Adding power sockets to truck bed - need a sanity check on wiring
Discussion in 'Audio & Video' started by JNJury978, Dec 16, 2022.
  1. Dec 16, 2022 at 8:11 AM
    JNJury978
    JNJury978 [OP] New Member
    2013 Toyota Tundra CrewMax Platinum 5.7L 4x4
    2013 Toyota Tundra 5.7L 4x4 CrewMax Platinum
    Wanting to add power socket ports (cigarrette + USB) to truck bed, and wanted to get a sanity check...
    I am familiar with running "always on" power to the truck bed as I already have truck bed lights w/ switch in the back; however, my "requirements" (aka desire) for this current modification is a little bit more specialized. I basically want:
    • Power sockets that turn on ONLY when the truck is on, but...
    • Can also be turned to "always on" via switch in case I want to use them without turning the truck on; this switch would otherwise be left in "Off" position 99% of the time
    Would this wiring diagram work for that?
  2. Dec 16, 2022 at 8:25 AM
    I run a Blue Sea system in mine. The power is always hot to the rear of the truck for use without the truck needing to be running. The panel has a circuit breaker on it to turn the ports on and off.
  3. Dec 16, 2022 at 8:34 AM
    JNJury978
    Hello and thanks for your input
    I am wanting the power sockets to run only when the car is Key'd on, but be able to "override" this through the use of a switch (which would otherwise be left in "OFF" position, by default).
    Reasons:
    I already currently have "Always On" power ports in the truck bed (controlled by a switch). But my current life style is such that 99.99999% of the time, I have a lot of devices charging the truck bed. Since I don't want to run my batteries down, I always have to go and manually turn the switch ON/OFF whenever I turn the truck on/off. And ofc, I've forgotten to do so a few times, which sucks for obviously reasons. So this is the main reason I want the power ports to turn ON/OFF by turning the truck on/off as well (by default)... but also have the ability to switch them ON even if the truck is off, in the rare chance I need that option.
  4. Dec 16, 2022 at 1:10 PM
    BeauDacious
    BeauDacious 040 > all other colors
    Beau
    14 DC 4x
    Looks like it should work, the relay controls the keyed power and the switch controls the always on power.
    JNJury978[OP] likes this.
  5. Dec 16, 2022 at 1:33 PM
    JNJury978
    Exactly the confirmation I'm looking for. For some reason, this is the first time I've ever had to use a relay, so I had no idea if I even had just that part down.
    Thanks so much!
