Amber DRL LED Swap
Discussion in 'General Tundra Discussion' started by Blackattic83, Nov 8, 2020.
  1. Nov 8, 2020 at 3:59 PM
    Blackattic83
    Blackattic83 [OP] New Member
    2015 Tundra Crewmax Limited
    Looking at swapping the front DRL / Turn signal amber lights to LED. Just wondering if anyone has had any luck with this and if so, brand, style etc... any links to products would be great.
    So far I’ve heard 3157CK Canbus zero error style bulbs are what I’m looking for... can anyone confirm?
  2. Nov 8, 2020 at 5:10 PM
    I use Vleds. The V6 series are very bright. If you get the V6, you will need the hyperflash fix as well. The $30 is for 2 of them to do each side. It would be $155 for the setup but they usually do 20% off for black Friday. Sign up for their newsletter and you will get emails for upcoming sales. I have been using their stuff for almost 9 years now. https://www.vleds.com/shop-application/daytime-running-lights/3157ck/v6-triton-kit-a-3157ck.html
    TXTundra2722 and G10dra like this.
  3. Nov 8, 2020 at 7:19 PM
    Blackattic83
    Thanks. I checked it out... I should have mentioned im from Canada. Little price jump for me lol. But I appreciate it.
  4. Nov 8, 2020 at 8:36 PM
    TXTundra2722
    2015 Black Tundra
    I went vleds as well... the ones that switch from amber with turn signal, back to white as DRLs (switchback). I'd buy again without a doubt.
  5. Dec 29, 2020 at 6:02 PM
    marckicker46
    marckicker46 New Member
    Marc
    I have 2015 Toyota Tundra. I am looking for led switch back plug and play ones that switch from amber with turn signal, back to white as DRLs (switchback). Can anyone guide me right led bulbs and will I need add resistor for each turn signals?
  6. Dec 30, 2020 at 6:15 AM
    TXTundra2722
    2015 Black Tundra
    I use the VLED bulbs for this.... just order their switch back ones and it's simple plug and play
  7. Dec 30, 2020 at 8:11 AM
    marckicker46
    Marc
    TXTundra2722..Do I order just vled bulbs and do I need to puchace other stuff? & what year is your truck?
  8. Dec 30, 2020 at 10:00 AM
    TXTundra2722
    2015 Black Tundra
    Sorry.... this might be helpful for you huh? Mine is a 2015. I purchased the bulb only (switch back) from vled and didn't need anything else. I ran this in the stock housing. I'm currently running Recon headlights, but I transferred the switch backs into this housing as well without any issues.
  9. Dec 30, 2020 at 10:26 AM
    marckicker46
    Marc
    Thank you for your help. I been buying different led switch back and no luck
  10. Dec 30, 2020 at 10:30 AM
    marckicker46
    Marc
    You had no issue with hyber fast flash when turn signals ? No resistor need
  11. Dec 30, 2020 at 5:59 PM
    TXTundra2722
    2015 Black Tundra
    VLED recommends with their products whether it's needed or not and i didn't need any since I'm not running LEDs in the rear as well. If I had LEDs in the rear then I'll definitely need to add a resistor. What year is your truck?
  12. Dec 30, 2020 at 6:05 PM
    marckicker46
    Marc
    My is same year is your 2015. I place order since they are having 20% discount till Jan. 04,2021. Thank you for your help
    TXTundra2722 likes this.
  13. Dec 31, 2020 at 6:52 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Second the vleds. I love mine.
