AC Compressor done???
Discussion in '2.5 Gen Tundras (2014-2021)' started by Johnders2586, Jan 30, 2020.
  1. Jan 30, 2020 at 5:18 AM
    Johnders2586
    Johnders2586 [OP] New Member
    2017 Tundra SR5 W/TRD pkg
    Toytec Performance Aluma 3" Lift- Toytec rear shackle, Fuel Vector Wheels, Toyo Open Country C/T 295/70/18 Tires
    Good Morning,
    I started my truck thismorning, Noticed a squeeky squeal type noise. Started looking at the belts and pullies under the hood. Noticed the AC compressor is stuck not turning so the belts squealing as it's trying to turn the pulley .. I assume this means the compressors done for? Can't understand why this would be at only 60K on the clock.. This happen to anyone else . Any advice? Anyone replace one?.. this blows ...
  2. Jan 31, 2020 at 1:41 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
    If you're lucky it's external. Maybe the clutch broke. When my Tacoma's went out the rubber ring had separated from the hub, so when the clutch would engage the ring would squeal. Sounded like a squealing belt, and since it wasn't turning the rest it looked stuck.
    If you're unlucky and the insides of the compressor went boom boom then it's not good. Typically a grenaded compressor blows debris throughout the system
    Randy Morton likes this.
  3. Jan 31, 2020 at 2:28 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    What's your ac refrigerant lvl at?
