Aftermarket airbags
Discussion in '3rd Gen Tundras (2022+)' started by Stimleck, Mar 7, 2023.
  1. Mar 7, 2023 at 7:00 PM
    Stimleck
    Stimleck [OP] New Member
    Hi folks has anyone found a rear airbag kit for these 22 tundras?
    I bought the timbren rubber springs but they're awful
  2. Mar 8, 2023 at 6:34 AM
    Bogus6
    Bogus6 New Member
    2022 Tundra TRD Pro, Solar Octane
    Yokohama Geolander MT 35x12.5x18
    ryanwgregg and AZ_First_Gen like this.
  3. Mar 8, 2023 at 9:47 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    What did you dislike about the Timbrens? I have some and find them and bit jarring when they make contact with the axle. I am waiting on the next trip with the trailer to see how they feel under load.
  4. Mar 8, 2023 at 9:56 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Dont mind me, Im just posting this from my AVS/Load leveling equipped truck :)
    j-utah likes this.
  5. Mar 8, 2023 at 11:43 AM
    AZ_First_Gen
    AZ_First_Gen New Member
    AZ
    2022 TRD OR Ltd Crewmax
    Yakima Overhaul rack, Retrax One XR Tonneau, Bed step, Air Lift Load Lifter 5000 with wireless compressor
    I bought the Air Lift Load Lifter 5000 for my 2022 Ltd TRD OR and they have been very good, install took about 3 hours. Almost the same ones from the video above, but not the Ultimate. Towed 200 miles last weekend with a hitch heavy (800 lbs) toy hauler that weighed in around 5000 lbs. It felt more stable than previous towing experiences and reduced the sag almost to nothing. I'm debating on adding in the compressor but I have a VIAIR compressor that hooks up quick and the bags retain the pressure pretty well.
  6. Mar 8, 2023 at 11:52 AM
    Stimleck
    . Underload they feel very stable, I used them with a snowmobile in the bed and separately while towing a trailer and the stability was great. Unloaded however its unbearable, the slightest bump or dip causes them to slam like hitting bump stops. My 1794 has about an inch of clearance unloaded so they almost always contact the rubber. They do not have any progression in their stability which is badly needed. The plant is in my town so I had the engineer look at them and he swapped to softer rubbers, same issue just to a lower degree. I told him they should be used in all kits over the harder ones. I'm buying the air ride 5000 today and Im thankful for this video link
  7. Mar 8, 2023 at 1:08 PM
    cvd2312
    cvd2312 New Member
    2023 CrewMax SR5 TRD OR
    Are you using a WDH with this setup as well?
    AZ_First_Gen[QUOTED] likes this.
  8. Mar 8, 2023 at 3:18 PM
    AZ_First_Gen
    AZ
    Yes, I have an Andersen WDH. Both of them together helps with moving the weight off of the rear axle and keeping things stable.
  9. Mar 9, 2023 at 10:07 AM
    Coasty
    Coasty New Member
    Pat
    Oregon
    2022 SRS Crew Max 6.5 4x4
    I ordered the Air Lift setup in the video and they are on back order everywhere so anticipate a weight (get it?)...
  10. Mar 9, 2023 at 1:56 PM
    AZ_First_Gen
    AZ
    I "weighted" 8 weeks when I ordered mine in December and decided to cancel the order because of some questionable interactions with the company. I was told the item was out of stock but it would only be 3-4 weeks, however, for an additional $75 they could get a "partner" company to ship them to me. Kept checking in every two weeks and got the same "partner company" offer two more times before I cancelled the order and had to pester them for a few days to refund the credit card. I ended up paying a higher price than the "partner" offer, but they were in stock and I had them in five days.
  11. May 29, 2024 at 6:11 AM
    Sacul
    Sacul New Member
    2024 Tundra Limited TRD
    Nothing yet
    Has anyone tried summo springs? They look like they might be better than bags and timbren imo
    let me know if so!
