AC is amazing at 1200 RPM+ Compressor shuts off under 1200
Discussion in '2nd Gen Tundras (2007-2013)' started by e30cabrio, Mar 31, 2026.
  1. Apr 4, 2026 at 9:58 AM
    #61
    joseph_womack
    joseph_womack Insta @ 4x4bound
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    Yes you could run separate wires if there is a brake somewhere; but to be honest all of this is just spit balling/the parts cannon till it gets properly diagnosed for what it is, since you don’t have it back yet we can’t fact check any ideas
    have you talked to them again or just waiting on the module?
    e30cabrio[QUOTED][OP] likes this.
  2. Apr 4, 2026 at 2:18 PM
    #62
    e30cabrio
    e30cabrio [OP] I'm e30cabrio, I'm a modaholic
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Found one on FB Marketplace.for 80.
    Back semi where I started except instead of getting to 40 it's 56. WTF???
    Where should the gauge I posted be when it's running?
  3. Apr 4, 2026 at 2:21 PM
    #63
    e30cabrio
    The boss refuses to call me. I left a horrible & factual review on Google & Yelp. He responded with bullshit and accusations regarding my wiring to the SC pump motor, 18+ Sequoia headlights. dedicated fuel pump wiring, none of which touched AC & all of which has been there for 3+ years.
    It's insane.
    joseph_womack[QUOTED] likes this.
  4. Apr 4, 2026 at 2:25 PM
    #64
    koditten
    Kirk
    Midland of the Mitten
    I think this thread is giving me hypertension.
    joseph_womack and e30cabrio[OP] like this.
  5. Apr 4, 2026 at 3:05 PM
    #65
    e30cabrio
    Sitting at Big O, getting the lbs checked and the system filled how do you think I feel?
    Lol
    joseph_womack likes this.
  6. Apr 4, 2026 at 7:22 PM
    #66
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    If the
    If the ac is working you should be getting 20° F colder than outside air temp generally
  7. Apr 4, 2026 at 7:24 PM
    #67
    e30cabrio
    Big O filled it, was low (knew Aamco dicked me)
    It's 12 degrees hotter now than the last picture that was 40 so I guess 42 is ok but doesn't this prove I did not need the condenser???
  8. Apr 4, 2026 at 7:25 PM
    #68
    e30cabrio
    Ambient today was 100, was 88 last picture.
  9. Apr 4, 2026 at 7:51 PM
    #69
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    Is it working below 1200 rpm though?
  10. Apr 4, 2026 at 8:20 PM
    #70
    e30cabrio
    Nope, it seems to be coming on at 1-1100 now & it stays cool longer before getting hotter under that.
    It's insane.
    One of the junkyards I called said he had the same issue and gave me this electrical shop I have the Thursday appointment at who fixed it.
    Fingers crossed.
    joseph_womack and AZTundra like this.
  11. Apr 5, 2026 at 6:59 AM
    #71
    e30cabrio
    I tried all the suggestions:
    Removed the diode, verified all the grounds are happy, tried disconnecting the fan & giving it direct power.
    Nope.
    Sad.
  12. Apr 5, 2026 at 9:48 AM
    #72
    e30cabrio
    No leaks here right?
  13. Apr 5, 2026 at 5:21 PM
    #73
    e30cabrio
    If I command the compressor under 11-1200 nothing.
    What is the rest of the info telling us?
    Second picture is holding the throttle, compressor on, cold air coming out.
  14. Apr 5, 2026 at 10:32 PM
    #74
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    That “Regulator pressure sensor” reading of 322 psi doesn’t seem right unless the compressor clutch had just been engaged. And if it had, I’d expect lower evap. core temperatures, so I doubt that it had.
    joseph_womack and Mdl like this.
