Amp placement
Discussion in 'Audio & Video' started by Pudge, Apr 6, 2019.
  1. Apr 6, 2019 at 9:09 PM
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    I have gathered all the components needed to upgrade my stereo. The speakers are all installed and the next phase is head units w/ maestro and a JL audio amp. I have the stock JBL system and know the amp for that is under the passenger front seat. Where should I put my new amp? Under the front seat or should install it behind the rear seat or under the rear seat. I suppose I would need shorter power and RCA runs if I go under the front seat and just a longer wire to the sub. I did but all the wiring needed at lengths to get the amp to the back wall of the truck if needed, including a 10 ft 9 conductor cable to run from the amp to the old amp location to pic up the speaker wires and remote wire there. Now I'm wondering if I dont even need that 9 conductor wire if I place the amp under the front seat. What is the best and easiest location to put my amp, including making adjustments to the amp controls such as gain and whatnot. I do not have any rear underseat storage bins to get in the way under the rear seat.
    Plan is to wire the left and right corner dash speakers off the head unit's front speaker outputs, the dual JL tweeter center channel speakers off the head unit's rear outputs. I will then power the door component speakers and sub off the amp. I came up with this idea when discussing my install with James at tech12volts and he thinks it's the way to go since I have a 4 channel amp.
    So where would you place the amp? My thought is under the passenger rear seat, but I see a lot of installs removing the OEM JBL amp and placing the new amp under the front passenger seat. Any and all ideas are welcome, pics too.
    Thanks
  2. Apr 7, 2019 at 9:41 PM
    Pudge
    CT
    Anybody? Maybe have pics of where you mounted your amp? I'm looking simple under front or back seat.
  3. Apr 7, 2019 at 10:11 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I added my 2-channel amp for my sub under the driver's seat. I've seen a few installs that replace the factory amp with a new 4/5 channel in the factory location and looks really clean. I'm with you on keeping it closer to the front to limit the length of wire needed, but probably isn't a huge deal to run behind the back seat.
    Pudge[OP] likes this.
  4. Apr 7, 2019 at 10:56 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    @Pudge i have a kicker hideaway under my drivers seat and it’s as big or bigger than most amps would be. I also have my 4 channel amp and signal processor under the passenger seat. The amp is above the carpet with easy access to gain/crossover controls and the signal processor is under the carpet where the factory amp was since once it’s set there is really no need for access and it cleaner that having it visible in addition to the amp. Don’t have pics of the passenger seat but if beneath your drivers seat is free there is actually a flatter/larger area compared to the passenger side.
    02F3B2F2-4A82-4AEE-B31C-E61164414FBF.jpg F68B6DC6-932E-47C4-B738-ACB4DBA4A267.jpg
  5. Apr 8, 2019 at 3:45 AM
    Cfincke
    San Antonio
    My amps are under the front seats since I have the EPS storage unit under the rear seats. If you ever plan to add the under seat storage, I would install you amp under a front seat.
    Are you running new speaker wire or reusing the factory wiring? If reusing, you may want the amp under the front passenger seat, as that is where the factory harness is that feeds to the speakers.
  6. Apr 8, 2019 at 6:01 AM
    Pudge
    CT
    Reusing factory wires. Front passenger seat is what I will do
  7. Apr 8, 2019 at 6:13 AM
    Twinky
    07 double cab work horse
    Front passenger seat should work well. Shorter power wire run. Speaker and rca wires under the center console. Remote wire under the drivers front dash and run it the rest of the waywith the power. Gound is kinda up to you.
    Eazy peazy
  8. Jun 7, 2019 at 8:03 AM
    Jai LI
    Jai LI New Member
    TX
    2018 CM 1794 5.7 4x4 FFV
    Rear sway bar, CAI and sound deadening
    Passenger seat... sorry don't have a better pic. Used the amp rack from *********.
  9. Jun 7, 2019 at 8:54 AM
    tundraal
    tundraal New Member
    Are you running new speaker wire to the door speakers? If not, just buy the ********* wiring harness for their amp. It will plug into the factory wiring harness under the passanger side seat. You can cut off their molex connectors and connect to any amp you want. That's what I did.
    I also bought their amp rack too.
    http://imgur.com/Aie6uE1
  10. Jun 7, 2019 at 9:02 AM
    Duneflyer
    Duneflyer MGM is the light at the end of the tunnel
    Darren
    Yuma AZ
    2017 1794 edition Crewmax 4x4
    Nitro 4:88 gear package with locker in rearend, Procomp 6" lift, mid travel arms, with devers on back, Fox 2.5 coilovers
    I cut the carpet and removed the foam under the rear seats, placed my amps (2) in the cutouts and then flopped the carpet over the amps to cover them.
  11. Jun 7, 2019 at 9:04 AM
    Pudge
    CT
    No concern about heat due to amps being covered?
    TomC843 likes this.
  12. Jun 7, 2019 at 9:15 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    There should be. They need some ventilation. At minimum this will shorten the life due to heat. May even cutout on warmer days.
    Pudge[QUOTED][OP] likes this.
  13. Jun 7, 2019 at 9:16 AM
    Duneflyer
    Darren
    Yuma AZ
    Not at all. The styrofoam actually acts as a heat reducer, and Im running JL amps, so, its quality as well. I have had it for 2 years this way and not a problem. They are running 2 JL 10s, JL c5 components (6 total speakers) in the front doors and Infinity component (4 speakers) speakers in the back doors
  14. Jun 7, 2019 at 9:16 AM
    Pudge
    CT
    That's what I was thinking. I would not be covering my amp with carpet thats for sure
    Trooper2[QUOTED] likes this.
