ABS warning light
Discussion in '1st Gen Tundras (2000-2006)' started by Topwater Scott, Feb 25, 2019.
  1. Feb 25, 2019 at 10:34 AM
    Topwater Scott
    Topwater Scott [OP] New Member
    Scott
    2006 Blue Tundra TRD
    My ABS warning light just came on and the ABS does not work. I found another post to disable ABS you remove the 2 fuses. I haven't checked my fuses yet but I imagine at least one of the fuses is blown. My question: what causes the fuses to blow? I can replace the fuses but want to know what needs fixing/replacing if the fuse blow again.
    Thanks everyone!
  2. Feb 25, 2019 at 11:34 AM
    15whtrd
    15whtrd Mr. Blonde
    Maybe a bad sensor or nicked wire somewhere? How did you confirm the ABS is not working?
  3. Feb 25, 2019 at 3:13 PM
    Aerindel
    Aerindel New Member
    Montana
    2000 Tundra AC, SR5, 4.7 V8 4WD, 340k'ish miles, 2008 Sequoia, 220k Miles
    As I mentioned in the other thread, I've never actually seen an ABS fuse blow, and in my tundra at least, there are two 40 amp! fuses, both of which have to be removed to trigger the light. A faulty sensor or wire I think is the most likely, but its worth pulling and replacing both fuses to see if that resets it.
  4. Feb 25, 2019 at 3:30 PM
    Professional Hand Model
    Hand Protectors
    Check your connections at each wheel.
  5. Feb 26, 2019 at 5:16 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Check connections and check fluid level. If it's slightly low it will throw the light and disable itself, you'll just have regular brakes.
