A construction question (Housing)
Discussion in 'Off-Topic Discussion' started by Tierhog, Feb 19, 2019.
  1. Feb 19, 2019 at 8:43 AM
    Tierhog
    Tierhog [OP] SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    I have crappy aluminum rain gutters. No trees to clog them. I live in California and see occasional rain. I now have a section of wood rot on a rafter tail and facia board (2x6x16). The rutters fill with a silt like dirt from agricultural discing and they leak in the corners.
    Do I need these damn things? I have a tile roof.
    I'm from the east coast and we don't use em.. Snow would kill them.
    Thanks
    831Tun likes this.
  2. Feb 19, 2019 at 8:55 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    A lot of factors to consider. How much over hang do you have? Where's the water going now and where's it gonna go if you remove the gutters? How much rain do you see on average per year? What's the water gonna splash on? Also, code requires that you have metal, like an ell, that fits under the shingles and comes out over the fascia.
  3. Feb 19, 2019 at 8:56 AM
    Tierhog
    This will add some clarity. Average rainfall is 13 inches per year, 0 snow.
  4. Feb 19, 2019 at 8:59 AM
    koditten
    koditten New Member
    Some insurance companies require them.
    One if their duties is to get run off away from walls and foundation.
    If you have little rain or snow, they are not very useful in my opinion.
    15whtrd likes this.
  5. Feb 19, 2019 at 9:01 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Dang, that corner must hold water and leak into fatia. 13 in annual rain shouldn't rot anything.
    There are certain builder grade gutters that tend to direct rain to the fatia more than others.
  6. Feb 19, 2019 at 9:02 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Well, you're gonna have water dripping/ splashing along the front of the garage door, maybe not a big deal for ya. It'll also splash up against the house.
    Short answer: No you don't really have to have gutters. If they're failing and need replacement, maybe remove 'em and see if you like it before installing new ones.
    Tierhog[OP] likes this.
  7. Feb 19, 2019 at 9:10 AM
    Tierhog
    All your responses are helpful. The primary culprit is the mud like silt that hardens into kryptonite in the summer and creates a swamp within the gutters in the winter. The seals fail at the union and it collects and drips for days as gravity allows it to go under the gutter and on the facia.
    I have a second set, on the upper roof and no damage yet, but I'm realistic.
    I'm on a foundation.with concrete and decking on the perimeter.
  8. Feb 19, 2019 at 9:13 AM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    If you want to fix the facia the gutter has to come off anyways and you can have a seemless one made to replace it. If you want to just stop the leak and deal with facia later then get some Quad brand gutter sealant in the caulk tubes and seal up the seams.
    Edit- pressure wash the silt out and seal the union with quad.
  9. Feb 19, 2019 at 9:14 AM
    Trooper2
    JR
    Gutters are nice, you may miss if removed when it does rain. As mentioned. there are different grades of gutters, but time and elements can certainly wear on any of them.
    When replacing fatia, I would recommend treated would.
    Tierhog[OP] and 831Tun like this.
  10. Feb 19, 2019 at 9:19 AM
    Twinky
    07 double cab work horse
    Take a section off of a side of the house, like the garage section. Then just see if they are worth it for the occasional rain or not.
    As long as insurance isnt an issue (save the gutter and put it back up if necessary) and the facial looks decent its not gonna hurt anything.
  11. Feb 19, 2019 at 9:19 AM
    pickeledpigsfeet
    Kings & Icons
  12. Feb 19, 2019 at 9:21 AM
    Tierhog
    I have a guy that's a licensed framing contractor that will remove, repair and paint it on Monday. House will look like a kid with his two front teeth knocked out until I figure out what's ideal.. Lol.
    You guys have been a tremendous help. Thank you all.
    831Tun likes this.
  13. Feb 19, 2019 at 9:23 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
  14. Feb 19, 2019 at 9:26 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Here in Cali, redwood is the best thing, as long as it's tight grained and not some box store bargain lumber. I've had terrible experiences with many of these "treated" trim lumbers. They claim a big warranty and are out of business before you can call them on it, presumably due to all the claims. From what I've seen, a lot of the "treated" lumbers for exterior trim application are made of inferior wood species like pine or spruce. They're often finger jointed too and the joints fail. They also often have costly and time consuming primer requirements (proprietary paint) for any cuts.
    I'm often working at the beach or nearby and the elements are a bit more extreme. In certain parts of the country the "treated" trim lumber may work fine but due to the experiences I've had I would avoid it like the plague.
    15whtrd, joonbug, Tierhog[OP] and 2 others like this.
  15. Feb 19, 2019 at 9:34 AM
    I'm from Ohio and we always have or "should" have gutters. Our fascia boards are typically covered with aluminum which also helps add protection. I personally wouldn't remove it.
    831Tun likes this.
  16. Feb 19, 2019 at 9:35 AM
    Tierhog
    Here's my quote.
    It looks like your gutter is causing the damage to your facia and rafter tails. It’s going to be difficult to impossible to fix your damage without removing the gutter too. We’re strictly a framing contractor and although we would give you a price for replacing the dry rot we don’t get involved with gutter. We’ll take it down as far as we need to fixing the facia and tails but putting it back up would have to to be somebody else. Based on the picture for this one area to be repaired the facia would need to get cut back on each side of the corner to make it look good.
