Air injection pump question
Discussion in '2nd Gen Tundras (2007-2013)' started by BigBarney, Aug 1, 2016.
  1. Aug 1, 2016 at 10:48 PM
    BigBarney
    BigBarney [OP] New Member
    Dustin
    2011 Tundra Rock Wariorr
    So, I have a 2011, and reading everyone's problems with these pumps and the quotes from the dealership is starting to scare me. I am curious if there is something I can put on the end of the trumpets to avoid this from happening!
  2. Aug 1, 2016 at 10:54 PM
    David2013Tundra
    David2013Tundra New Member
    David
    2013 Tundra DC 5.7
  3. Aug 2, 2016 at 6:01 AM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    How many miles on your 2011? I also have a 2011 and my first one went out around 105k-108k. There is an upgraded air inlet tube (aka: trumpet) that you can swap out, as far as something to put over it, maybe some molded fiberglass to keep water out but with space to let air in.
  4. Aug 2, 2016 at 6:01 AM
    Nor7
    FYI: I just recently posted a thread about this, look at the DIY section, should be near the bottom of the list, you'll see a picture with the new trumpet.
  5. Aug 2, 2016 at 7:22 AM
    Nor7
    Here it is.
    matluth likes this.
  6. Aug 2, 2016 at 3:44 PM
    BigBarney
    Dustin
    I'm sorry, I have looked high and low for the article in the DIY section. Can you link it??
  7. Aug 2, 2016 at 7:03 PM
    Nor7
  8. Aug 2, 2016 at 7:14 PM
    Nor7
    Here's the Chilton Repair Manuals I used.
  9. Jul 26, 2017 at 5:00 PM
    abriels
    abriels New Member
    I have a 2011 Tundra with 133,000 miles. I just received an Toyota recall extending the warranty for this issue to the 2011’s and 10 years 150,000k miles... if you haven’t received it in the mail, call and verify!
    JTP, Wynnded and 15whtrd like this.
