Aftermarket headlights
Discussion in '2nd Gen Tundras (2007-2013)' started by bthompson12, Mar 31, 2019.
  1. Mar 31, 2019 at 12:26 PM
    bthompson12
    bthompson12 [OP] New Member
    Bruce
    AL/WI
    2012 Nautical Blue Tundra 5.7L 4x4 DC
    Looking to see some images of the eBay specials. My oem headlights are getting foggy and I’d rather just replace them then try and clean them up. I’ve seen a few on eBay I like but not sure the quality. Main thing I see is the bulbs that come with the kits are trash and usually have to be replaced. Show me what you got
    Thanks,
    Bruce
  2. Mar 31, 2019 at 12:39 PM
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    X2
  3. Apr 4, 2019 at 9:09 PM
    bthompson12
    Bruce
    AL/WI
    Wow...nothing at all
  4. Apr 4, 2019 at 9:17 PM
    Trooper2
    Trooper2 Premium Lone Star Member
    (Southern Suburban) Houston, TX
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Hankook Dynapro ATs, N Fab 3 Hoop Nerf Bars, TRD Wheel Locks, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Had good results with Mcguire' s Heavy duty headlight restore kit. Hearing if ready for replacement, best go OEM than Aftermarket,
    sf319 likes this.
  5. Apr 4, 2019 at 11:09 PM
    sf319
    sf319 On to the next chapter of Tundra ownership....
    Utah
    Now 2014 CM Barcelona Red SR5 5.7, was 2007 White DCSB SR5 5.7
    Dash Cam (1st Mod)
    So I have tried the restore kits, it works for a month or two. I park in the garage too. I then went the after market route, and realized they are all crap. The set I got looked cool was supposed to be Spyder, but when I installed them the low beam was aimed too high. Tried adjusting but wouldn't go any lower, it would go slightly higher. I looked at a bunch of different models, but none had good enough reviews. I ended up just getting new replacements from @Roman at Cool Springs Toyota, they are expensive but so are the good after market ones with so so reviews. There are a lot of people on here that like their after market lights. I think I just got a bad pair, but I wasn't the only one according to reviews I read. Be prepared to return them, so verify the sellers return policy. I didn't and now have a bad set of lights sitting in my garage.
    Roman likes this.
  6. Apr 5, 2019 at 1:47 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    If you clean them up you need to clear coat them or they will fog back to how they were in a couple months....I’d stay away from any aftermarket lights other than depo oem replacements.
    sf319 likes this.
  7. Apr 5, 2019 at 4:42 AM
    86toy2011
    86toy2011 New Member
    Honestly the headlight restore kits are snake oil. Just wet sand your headlights, polish them and then clear coat them. Or buy new OEM.
    Stormtrooper81 and sf319 like this.
  8. Apr 5, 2019 at 4:51 AM
    Mnorris1206
    08 tundra
  9. Apr 5, 2019 at 4:54 AM
    Mnorris1206
    08 tundra
    I also really like this idea and your blue would look cool this way also. Stock head lights painted color match inside .Screenshot_2019-01-14-21-10-06.jpg
    2ndgenny likes this.
  10. Apr 5, 2019 at 5:36 AM
    Jrharvey02
    Jrharvey02 Meh.
    Skyland Village, Colorado
    2010 Tundra CM 5.7FFV Platinum Dark Black
    A.R.E. Topper, Clifford Remote Start/Alarm, Pioneer Avic8200-NEX Entertainment System, Passport 9500ix Radar Detector, Compustar Dash Front and Rear View Cameras, ADVX Rear view mirror camera, front grille camera, JL Audio 10” sub, Focal 6.5”, Thule Rack Mounts & Rocky Mounts Basket, Dual Batteries, Bedrug Bedliner, LED Bed Lights, TRD Sport Shocks, TRD rear sway bar. Custom Fitted Denver Outfitters Fly Rod Vault, BreezeGuard rear pet screens, DTMoto Headlights, color-matched aftermarket grille
  11. Apr 5, 2019 at 5:39 AM
    timsp8
    timsp8 Member
    NY
    2018 Tundra Limited Crewmax
    Just remember, with most aftermarket headlights you will loose the ability to adjust them from inside the cab. I tried to swap the motors to new ones with my 2010 and it didn’t work. Gave up and replaced with oem and did the bhlm.
    sf319 likes this.
  12. Apr 5, 2019 at 11:56 AM
    Punisher17
    Punisher17 New Member
    https://www.ebay.com/itm/For-Black-...Tundra&hash=item58f800ed11:g:PWYAAOSwor1aXrAM
    I have the headlights from this kit and they are adjustable. The tail lights I threw away because the LEDs stopped working in just a few months and put on stock replacements from Ebay. The headlights are pretty good imo never have leaked or anything.
