Alignment after off-roading?
Discussion in 'General Tundra Discussion' started by tongsiup, Feb 23, 2019.
  1. Feb 23, 2019 at 11:30 AM
    tongsiup
    tongsiup [OP] New Member
    Do u guys do alignment after off-road? My tundra pulled to the right after off-road at Anna-Borrego last weekend.
  2. Feb 23, 2019 at 11:39 AM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    I usually do. After my last 2 trips the steering wheel has been off center while driving home. I would align your truck to prevent premature and abnormal tire wear.
    jc153 and OR18TRD like this.
  3. Feb 23, 2019 at 11:43 AM
    tongsiup
    How much you doing the alignment? If doing the alignment every time after alignment, that will be a lot of money.
  4. Feb 23, 2019 at 11:48 AM
    TacoWuzzaTurd
    TacoWuzzaTurd Loving my Tundra
    Scottsdale AZ
    2018 SR5 4x4 Crewmax, TRD Offroad
    6112s @1.9", TRD Dual Exhaust, rims, tires, jl audio system
    Could look into the lifetime alignment program at Firestone. I'm not an expert but I think you want to make sure they are aligning it correctly if you have it lifted or larger tires I don't think you want them just aligning to factory specs. I'd just make sure they have someone on staff with experience and confidence in aligning lifted/modified vehicles. Not just punching your VIN into a computer and matching up numbers. However I dont know much about alignments so maybe that isnt an issue at all. I just seem to recall reading about that in the past. If you can find a good Firestone place sometimes you can get that lifetime alignment on special for less than $180.... then you have unlimited alignments.
  5. Feb 23, 2019 at 11:49 AM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    There are shops that offer lifetime alignment. They charge about $200 upfront but you'll get unlimited alignment as long you own the vehicle (not transferable).
    TheBeast likes this.
  6. Feb 23, 2019 at 11:50 AM
    tongsiup
    $60 not bad. I asked some shop. $60 they just doing the toe.
  7. Feb 23, 2019 at 11:51 AM
    TacoWuzzaTurd
    Scottsdale AZ
    They probably need to look at more than just the toe? Camber, caster, etc?
    Rica25 likes this.
  8. Feb 23, 2019 at 11:52 AM
    TacoWuzzaTurd
    Scottsdale AZ
  9. Feb 23, 2019 at 11:52 AM
    tongsiup
    Yes, that what I thought. They said need to charge more for the camber and caster
    Rica25 likes this.
  10. Feb 23, 2019 at 11:55 AM
    Porschetech29
    Francis
    I’m lucky that I can do it myself at work
    TheBeast and TacoWuzzaTurd like this.
  11. Feb 23, 2019 at 11:56 AM
    tongsiup
    Yes, I know there are offer lifetime alignment. But I think they have time limit, like you have to wait 3 or 6 months then you can come back to do another alignment.
  12. Feb 23, 2019 at 11:58 AM
    TacoWuzzaTurd
    Scottsdale AZ
    Ah that could be. Definitely read through the terms and conditions. They may also have a disclaimer that says if you take the vehicle offroad, they charge extra or wont allow the lifetime alignment. Definitely need to ask the questions.
    What are you doing each time you offroad that you're throwing your alignment out of whack? I guess I'm a pretty tame offroader...
  13. Feb 23, 2019 at 12:01 PM
    tongsiup
    I just hit a rock when running on a fire road.
  14. Feb 25, 2019 at 9:25 AM
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    You should also check your cam tabs to see if they bent. Total Chaos makes replacement ones that weld on in place of the thin stock ones.
  15. Feb 25, 2019 at 9:37 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    My Goodyear Store (light maintenance/tire store) here in CO offers 6 alignments for $120...
    Sunnier likes this.
