Amber DRL Fuse location
Discussion in '2.5 Gen Tundras (2014-2021)' started by Xone42, Feb 4, 2019.
  1. Feb 4, 2019 at 8:23 PM
    Xone42
    Xone42 [OP] New Member
    Looking for some help on this one. I did the led light conversion on my 2016 trd pro to 2019 trd pro led headlight assemblies. I got the harness from ihacker, install went good. However i can’t get the grey wire on the flasher plug J29 to recieve a signal from the ecu to ground out the relay to enable my amber DRL’s and the Bright mode on the LED DRL’s. I think there should be a fuse for the amber DRL’s on my truck. It’s a Canadian trd pro if that helps. The parking brake is not on, so that micro switch is not my problem. I have looked at both fuse panels and no luck. Is there another fuse panel somewhere in the 2014+ tundras? Any help would be appreciated, ihacker has also been trying to troubleshoot as well. We are both stumped on this one.
  2. Feb 5, 2019 at 3:30 PM
    Xone42
    Figured it out, case closed.
    831Tun likes this.
  3. Feb 5, 2019 at 3:34 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Details?
  4. Feb 5, 2019 at 3:38 PM
    Xone42
    Tail fuse in the fuse box inside takes care of parking lights.
    831Tun likes this.
