Adding 1,500 lbs
Discussion in 'Suspension' started by Kb66, Apr 7, 2026 at 8:03 PM.
  1. Apr 7, 2026 at 8:03 PM
    Kb66
    Kb66 [OP] New Member
    Tuesday
    2017 Tundra
    None
    I recently purchased a 2017 Tundra to do some overlanding. I’ve ordered a Tune M1 tent that is being manufactured, which is advertised at 500 lbs. By the time I add fridge/freezer, water, camping gear, myself & my wife, food & exterior components including winch, bumpers & bigger tires, we’re up to about 1500 lbs.
    If anyone has made suspension upgrades similar to these specs and are happy with them, I’d appreciate knowing your mods.
    I’ve called around to several companies and have received as many conflicting recommendations.
    Thanks in advance.
  2. Apr 7, 2026 at 8:08 PM
    2026 Ram 1500 Bighorn
    You likely need a bigger truck, unless you have a unicorn payload rating.
    Payload is about way more than your suspension. It accounts for how it handles, cools, brakes, etc. Making the truck not squat by beefing up suspension doesn't fix anything besides looks, and it doesn't negate the added wear of being over payload.
    Most importantly, the payload rating takes into account the vehicle's behavior in emergency braking and maneuvers. Overloading is going to degrade emergency performance.
  3. Apr 7, 2026 at 8:28 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Now that the classic payload post from someone is out of the way....
    Sounds like a pretty standard camping setup. I'm not entirely versed on Tundra suspension options, but you'll probably want an add a leaf in the back, front is probably fine with whatever springs, and then shocks probably need to be slightly stiffer which if you get something like King/Fox/ADS with adjustable knobs on the reservoirs then you can dial it in to what you want. @memario1214 sells a bunch of Tundra stuff and probably has the most up to date suggestions for a bolt on suspension setup.
  4. Apr 7, 2026 at 8:54 PM
    Terndrerrr
    Terndrerrr 913000 miles to go
    Music City
    6UR-FE
    That Tune camper looks awesome.
    You might want to look through the GFC and FWC threads. Similar lightweight truck camper setups. See what those people are running.
    Here are some threads:
    https://www.tundras.com/threads/2017-tundra-gfc-bed-build-out-super-pic-heavy.142861/#post-3591713
    https://www.tundras.com/threads/go-fast-camper.23578/
    https://www.tundras.com/threads/baileys-2018-four-wheel-camper-build-photos.35164/
    https://www.tundras.com/threads/four-wheel-camper-fwc-thread.94294/
  5. Apr 8, 2026 at 3:56 AM
    OHwendTrd
    OHwendTrd Aging Member
    2021 SR5
    Couple things
    Probably right, but! ...
    @GODZILLA :fistbump:
  6. Apr 8, 2026 at 4:05 AM
    Mainly make these posts so folks at least take a look at their payload and raise a bit of awareness. So many (myself included many years ago) have no idea what payload ratings are and misunderstand them.
    I'm under no illusion that my posts will ever dissuade anyone from doing what they want to do, but I do hope they at least make their decision from a more informed position.
    Cpl_Punishment and Kb66[OP] like this.
  7. Apr 10, 2026 at 7:40 AM
    Kb66
    Tuesday
    2017 Tundra
    None
    Thank you all for your suggestions & advice. I’m about ready to make a decision. I won’t be able to buy a new truck, but I do appreciate the info on emergency handling.
    Once I decide and get it together, I will update my post & let you know if I am happy with the results. I am hoping all my research & your advice will make this decision less stressful & exactly what I need. I only have another 45 days or so to have the truck ready for the camper delivery. I’ll update after my shakeout trip.
    Thanks again.
    2mchfun and GODZILLA like this.
  8. Apr 10, 2026 at 8:44 AM
    AZBoatHauler
    So.Arizona
    What's your budget? Bilstein 6112 / 5100 or 5160 setup would be better than stock and not break the bank. If you want more than that - @memario1214 can setup you up with a higher end suspension and some aftermarket leaf packs.
    Terndrerrr, GODZILLA and 2mchfun like this.
  9. Apr 10, 2026 at 8:58 AM
    2mchfun
    Look at Roadmaster Active Suspension HD kit for Tundra. E trailer.com has
    GODZILLA likes this.
  10. Apr 10, 2026 at 10:01 AM
    Also payload is adjustable, to a degree. It's the total weight being added to the vehicle. If there are things in the vehicle that you don't need to carry around, get it out of the vehicle. If there are components you are considering adding, and one of the options saves weight, consider using that one instead (usually more expensive). Weight reduction mods...
    Terndrerrr likes this.