    Added these eyelids from Ebay also
    https://www.ebay.com/itm/Made-to-fi...779201?hash=item3ac8409681:g:d24AAMXQvTlRgzmk
    I'd go Spyder if I could do it all over. I do have Spyder stock fog kit though.
  13. Apr 5, 2019 at 12:01 PM
    BTBAKER
    BTBAKER ..........
    Brad
    Castle Rock
    2017 Tundra Limited
    My motors slipped right on my Spyders and they work great.
    TundraDude4x4 likes this.
  14. Apr 5, 2019 at 12:07 PM
    Swampcreek
    Swampcreek New Member
    I've done many fogged headlights with buffing compound and a professional ROTARY buffer (I'm a boat owner so such equipment is essential), it takes only a few minutes but you have to be careful not to rub the paint off of surrounding areas (Did that once too). I'll bet you could stop by any mom & pop body shop on a slower day or around lunch time and they'd do it right on the spot for $20 or so...doesn't hurt to ask!
  15. Apr 5, 2019 at 1:23 PM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    matrdguy, Mnorris1206 and 08crewmax like this.
  16. Apr 6, 2019 at 7:58 AM
    bthompson12
    Bruce
    AL/WI
    See I do like these. Any problems with them? I would replace the bulbs with led’s up front immediately
  17. Apr 6, 2019 at 7:59 AM
    bthompson12
    Bruce
    AL/WI
    What do you guys mean by they are adjustable or not adjustable? I don’t believe I’ve ever adjusted my lights?
  18. Apr 6, 2019 at 7:59 AM
    bthompson12
    Bruce
    AL/WI
    Jrharvey02 likes this.
  19. Apr 6, 2019 at 8:03 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Be careful w/the eBay headlights/tail lights. The vast majority of them are just Chinese junk. Spyders are hit and miss. I've never had any luck w/them. Winjets are junk, but some people have had luck w/Autosaver (I think that's the name) if you can find them. Most of us have just upgraded to the 2018 Toyota LED headlights or are waiting on the Morimoto headlights to come out.
    sf319 and 2ndgenny like this.
  20. Apr 6, 2019 at 8:03 AM
    2ndgenny
    2ndgenny A surge of truck truck mods :)
    Hinton Alberta, Canada
    Oh8 Limited DC Bush Beater!
    OME 3.5” 613’s & Dakar leafs, SPC UCA’s Daystar bag cups and bags. Arb bumper/2” rigid led fogs. Debadged. Smoked tailights/3rdbrake. Magnaflow catback. aFe Magnum stage 2 intake. Official Dirty Seven Club Member!
    I just want to be able to afford 2019 Sequoia headlight conversion :(
    sf319 likes this.
  21. Apr 6, 2019 at 8:04 AM
    2ndgenny
    There’s morimoto headlights coming out for us!?
  22. Apr 6, 2019 at 8:04 AM
    Jrharvey02
    Jrharvey02 Meh.
    Solid so far. They are take offs from another member who went with sequoia upgrade. So between him and me they’ve got a solid year + of use and everything is great. I was super skeptical too but hey, for less than $200, it was worth a shot. They are dry, leveled and made the truck look way newer. I’ll never be giving up my stock headlights tho...just in case
  23. Apr 6, 2019 at 8:05 AM
    Sas
    OKC, OK
    Yeah, they're pretty bad ass looking IMO too. If I hadn't already upgraded I'd be all over it. There are a couple of threads floating around the forums.
  24. Apr 6, 2019 at 8:06 AM
    2ndgenny
    Prove it haha. I want to see the light!
  25. Apr 6, 2019 at 8:08 AM
    Sas
    OKC, OK
    Your search functions works just the same as mine. :p
    BTBAKER and 2ndgenny like this.
  26. Apr 6, 2019 at 8:09 AM
    2ndgenny
    All I’m finding is custom builds. Ah well. It’s all fluff until they’re released anyway I suppose
  27. Apr 6, 2019 at 8:11 AM
    Sas
    OKC, OK
  28. Apr 6, 2019 at 8:15 AM
    2ndgenny
  29. Apr 6, 2019 at 8:17 AM
    Sas
    OKC, OK
    Ahhh, my bad! I didn't see that this was posted in the 2nd gen forum. Sorry for getting your hopes up!
  30. Apr 6, 2019 at 8:18 AM
    apwisher
    apwisher New Member
    Everett, WA
    I haven’t had any issues with them at all. The build quality is good. The only pain is getting them leveled on the gen 2, as the vertical adjuster is very hard to get to. I had to pull the lights to adjust, rinse, repeat to get it. But that is pretty easy. I’m going to run them until a bulb burns out then decide if I want to upgrade the bulbs. So far the output seems about on par with stock. High beams are better though. I’ll probably put some piaa bulbs in before LED but that is just my preference.