    Material :2x6 x 16’ facia 38.00
    2x4x 8’ Doug 5.00
    1/2gal paint& primmer
    20.00
    Nails and caulk. 5.00
    Labor 4 man hours. 200.00
    Bid Total: 268.00
    I thought it was reasonable . Im presuming hes using Douglas F?
    15whtrd and 831Tun like this.
  17. Feb 19, 2019 at 9:36 AM
    Trooper2
    JR
    Edit: Replace materials (especially wood) with what is recommended in your region.
    SoCal619 and 831Tun[QUOTED] like this.
  18. Feb 19, 2019 at 9:39 AM
    Yes I would remove to fix and reinstall it. I will also agree redwood is a much better option than treated wood. We still use redwood around here in certain situations. The problem for use is redwood is very hard to get anymore and very pricey.
    831Tun likes this.
  19. Feb 19, 2019 at 9:44 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    That would be my guess. I was kinda broke when I started building my house and used some DF for fascia, I now regret it. It's wept sap and all needs to be sanded and repainted. If it's well primed and painted on ALL sides it'll work but for the small amount that's being replaced I'd suggest redwood 'cause it would've held up the the leaking gutter far better than what's currently there.
    Do you by chance know what the average humidity is your area?
    joonbug likes this.
  20. Feb 19, 2019 at 9:48 AM
    Tierhog
    Google is GOOD.. LOL
    Average Humidity is 66%
    We are selling in approximately 4 to 5 years
  21. Feb 19, 2019 at 9:48 AM
    CaptSpaulding
    CaptSpaulding ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    Also consider a more substantial drip edge. It would help push the water away from the fascia . I just built a patio on the rear of my house, opted for a dramatic drip edge and no gutter. So far, the fascia never gets any run off
    SoCal619 and 831Tun like this.
  22. Feb 19, 2019 at 9:52 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    So true. And, the way it's grown these days it doesn't have the same rot resistant properties that it once did. It's grown faster and the extractives and tannins that give it color and rot resistance don't have enough time to form. I'm lucky, Big Creek Lumber, one of the major redwood mills is really close by. Heck, I've got 30+ redwood trees here on our property.
    joonbug and Prostar 190[QUOTED] like this.
  23. Feb 19, 2019 at 6:45 PM
    koditten
    koditten New Member
    I'm not sure what your contractor is smoking, but if you can get the repairs done for $300, you better get the check wrote.
    Prostar 190, CaptSpaulding and 831Tun like this.
  24. Feb 20, 2019 at 4:44 AM
    Slayer
    Slayer Member
    Slayer
    from the photo..
    I'm sure the rafter tail is gone too better fix that too.
    that fascia is what the lumber industry call SPF... fast growth spruce,pine or fir then pre-primed.
    a poor, but cheaper choice by your builder.
    replace with cedar or redwood.. doug fir will make you fight pitch pockets a long time.
    I would check the slope on that section of gutter.. maybe it the low spot.
    adding a downspout there might help too.
    water is very damaging.
    maintainace is key... flush that crap out of your gutters once in a while.... HA
    831Tun and Trooper2 like this.
  25. Feb 20, 2019 at 11:22 AM
    Tierhog
    I cleaned all the gutters yesterday. Was a mudfest. The guy is coming Monday. If that price is low I'll definitely pay in cash. He probably thought I'd turn it in to the insurance. Rafter tail is being replaced.
    https://youtu.be/CCK2SITWa_Q
    We move to Florida in 5 years. Retirement in California is financially ridiculous. Truck tags for a year was 700$ plus.. Sales tax is 9%, Gas prices, real estate etc.
  26. Feb 20, 2019 at 11:41 AM
    Trooper2
    JR
    :itllbuffout: until you move LOL :rofl:
    Tierhog[QUOTED][OP] likes this.
  27. Feb 20, 2019 at 12:14 PM
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    I am a commercial and residential building inspector. Correct on the comment about the gutters! Need them to channel water away from the house. I would replace the rafter fascia boards with a 2x or 1x composite board. Add new Vinyl gutters wrap the exposed rafter tails with coil stock and sell in 5 years.
    equin, Twinky and Pudge like this.
  28. Feb 20, 2019 at 12:37 PM
    Tierhog
    Good advice Scott.. We are doing exactly that.
    poheller likes this.
  29. Feb 26, 2019 at 8:32 AM
    Tierhog
    Repaired. Apparently it wasn't DF.. And it was some kind of "rough cut" Anyway, he appeared to do a good job and caulked the tail ends bottoms etc.
    Now the rain gutter guy wants 250$ to rehang.. Thought that was steep but neighbors say that's normal to slightly high.
    Thoughts?
  30. Feb 26, 2019 at 9:21 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Gutter installation requires a galvanized drip edge flashing that prevents water from running back under the roofing edge, onto the fascia, and under the roofing. Some builders believe that sufficient overhang of roofing material will eliminate the need for a drip edge when installing gutters. Typically, this turns out to be false. If your roof does not have a drip edge at the edge of the roofing, you'll continue to have this problem, and probably not just in this location.
    Edit: This is true for shingle roofs...not sure what you do with the tile profile. Maybe roll flashing under the profile lower edge.
    @poheller is correct. Keep the gutters. Depending on the type of soil you have, you may begin to see foundation cracks if you don't keep water drained away from your foundation.
