A TRD Supercharger on a 2016
Discussion in 'Performance and Tuning' started by Tundyfundy, Oct 14, 2019.
  1. Oct 14, 2019 at 2:57 AM
    Tundyfundy
    Tundyfundy [OP] Petunia The Tundra, and her sidekick Colbie
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I recently purchased a USED TRD super charger. I also bought a TRD FIT KIT, model number PTR29-34140. I own a 2016 (Gen 3) 5.7 GAS NA engine. I'm a little late on the pull here but....
    1. I'm pretty sure this is compatible but does anybody have any insight on part compatibility?
    2. I already have a "BullydogHP", what process is necessary to for tuning using the bullydog?
    3. I read that the SC tunes are usually specific to 93 Octane. As I live in CA, and can only obtain 91 Octane, will I be good or will the motor knock?
    4. Is the TRD Supercharger The exact same product as the Magnusson TVS 1900? I'm wondering because I want to know if I can use those parts to rebuild the supercharger.
    5. Has the TRD Supercharger part number changed? I'm asking because I want to know if there's different versions.
    @Roman I have been trying to get a hold of you by phone for about a week to no avail. I know you're a busy man so I'm hoping you could provide some insight to me about the Toyota compatibility on here at your leisure. Also I need to order everything that used to come in the main supercharger assembly, minus the main assembly; i.e., "Hardware Bag "J" as well as the O-rings.
    Thank you in advance everybody! Your guidance is appreciated. :mudding::thumbsup:
  2. Oct 14, 2019 at 8:53 AM
    Tundyfundy
    Bay Area, CA
  3. Oct 14, 2019 at 9:06 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    Yea, sorry about that. I always run around the dealership all day long and am never in one place for long.
    The fit kit is the correct part number. I just looked up the parts that are still available at Toyota, and it appears that most of the hardware you're looking for is not available. It should be available from Magnuson, though. They should still be able to supply everything since they are still producing them. I'm not sure what all you will need to order to get it, though. Magnuson should be able to answer most of those questions.
    Tundyfundy[OP] likes this.
  4. Oct 14, 2019 at 9:08 AM
    Tundyfundy
    Bay Area, CA
    Thanks @Roman
    Roman[QUOTED] likes this.
