AC Light flashing
Discussion in '2nd Gen Tundras (2007-2013)' started by B_Wall, Jul 14, 2021.
  1. Jul 14, 2021 at 6:10 PM
    B_Wall
    B_Wall [OP] New Member
    Brendan
    2013 Tundra 4.6
    Had a new compressor installed last fall on my 2013 4.6L Tundra. AC will blow cold and randomly the light will start flashing. I recently replaced the relay (Autozone) and still get the same results. AC blows cold and will randomly start flashing, sometimes within 5min and sometimes it will work for 2hr ride no problem. Any thoughts on what it could be would be appreciated.
  2. Jul 14, 2021 at 6:12 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    Sounds like a ground wire issue
    MS22 likes this.
  3. Jul 14, 2021 at 6:16 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    When I bought my 02 it had the same issue, previous owner recently had the TB changed and they forgot to hook up the ground from the A/C.
  4. Jul 14, 2021 at 7:17 PM
    B_Wall
    Brendan
    2013 Tundra 4.6
    I took a look at the ground. Pretty corroded but seems to be solidly attached.
  5. Jul 14, 2021 at 7:26 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    Maybe that's why, losing proper connection because of rust, i would spray some wd40 just to be sure
  6. Jul 14, 2021 at 8:06 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Full disclosure, I don't own a 2nd gen nor have I ever set foot in one but I have seen the flashing ac light on older toyotas. On my 96 Camry the ac light would start flashing and cutting off AC when the refrigerant was getting low until it finally all leaked out then no more AC. Heard it had something to do with the clutch not spinning at the same speed as the belt/engine.
    On my 08 Lexus I got the flashing light after going through a puddle once.
    Good luck.
  7. Jul 14, 2021 at 9:36 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    That's not what a good ground looks like.
  8. Jul 15, 2021 at 5:30 AM
    CTB Mike
    CTB Mike It's RED? My rods and cones must be screwed up!
    Southern Arizona
    2011 Red Rock Warrior
    I had an '03 Suzuki XL_7 that had the flashing A/C light. No one (including Suzuki techs) could tell me the cause. Charge was good, never had a problem with cooling so I let it be until I sold it about 2 years later. I loved that truck!
  9. Jul 15, 2021 at 10:54 AM
    shakey_jake
    shakey_jake New Member
    Jake
    Virginia Beach
    2012 Tundra 5.7 TRD 4x4
    6" lift. 35s on 20s
    i know you said you replaced the relay but was it the mag clutch relay or a different one?
    Danny3737 likes this.
  10. Jul 15, 2021 at 11:11 AM
    B_Wall
    Brendan
    2013 Tundra 4.6
    I agree, definitely not the best ground. I’m going to clean it up this afternoon.
    I replaced the mag clutch relay.
  11. Jul 19, 2021 at 4:35 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    The mag clutch relay is a problem in all Toyota’s. II’ve had to replace them in my RAV4, Highlander, and Camry.
  12. Jul 22, 2021 at 6:35 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    I’m not sure you can buy the mag clutch relay from autozone - although they may have one that fits - when I had that problem in my 4Runner I learned it is a special high current relay or something and I ended up ordering a used oem one from eBay.
  13. Aug 19, 2021 at 6:26 PM
    B_Wall
    Brendan
    2013 Tundra 4.6
    I cleaned up the ground and and tested the relay to no avail. I had noticed it would seem to work more consistently while driving and was for more likely to shut down while at idle. We hooked it up to get the code and turns out the compressor is fine but the lock sensor went bad at 13 months. Ended up grabbing an OEM compressor from the local Toyota dealer and its working as it should now.
