2, 2018 at 5:57 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    No, I had the choice of three modes which I could access/select through the settings menu in the instrument cluster: automatic, lowered, off. If your steps don't come with a switch you could always add one to interrupt the main power to the controller or relay.
    jason.bird likes this.
  23. Mar 2, 2018 at 6:19 PM
    geno0506
    geno0506 GENO
    Michael
    San Antonio, Texas
    If you have the Pnp like mine, you just unplug the module that connects to the in cabin computer hook up under the steering wheel on the left!
  24. Mar 2, 2018 at 6:22 PM
    94slowbra
    john
    new orleans
    2016 TRD pro
    i finally got them installed. took about 4 hrs by myself. nothing was hard except for the stupid plastic rivets to put the cover on the motor. i damn near cut my finger off trying to use a screw driver to press it in. slipped and caught my finger. but in the end it was a very straight forward install. only disappointment is the shitty lights that amp uses. ill definitely be replacing them with something better soon.
    my kids were very excited when i picked them up from school. my 4yr old can get i by herself now.
    for anybody on the fence about these get them. i know that sliders are what all the cool kids are running but i just dont have a need for those. these fit my needs perfectly. there when i need them and hidden when i dont. ill get some pics up soon when i have some light out.
    thanks again for the tips fellas
    duece292 and geno0506 like this.
  25. Mar 2, 2018 at 6:54 PM
    geno0506
    geno0506 GENO
    Michael
    San Antonio, Texas
    I hated those cheap rivers so I chucked them and used zip ties and they zipped tight and not rattle at all, like the rivets!
    Let me know what you replace the amp leds with, I want to change mine out as well!
    Thanks
  26. Mar 2, 2018 at 7:03 PM
    94slowbra
    john
    new orleans
    2016 TRD pro
    Funny, I ended up using zip ties too. So much easier.
    I'll keep you posted on the lights. I've looked at the KC cyclones, looks like and awesome light just don't want it to new too much.
  27. Mar 2, 2018 at 7:06 PM
    geno0506
    geno0506 GENO
    Michael
    San Antonio, Texas
    :thumbsup:
    Yeah the amp leds are cheesy and yeah new ones not to bright but better them amps !
    Also it feels like getting into a luxury truck and seeing people staring when they open and close priceless
  28. Mar 2, 2018 at 8:10 PM
    ChucklesToy
    ChucklesToy New Member
    Chuck
    Round Rock, TX
    2019 Honda Ridgeline RTL-E
    I used zip ties too. One of the rivets broke when I was installing so took the other out and used zip ties. As far as using their LEDs goes, I chose not to use them at all. My truck has puddle lights so IP don't need the LEDs - wife wanted to try without and likes it this way. I just used electrical tape on the connectors on the harness end and taped them to the harness. I had AMP PowerSteps on my Silverado and their LEDs kept dying. Not impressed with their LEDs, but love the steps and their customer service was great.
  29. Mar 2, 2018 at 8:22 PM
    geno0506
    geno0506 GENO
    Michael
    San Antonio, Texas
  30. Mar 2, 2018 at 8:23 PM
    94slowbra
    john
    new orleans
    2016 TRD pro
    Plus they are kind of purple. If thats the worst i can deal with that. Kc cyclones are $100 for 4. I'll probably just go that route and have tons of light
    geno0506 and ChucklesToy like this.
