A pillar hardens to rearview Mirror/monitor and lights
Discussion in 'North East U.S.' started by f9zsheol, Apr 19, 2019.
  1. Apr 19, 2019 at 8:49 AM
    f9zsheol
    f9zsheol [OP] New Member
    Hello I need to but this hardness 82171 2013 Toyota Tundra 5.7l gas 4x4 I’ve been to the dealer and they told me it’s not available what can I do any thoughts thanks. I’m new to this form so I apologize if this was solved already or discussed.
  2. Apr 19, 2019 at 8:51 AM
    15whtrd
    15whtrd Mr. Blonde
    Harness?
    BlackSheep likes this.
  3. Apr 19, 2019 at 8:55 AM
    15whtrd
    15whtrd Mr. Blonde
    https://parts.toyotaofcoolsprings.com/search?search_str=82171
  4. Apr 19, 2019 at 8:59 AM
    f9zsheol
    I don’t know how to best describe it the wire harness that connects from the rearview Mirror back up camera and over head lights and the wire runs down to the left side driver side behind he airbag and connect where the A Piller is
  5. Apr 19, 2019 at 9:00 AM
    15whtrd
    15whtrd Mr. Blonde
    Check the link I posted. I’ll tag someone for you maybe they can offer further assistance.
    @Roman
  6. Apr 19, 2019 at 9:02 AM
    f9zsheol
    This one that goes to the mirror
    15whtrd likes this.
  7. Apr 19, 2019 at 9:03 AM
    f9zsheol
    Thank you for your help
    15whtrd likes this.
  8. Apr 19, 2019 at 9:12 AM
    15whtrd
    15whtrd Mr. Blonde
    Also it might help to include whether your truck is SR5, platinum, or limited. There may be different harnesses depending on your trim.
  9. Apr 19, 2019 at 9:27 AM
    f9zsheol
    Yes it’s an sr5
    15whtrd likes this.
  10. Apr 19, 2019 at 10:09 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    That's the first time I've seen a wire harness that wasn't available to order. There must be something else going on with it as to why it isn't available. Maybe safety related. The connectors are showing to be available for the harness.
    15whtrd likes this.
  11. Apr 19, 2019 at 10:15 AM
    15whtrd
    15whtrd Mr. Blonde
    If that’s the case maybe it would be smart for him to buy the connectors and then take his old harness and have it copied to the new connectors.
  12. Apr 19, 2019 at 10:19 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    The man said "hardness" and by thunder he aims to get some.
    You've been warned, ladies.
  13. Apr 19, 2019 at 10:23 AM
    Roman
    Roman
    Franklin, TN
    I guess it would depend on the damage that his current harness has. If it's a connector, that's an easy fix. If a wire is split somewhere, that can be fixed with some solder/heat shrink.
  14. Apr 19, 2019 at 12:21 PM
    f9zsheol
    Thank you all for your time I’ll do the solder / heat shrink option
    15whtrd and Roman like this.