  15. Apr 5, 2026 at 11:10 PM
    #75
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA 1 7/8 Longtubes, Snivs 1.88 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT Trans/valve body, 4.5inch intake with 10x2 SABM, FIC 880/930cc injectors, 450 Walbro, Direct Port W/M injection, GM 95mm TB, DW fuel regulator, E-fan, Remote engine air/oil cooler, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    A quick look says that a high reg psi above 250 psi can be:
    Overcharged system, condenser fan not working, air in system, blocked condenser, stuck expansion valve closed. The big question is what is causing the fan not to come on under 1200rpm.? ?
  16. Apr 6, 2026 at 6:19 AM
    #76
    e30cabrio
    In the second picture, vent temp was cool, it was over 1200 rpm.
    Why the damn compressor & fan stopped coming on under 1200 is the million dollar question.
    The series of events was, ECU died, truck sat for about 2 weeks, ecu came back, this started.
    It has since been parts cannoned with every part but those inside the dash.
  17. Apr 6, 2026 at 7:29 AM
    #77
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    I need a little more clarity… when giving the fan direct power it doesn’t come on?
    Meaning the fan lost either low speed or high speed?
  18. Apr 6, 2026 at 7:29 AM
    #78
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    Where’d the ecu come from and why was it replaced/why’d it die?
  19. Apr 6, 2026 at 9:29 AM
    #79
    e30cabrio
    Fan is fine direct power & over 1200 rpm, compressor does not come on until 1200 rpm both with the fan connected to the harness & direct power.
    I am supercharged, ecu bricked flashing a tune, it was replaced by another I had which is when these issues started, hoped the second ecu was also bad so got a new one from Toyota.
  20. Apr 6, 2026 at 10:38 AM
    #80
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    I haven’t used techstream to look at active tests so unsure about what info you can see. When the fan is on does it show you in techstream? Is it two different sections: one for high speed and low speed or is it just fan on?
    Secondly, when the compressor is not on below 1200, does Techstream say that it should be on? Or does it say the compressor is off?
  21. Apr 6, 2026 at 10:51 AM
    #81
    e30cabrio
    The first picture the compressor is commanded on but is off & TS says it's on , the second I have commanded it on (before getting it to 1200+ it did not come on) I then held the pedal.
    Here is a video when I was on the pedal, I assume the Evap fin thermistor temp under 60 & going down shows it is cooling?
    https://vimeo.com/1180549213?share=copy&fl=sv&fe=ci
  22. Apr 6, 2026 at 12:51 PM
    #82
    What’s the system voltage during the below 1200rpm operation? And above?
  23. Apr 6, 2026 at 12:58 PM
    #83
    e30cabrio
    With the diode (for the AGM) 13.5-14.2. Without 13.2-13.7 without. I put it back since it didn't fix it.
  24. Apr 6, 2026 at 1:27 PM
    #84
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    Yeah, and it’s not going negative or anything causing the compressor to kick off so that can be ruled out.
    you need to command the compressor on at idle with tech stream and check for power and ground at the compressor; it should most likely not have it but we’re just double checking everything
  25. Apr 6, 2026 at 1:31 PM
    #85
    e30cabrio
    I'll check, I'm pretty sure there will be no power.
    Thanks
  26. Apr 7, 2026 at 6:12 PM
    #86
    e30cabrio
    No power until 1150 RPM.
  27. Apr 7, 2026 at 10:49 PM
    #87
    joseph_womack
    Joe
    Louisiana
    2019 Tundra 5.7 4WD
    Okay, that’s what I expected but I’ll dig into the wiring diagram today, you said this all started right after the new ecu?
  28. Apr 8, 2026 at 5:59 AM
    #88
    e30cabrio
  29. Apr 8, 2026 at 7:20 AM
    #89
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Have you entered HVAC self-diagnostics mode on the control panel?
  30. Apr 8, 2026 at 7:36 AM
    #90
    e30cabrio
    Did not know that was a thing. I searched it & it seems to need a display with numbers which mine does not have. I'll give it a try & see.
    Thanks.
