Adding tow package for light towing?
Discussion in 'Towing & Hauling' started by Stupidis, Feb 10, 2019.
  1. Feb 10, 2019 at 2:38 PM
    Stupidis
    Stupidis [OP] New Member
    Bret
    2015 silver 4.6
    None
    Okay, recently bought a 2015 Tundra, and I’m curious to know if I can add a tow package strictly for light towing. It has the smaller engine and I don’t want to take chances. Love the truck
    Stormtrooper81 and Pinay like this.
  2. Feb 10, 2019 at 2:41 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Does it not come with a hitch? Even the smaller v8 can tow plenty
    Stormtrooper81 and jeremyd like this.
  3. Feb 10, 2019 at 2:42 PM
    Stupidis
    Bret
    2015 silver 4.6
    None
    No, I couldn’t afford the extra expense. Hoping to find an after market solution on my limited budget
  4. Feb 10, 2019 at 2:42 PM
    Welcome from Texas
  5. Feb 10, 2019 at 2:45 PM
    LML 3500HD
    etrailers.com
    Hitch and brake controller is what you need.
  6. Feb 10, 2019 at 2:48 PM
    Stupidis
    Bret
    2015 silver 4.6
    None
    Even for light and lightly loaded trailer? Brake controller I mean, the hitch I can do. I am more worried about the transmission without the tow/haul button
    Pinay likes this.
  7. Feb 10, 2019 at 2:55 PM
    LML 3500HD
    depends on what you consider light. 3000 lbs or less doesn't require a braking axle in most states. What kind of connector on the trailer?
  8. Feb 10, 2019 at 2:55 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Does your truck come with the option to turn off overdrive? If so, I’d keep overdrive off when towing to keep the trans heat at bay, or at least that’s what we used to do in the olden days.
    Pinay likes this.
  9. Feb 10, 2019 at 2:57 PM
    Stupidis
    Bret
    2015 silver 4.6
    None
    Oh and while I’m advertising my stupidity, the truck came with the hands free technology however it doesn’t work correctly with an iPhone 8 it appears to only be compatible up to the iPhone 5. Is there software update for this?
    Pinay likes this.
  10. Feb 10, 2019 at 3:01 PM
    Stupidis
    Bret
    2015 silver 4.6
    None
    Trailer in question is single axle, entirely aluminum mainly used for hauling atv or lawnmower. Probably less than 1500 lbs fully loaded. Also has no overdrive
    Pinay likes this.
  11. Feb 10, 2019 at 3:04 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiya and welcome from SoCalif!!!
  12. Feb 10, 2019 at 3:09 PM
    LML 3500HD
    So you just need the 4 prong wiring kit.
    You have overdrive. Is your gear selection shifter on the console or steering column?
  13. Feb 10, 2019 at 3:13 PM
    Stupidis
    Bret
    2015 silver 4.6
    None
    Steering column, and it has the automatic or standard option. Last truck I owned was an 80 model ford straight 6 300 4 in the floor. Haven’t a clue how to make this new standard mode work for me
  14. Feb 10, 2019 at 3:15 PM
    LML 3500HD
    There should be a button on the end of the shifter on/off for the OD.
    Stormtrooper81 likes this.
  15. Feb 10, 2019 at 3:17 PM
    Stupidis
    Bret
    2015 silver 4.6
    None
    Sorry, not on this model, I’m going through the manual now to see if I can locate it
    ColoradoTJ likes this.
  16. Feb 10, 2019 at 3:27 PM
    ninjajay
    Spoolston, TX
    I think that's within the capacity of a Camry. You'll be fine with just adding a hitch.
    BKVR6, Stormtrooper81 and ColoradoTJ like this.
  17. Feb 10, 2019 at 4:00 PM
    Stormtrooper81
    Stormtrooper81 Slow and steady
    Lost coast
    2011 DC
    X2
  18. Feb 10, 2019 at 4:10 PM
    Stupidis
    Bret
    2015 silver 4.6
    None
    Thanks experience and wisdom, I have been enlightened.
  19. Feb 10, 2019 at 4:41 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Yup, both 5th and 6th gears of the 6spd autos are overdrive. 4th is direct.
    Even though it’s a lightweight trailer, I’d avoid pulling any grades in 5th or 6th since you don’t have an additional transmission cooler or lock-up torque convertor and you don’t want an overheated transmission. But add a hitch and wiring for trailer lights and you’ll be set. You should barely feel that behind you.
  20. Feb 10, 2019 at 4:43 PM
    Stupidis
    Bret
    2015 silver 4.6
    None
    Thanks, it’s for short trips only, mostly below 45mph speed limits, shouldn’t be a problem.
    landphil likes this.
  21. Feb 16, 2019 at 2:37 PM
    Rubberdown
    Do the new grade models not have the 4 pin flat there up under the bumper like the 2013 and earliers do? That’s crazy.
  22. Feb 17, 2019 at 3:31 PM
    salmonator
    salmonator New Member
    Tigard, OR
    2019 Tundra SR5 4x4 DC
    They have a flat 4 and a 7-pin. At least mine does, and I don’t have the towing package.
