Advice on Undercarriage Rust
Discussion in 'General Tundra Discussion' started by vatundra, Jan 19, 2020.
  1. Jan 19, 2020 at 10:08 AM
    vatundra
    vatundra [OP] New Member
    ***Undercarriage rust question***
    Hey all, I currently have an 07’ 4.7 2wd that served it’s purpose this summer/fall. Found an 07’ 5.7 4x4 for $10k that I was planning to pick up tomorrow. Seller just sent me these pics that I hadn’t seen before. Said the rust is from the previous owner backing his boat into the water (aka not cleaning AFTER backing the boat into the water). Some of the areas look worse than others (pic 3), just wanted some opinions from folks who may know these trucks better than I do. Thanks!
  2. Jan 19, 2020 at 10:09 AM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    Doesn’t seem abnormal for a truck of that age. You could coat it with fluid film if you wanted to and that should keep it from getting worse.
  3. Jan 19, 2020 at 12:28 PM
    Spaceiscool
    Spaceiscool Something something.. danger zone?
    JL
    Ontario
    2008 White Tundra CM TRD
    Spray painted rims
    That doesnt look bad at all. Oil it up and it will be looking new again.
