ABS,VSC, CHECK ENGINE LIGHT
Discussion in '2nd Gen Tundras (2007-2013)' started by Pompano guy, Aug 27, 2024.
  1. Aug 27, 2024 at 9:15 AM
    Pompano guy
    Pompano guy [OP] New Member
    Robert
    2008 Toyota Tundra 2WD 5.7
    My 2008 Tundra ( 120K ) shows the ABS, VSC (flashing), and CHECK ENGINE warning lights come on after about 2 minutes driving. The transmission will not go into 4th gear when this happens. After I stop, shut off engine, it will shift normally, although the lights stay on. After about 4 starts, the lights go away for about 4 more starts but return with the same result. I have not had it diagnosed for error codes but I will come back to the forum once I have. Is it the speed sensor? Will a computer tell me which one? Thanks!
  2. Aug 27, 2024 at 9:50 AM
    art64
    art64 New Member
    Maybe the Air Injection Pumps or it's related components like the switching valves. Definitely need the code/codes.
    Pompano guy[OP] likes this.
  3. Aug 29, 2024 at 10:17 AM
    Pompano guy
    Robert
    P032D is the code I got. Naturally I did not have the warning lights on when we hooked up the computer. That says "knock sensor 3 circuit high" ? That doesn't add up to me.
  4. Sep 12, 2024 at 7:53 AM
    GiJoeTrukin
    GiJoeTrukin New Member
    Joseph
    08 TRD
    Hi guy, I’m having the same issues with 160k miles. I’ve replaced all the easy stuff ie injectors, sensors, mass Flo, and even the throttle body. Next try is the lifters, oh and yes I had to redo the timing chains.
  5. Sep 12, 2024 at 8:02 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
  6. Sep 17, 2024 at 8:45 PM
    Tundra1717
    Tundra1717 New Member
    2008 Toyota Tundra 4.7L V8
    Are your brake lights working in the back?
