Alarm when I hit the gas
Discussion in '2.5 Gen Tundras (2014-2021)' started by BrownboiPuyallup, Jul 12, 2022.
  1. Jul 12, 2022 at 12:03 PM
    BrownboiPuyallup
    BrownboiPuyallup [OP] New Member
    Dude
    2018 Tundra
    Hello all! Glad to be here a part of this awesome platform.
    I have a 2018 Tundra. There's an alert that comes on when I step on the gas. At first the screened displayed a "turn off... something but it hasn't came back on since and the alarm is only going off when I accelerate. Any ideas as to what it may be. I got a recall notice on the electrical wiring of the headlights. Could it be related?
    What say you?
  2. Jul 12, 2022 at 12:07 PM
    Teebo502
    Teebo502 TUNDRA LIFE
    Teebo
    Louisville, KY
    2020 White Tundra CM TSS
    Chrome Delete, OEM TRD Pro Exhaust, Red Leather Seats, OEM TRD Pro Led Headlights, Steering Wheel Mod, Window Tint, Bed cover, 2" Front Level, REXING V1P Pro Dash Cam.
    Welcome to the forum!!! No, I don't think the headlight recall has anything to do with the alarm/alert. I personally never seen, or heard of an alert like that. Maybe something that is aftermarket that is installed on your truck.
  3. Jul 12, 2022 at 12:12 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Parking brake released?
    Joe333x, EDDO and Taco-Spike like this.
  4. Jul 12, 2022 at 1:28 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    This may seem random, but check your oil level? I believe there is an alarm if your oil level or pressure drops below a certain point and engine load will cause changes.
  5. Jul 12, 2022 at 1:36 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Engine speed, not load; oil pressure goes up with engine speed.:)
  6. Jul 12, 2022 at 1:37 PM
    18" TRD Off Road Wheels
    If you're gassing it hard it might be the traction control or VSC. I've done that when peeling out. :burnrubber:
    iamkeith and Retired...finally like this.
  7. Jul 12, 2022 at 1:59 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    And to add to that, incorrect or uneven tire pressure can make it much more sensitive, even if it’s not out enough to turn the tire pressure warning on. And that’s assuming there aren’t mixed tires on the truck.
  8. Jul 12, 2022 at 5:55 PM
    mountainpete
    You’re correct. Wrong word used.
  9. Jul 12, 2022 at 6:13 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Read the troulbe codes just to make sure their are none. Do you remember what the picture on the warning message looked like?
  10. Jul 12, 2022 at 6:33 PM
    Welcome from NY.
  11. Jul 12, 2022 at 8:00 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I vote for parking brake since it will beep and alert you if you try to drive off with it on
    GODZILLA likes this.
  12. Jul 13, 2022 at 6:53 AM
    BrownboiPuyallup
    Dude
    2018 Tundra
    Thanks you guys for the warm welcome. Initially my aunt had called me about the issue, in regards to the alarm sound when accelerating. I was dropping someone off at the airport and I had lend her my truck to go to the store. She tried releasing the "E" brake by pulling on the "hood" handle and popped the hood open. The hood sensor was alerting her that the hood was open and the car was unsafe to drive. I only realized that, that was what it was, when I seen the hood cracked open when I came home. I've never heard of such a thing on a car but I'm glad my Tundra has that feature. Mystery solved. Hope this helps others with the same concern.
    equin, Leo's first, bulldog93 and 8 others like this.
  13. Jul 13, 2022 at 6:56 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    I think the hood open sensor was added in 2018. Now that you mention it I could see how someone could accidentally pull it and open the hood while thinking they are disabling the parking brake.
    Good to know you got it fixed.
  14. Jul 13, 2022 at 6:56 AM
    All's well that ends well. Glad you found it. Now you can get around to browsing for the mods that will surely drain your children's college funds. :D
    texasrho83 likes this.
  15. Jul 13, 2022 at 7:03 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I NEVER would've thought that, especially as I didn't know that there was a hood sensor.
  16. Jul 13, 2022 at 7:57 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! This needs to be posted in "Things Your Tundra Does That You Didn't Know About"!
    GODZILLA and Wynnded like this.
  17. Jul 13, 2022 at 12:49 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    So same time as OEM remote start, right? The two go together like peas and carrots.
    And ditto.
  18. Jul 13, 2022 at 6:59 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Im not sure about the remote start but I could believe it started becoming standard in 2018. It was definitely an option prior too. When I bought my 2007 last year I ran the vin on Toyota Owners. It said it had factory remote start. I asked the seller and he said no it doesn’t have that. I bought it, drove across town to have lunch with a friend. Parked, got out, hit the lock button twice and then held it. Truck beeped and started right up. I just laughed and said cool!
  19. Jul 13, 2022 at 7:12 PM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    Glad I'm not the only one!
    First road trip we took in our 4Runner I did that. We took the ferry to Port Aransas, and set the P brake for the float across the channel. Got to the other side and promptly popped the hood trying to release the brake. :facepalm: Properly released the brake once I figured it out (high tech stuff!), then pulled aside once clear of the ferry to do the walk of shame and close the hood.
  20. Jul 13, 2022 at 8:08 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    I do it several times a week. The ford is a pull and the tundra a push harder. Most of the time I pop the hood on the tundra and apply the brake harder on the ford. Infuriates me as almost all the previous trucks were push harder to release the brake.
  21. Jul 16, 2022 at 5:30 AM
    don3032
    don3032 New Member
    don
    2021 Tundra Limited Crewmax Nightshade
    debadged, diamondback, window tint, dirty deeds exhaust.
    It is a Tundra, it could be the low fuel light every time we step on the gas, lol.
  22. Jul 16, 2022 at 5:33 AM
    Sounds like the Tundra is more fun than the Ford. "Harder! Deeper!" vs "Pull it out!" I mean, which one would you rather spend time with?
