A simple little usb hack
Discussion in 'Audio & Video' started by Henry Hooker, Mar 23, 2019.
  1. Mar 23, 2019 at 5:51 PM
    Henry Hooker
    Henry Hooker [OP] New Member
    Not sure if this has been posted before or not. I don't get on here enough but when I need info it's a great place so figured I'd post this up just in case. Anyway, the usb port being located directly in front of the third cupholder makes it a pain and also means a wire laying around.
    I pulled the plug apart using a couple small jeweler screwdrivers and the whole board disconnects from the actual holder in the dash. I took a piece of abs plastic and stuck it on the bottom to make it rigid and then taped over the whole thing and then zip tied it up. Now I have no wires hanging around and the cupholder isn't blocked by the usb cord sticking out.
  2. Mar 23, 2019 at 5:54 PM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    I’m having a hard time understanding what’s going on here.
    Can you post a pic of the finished product?
  3. Mar 23, 2019 at 5:58 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    X2
  4. Mar 23, 2019 at 6:40 PM
    Sunnier
    Sunny
    San Diego, CA
    Yeah, @Henry Hooker, it's cools you took time to share this mod that might help us, but I can't figure it out either. Can you maybe post a pic from the vantage point of your driver's seat, showing what this turned out as? What do you plug into now, and is it now sitting loose atop the center console, or-?
    831Tun likes this.
  5. Mar 23, 2019 at 6:48 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    Sounds like you hid the plug and made it kind of like a hardwired/in line deal?
    831Tun likes this.
  6. Mar 23, 2019 at 7:17 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  7. Mar 23, 2019 at 7:22 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
  8. Mar 23, 2019 at 7:43 PM
    Henry Hooker
    Squatting Pigeon is correct. Sorry, I get in my mindset and forget that people may not be living in my brain. Basically the usb cord is now ran out the behind the dash. I have my old ipod sitting in that little cubby on the passenger side kind of where their knee would be. As for the front view, it looks the same except there isn't a way to plug in a usb. Obviously if you looked real close you could tell. I did it this way because it's a lot easier to modify/ruin a charging cord vs factory wiring. Here's a pic I couldn't find earlier, you can see the circuit board part. Basically, you unplug the unit from the dash, then pull unit apart to get the circuit board out and then you can plug housing back in place so it looks normal. I added a piece of plastic to the bottom for rigidity and to keep it from touching any metal. I'll try to snap a pic of my ipod hanging out tomorrow and of the
    front (although it looks quite normal.)
  9. Mar 23, 2019 at 7:44 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    I had to read it 3 times:eek2:. :popcorn:
    Squatting Pigeon likes this.
  10. Mar 23, 2019 at 8:05 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Still dont get it. Interested in more pics of ipod and all that
  11. Mar 23, 2019 at 8:24 PM
    Henry Hooker
    Ok, here's a pic of how it looks now, and where the ipod is. I had cut and splice my charge cable and drill a small hole back of the cubby to run the wire, which is pretty straightforward, although a bit tedious with the tiny wires. Hopefully I can tear it apart tomorrow and totally redeem myself with a couple extra pics
    Cobshop, TomC843, Sunnier and 3 others like this.
  12. Mar 23, 2019 at 8:30 PM
    Pudge
    CT
    Makes sense now no need to rip it apart again. Good job and definitely works will for your needs.
  13. Mar 23, 2019 at 10:21 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Thanks for sharing OP, looks good! On a side note, your and my definition of “simple” are apparently very different.
  14. Mar 24, 2019 at 6:37 PM
    Henry Hooker
    Ha, perhaps, but when something can be un-clipped vs splicing into factory wiring I'd consider that simpler. My next post about the sub box build might be a bit more in depth and half complicated.
    Cobshop likes this.
