Advice for lift kit with aftermarket bumper
Discussion in 'Suspension' started by badsector, Oct 11, 2016.
  1. Oct 11, 2016 at 7:06 AM
    badsector
    badsector [OP] New Member
    Richmond, VA
    2010 Black Rock Warrior DC
    Expedition One Front Bumper w/Warn 10-S winch TRD Dual Exhaust ARE CX Camper Shell OME 613 Full suspension kit with Dakar rear springs.
    Looking for advice on lift kits for my 2010 Tundra (DC RW 5.7 4x4). I just ordered a Expedition One rangemax front bumper which is advertised to weigh about 150lbs before adding a winch. I'm bouncing back and forth between the following kits:
    1. OME 613 - Reading alot of recommendations on this kit for 5.7 + heavy bumper setups but also alot of negative comments about it being overly firm/stiff. I'm actually leaning toward this option including the dakar leaf springs in the rear.
    2. ToyTecLifts BOSS kit - I'm seeing more mentions of a more comfortable ride with this setup but worry about the bumper weight negating the kits lift.
    3. Bilstein 6112/5160's + shackles - This one also looks very appealing, but again not sure how much lift I'm going to loose on this kit with a heavy bumper/winch.
    I'm looking for a small lift in the 2.5-3 in range for the front and enough in the back to keep a 1-2" rake, I plan to keep my factory wheel/tire size (285/70r17 Rock Warrior). I can handle a little more stiffness over stock, but I'd prefer not to hear things rattling out of my dash constantly on poorly kept roads/highways. I also worry that the 2.5 front options might drop to 1.5 or 1 inch after a heavy bumper install. In the back, I have an ARE camper shell, roof top tent, and when camping have a decent amount of gear/weight in the bed of truck (500-800lbs maybe including the shell/tent). I'm not looking for a desert racer setup... I adhere to the "As slow as possible, As fast as necessary" style of off roading.
    I'm open to other suggestions... my budget is around $1500... I could go up to 2k if the value is there (ICON stage 2?) but I'm a best bang for the buck guy more so then quality at any price. I want to keep the stock UCA's to save money if at all possible.
    T-Rex266 likes this.
  2. Oct 11, 2016 at 7:17 AM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    Just to mention about the OME setup... I've got it on my Tundra with my 135lb bumper, no winch right now. Way too stiff IMO with the 135lbs, I'm about to switch the front out for some King coilovers that the wife got me for my Bday a couple weeks ago. The OME will be coming off and has about 12-15k miles on it if a used set interests you at all, might be better with a winch added. I have a solid 3" of lift, maybe a touch more with the setup.
    For the rear look at some coachbuilder extended length shackles and some longer shocks to match
    Edit: Actually I believe my OME are the 614
  3. Oct 11, 2016 at 7:31 AM
    chphilo
    chphilo Tundra addict
    Western PA
    OME is an excellent option for heavy bumper. But with a 150 lb bumper, you may consider 614 instead of 613. I've seen guys with 250 lb bumpers with 613 and they say they are happy with their choice.
  4. Oct 11, 2016 at 7:47 AM
    badsector
    Richmond, VA
    Looks like the winch cable choice can make a difference there... steel cable winches seem to run about 100lbs vs 60-70ish for synthetic. If I get a steel cable.. then I'd be pushing up around 250lbs.
  5. Oct 11, 2016 at 7:49 AM
  6. Oct 11, 2016 at 9:13 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I agree with everything these guys say. But also consider the BOSS is adjustable, so if you lose more height than you want? You can always adjust the shocks to where you want them. Plus they come in 650 and 700 lb options. Just my 2 cents.
  7. Oct 11, 2016 at 11:00 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4 x 4
    Toytec -Duratrac -Expedition One-Fab Fours
    I have a Gen 3 not Gen 2 but... I am running Toytec with the heavy Springs and an Expo One with winch. Almost too soft for my taste. I am set at 2 inches with no lift out back. Toytec was great to deal with.
  8. Oct 11, 2016 at 11:20 AM
    badsector
    Richmond, VA
    Do you have a thread or pics of your truck.. would love to see the stance with your toytec settings.
  9. Oct 11, 2016 at 11:36 AM
    Over the LINE
    New Orleans
    Here it is before tires. I changed to a PRO skid plate and went with 295/65/18 Duratracs.
  10. Oct 11, 2016 at 11:42 AM
    badsector
    Richmond, VA
    That looks great
    That looks great... that's just about what I'm looking for, maybe just a smidgen higher. It's hard to tell from the angle... is your winch running synthetic line?
  11. Oct 11, 2016 at 12:08 PM
    Over the LINE
    New Orleans
    It is synthetic. I used a Smittybuilt winch. Not really set up for foot forward but it worked. I relocated the control box to under my hood. Here is my build thread with a few pictures.
    https://www.tundras.com/threads/over-the-line-2016-cm-4-x-4-build.5884/