  15. Jun 7, 2019 at 9:18 AM
    Pudge
    CT
    Heat reducer? I'd think it would just warm up when the amp does and with the carpet over the top you've got no air flow.
    Trooper2 likes this.
  16. Jun 7, 2019 at 9:19 AM
    Trooper2
    JR
    The amps generate heat, the stryofoam will just help retain heat. Quality or not, need ventalation.
    Challenger1 and Pudge[OP] like this.
  17. Jun 7, 2019 at 9:22 AM
    Duneflyer
    Darren
    Yuma AZ
    Regardless what the strofoam does or doesnt do.. 2 years, 30k miles without a problem. so Im sticking to where they are
  18. Jun 7, 2019 at 10:06 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    When my buddy installed in his DC, he did the rear seat fold down mod, and then fastened some carpet covered plywood to the back wall and mounted all his amp and power distro back there in some of the “wasted space”. Living where’s I live in the winter if I have people in my back seat I don’t want water and ice sludge all over my amps if they were under my front seat. When I do my sub the amp will be on the back wall
  19. Jun 7, 2019 at 10:11 AM
    Duneflyer
    Darren
    Yuma AZ
    I was going to so that as well, but decided to go with the JL stealth bo with 10s. There was no room after that.
    kparrow[QUOTED] likes this.
  20. Jun 7, 2019 at 10:37 AM
    Trooper2
    JR
    The amp has a recommended temperature operational range. It would be interesting to get a temp with an IR gun after about an hour of use.
    The carpet covering would be my main concern.
  21. Jun 7, 2019 at 2:37 PM
    tundraal
    tundraal New Member
    What brand amp? Hard to argue with your results...
  22. Jun 7, 2019 at 2:40 PM
    Duneflyer
    Darren
    Yuma AZ
    JL Audio
  23. Jun 22, 2019 at 5:38 AM
    Danny
    Danny New Member
    2018 Tundra Crewmax SR5
    I’d be more concerned with the carpet catching on fire
  24. Sep 12, 2019 at 3:58 PM
    james33440
    james33440 New Member
    James
    2010 Tundra Double Cab
    Magnaflow Exhaust
    any pics?
  25. Sep 12, 2019 at 4:49 PM
    BeachyTundra
    BeachyTundra New Member
    Brandon
    Spokane
    2017 MGM 5.7L DC, Bilstein 5100s
    @DCB500 How does the kicker hideaway do as a sub? This seems to honestly be the perfect option for me without taking up the whole underside of the rear seat in my DC with a box and subs.
  26. Sep 12, 2019 at 5:05 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    Well funny you ask..... it is actually pretty descent and definitely a space saver and does a good job for fill in bass. It doesn’t pick up great on super low end frequency since it’s an 8” woofer but it does add a descent “thump”. I am actually in the process of switching over to separate amp and subs because I do want more of that low end so I will be getting rid of my hideaway if you are interested, just pm me if so.
  27. Sep 12, 2019 at 5:09 PM
    BeachyTundra
    Brandon
    Spokane
    Well damn it....I also want more of the thump. Do you know what you're going to do for sub placement? I'd love to have a 'vertical' box that fits behinds our DC seats, but unfortunately I don't know if you could get the clearance for one.
  28. Sep 12, 2019 at 5:47 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    I ordered a box made to fit under the back seat that fits 2 10’s and then here is the amp and subs that I will be using.
    Kicker comp shallow mount
    Rockford amp that will be 800 watts the way it will be wired.
  29. Sep 12, 2019 at 5:53 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    Literally just got done taking out the hideaway and wiring up the new amp. Now just need the box!
    9B99A1CF-2F44-45C2-93D0-5CD5F659DDCD.jpg 98BFDFCC-8CCB-48D6-BA08-ED5DB4CAB767.jpg
  30. Sep 21, 2020 at 1:03 PM
    Kybosh_ag
    Kybosh_ag New Member
    Adrian
    2008 SR5 DC
    Not enough
    Sorry to revive an old thread, but I also have a JBL system that I'm replacing in steps. I was reading through some of your posts and saw that you were originally thinking about a small 2ch amp for the dash speakers, but that you decided to run them off your headunit, running the corners/sails off the fronts and the center dash off the rears. Are you still running the dash speakers this way? How does it sound? If you changed them, how are they wired now and how is the sound? What corner speakers are you running?
    Currently the only factory JBL piece left is the amp, but I have a 4ch amp (74wx4 @ 2ohms), a mono amp, and two JL 10"s and box waiting to be installed. I already replaced the speakers with ones from Tech12volts (Hertz uno for the doors, JL for all 3 dash), and the HU (Pioneer AVIC-8400).
    James said just to connect all the dash speakers to the front channels of the amp, but I'm not sure how well
    it would handle that. My friend that used to own a car audio shop said the center channel may not sound good since there is no center channel output from the HU, which we already know. He suggested running the dash speakers from the HU. He also suggested maybe splitting up the two center speakers and running one on the left and the other on the right channel, but didn't know if that would sound good. I've also read a little about running it as a mixed mono.
    Just looking for your insight before I order wire kits and pull everything apart.
