AMP research steps
Discussion in 'General Tundra Discussion' started by NCTundra18, Dec 12, 2021.
  1. Dec 12, 2021 at 10:36 AM
    NCTundra18
    NCTundra18 [OP] New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    So I'm going to put these steps on my 2018 crewmax. They're supposed to be here on Tuesday so hopefully I can get them on Wednesday. Anyways, has anyone else done this on their 18 Tundra? The wiring instructions are lacking to say the least. I would appreciate anyone's help.
    Thanks
  2. Dec 12, 2021 at 10:55 AM
    CoachRob
    CoachRob New Member
    Platinum 4x4
    I did not install mine, but I LOVE them. Very sturdy (does not lean when stand on them, even multiple people), the lighting helps at night for sure, and also insures me I closed my doors haha
    NCTundra18[OP] likes this.
  3. Dec 12, 2021 at 10:59 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I have them and installed them myself. A quick search on this forum will net you the information you need.
  4. Dec 12, 2021 at 11:01 AM
    NCTundra18
    Jeff
    Candler, NC
    Thanks, yeah I think I found what I needed.
    r1-superstar[QUOTED] likes this.
  5. Dec 12, 2021 at 11:02 AM
    r1-superstar
    DB
    UTAH
  6. Dec 12, 2021 at 11:03 AM
    r1-superstar
    DB
    UTAH
    Cool! Enjoy the install and get ready to be rewarded with cool powered running boards!!!
  7. Dec 12, 2021 at 11:10 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    I have them on my 18’. I literally installed them between squall lines during a hurricane 2 years ago. It was that easy.
  8. Dec 12, 2021 at 11:13 AM
    NCTundra18
    Jeff
    Candler, NC
    Well I hope I don't have to do that, lol.
  9. Dec 14, 2021 at 4:34 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    When I installed them on my '17 right after I got it, I called AMP Customer Service to verify which wires I was supposed to tap into. They were very knowledgeable, if you have any questions.
  10. Dec 14, 2021 at 5:07 AM
    NCTundra18
    Jeff
    Candler, NC
    Thanks, I'll keep that in mind.
  11. Dec 14, 2021 at 6:28 AM
    BayRunner
    2017 Tundra Platinum
    I installed mine on my ‘17 which I believe was the last year for true plug and play. I just plugged it into the ODB port and was done.,
  12. Dec 14, 2021 at 7:06 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    Yes, the plug-n-play option was available but $100 more so I installed the wired version. Didn't realize they don't have that anymore.
  13. Dec 14, 2021 at 7:36 AM
    AJGallo41
    AJGallo41 New Member
    Aj
    MN
    2016 Tundra Crewmax 5.7
    Level Kit 275/70r18 BFG KO2's
    Just installed these last weekend on my Tundra, between the thread on here and the Youtube video of install on a Tundra is was pretty straight forward. I will say to make sure the wiring is fed through the appropriate channels because they give you no extra wiring so if it's not run in the shortest distance possible you may have to mount the controller in a different position.
  14. Dec 14, 2021 at 7:39 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    Do they still provide those Posi-Taps to make the wiring connections? First time I ever saw them was when Amp provided them and I thought they were very cool. Have bought some myself since and really like them but they are expensive.
  15. Dec 14, 2021 at 7:41 AM
    AJGallo41
    Aj
    MN
    They do but they aren't the best in my experience, two of them didn't tap properly when I was installing my steps and it drove me nuts trying to figure out the culprit.
  16. Dec 14, 2021 at 7:45 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    I am surprised. Seemed rugged and fool-proof to me as long as you had the right size connectors for the wire.
  17. Dec 15, 2021 at 6:41 AM
    NCTundra18
    Jeff
    Candler, NC
    Thanks for all the help. I'm starting the install right now. I'll let you know how it turns out.
    r1-superstar and AJGallo41 like this.
