Aftermarket seats with SRS light?
Discussion in 'General Tundra Discussion' started by djt3999, May 14, 2022.
  1. May 14, 2022 at 4:44 AM
    djt3999
    djt3999 [OP] New Member
    My 08 SR5 Crewmax driver's seat is trashed. I'm considering getting the Corbeau Sport Seats but concerned about what will happen with the SRS system/light since obviously there will be an unhooked connector for the OEM seat airbag.
    Has anyone run into this problem yet? Thanks.
  2. May 14, 2022 at 8:22 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Guessing you will lose functionality of that system and probably get an warning light or error on the dash. You can have an upholstery shop rebuild your driver seat, did that with my 4runner. And search, there may still be toyota cushions available to purchase, which could be cheaper than a shop rebuild.
  3. May 21, 2022 at 7:49 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Do some research on resistors to “clone” the airbag signal. I know in wheelchair/handicapped vehicles they remove the under dash knee airbag and put in a resistor to make the ecu still think it is present.
    I am sure you can do something similar with the side airbag in the seats. Just fool the system into thinking everything is normal.
    Might be able to measure the resistance of your seat airbag with a multimeter, grab a resistor to match and test it. Risky though so be careful and make sure you know what you are doing.
    I would wire in the seat belt switch to the new seats also
