A/C Clutch & Compressor Failure
Discussion in '2nd Gen Tundras (2007-2013)' started by Bluutundra, Mar 18, 2024.
  1. Mar 18, 2024 at 2:19 AM
    Bluutundra
    Bluutundra [OP] New Member
    Oregon
    2008 Naut. Bl Tundra Limited
    -295/70r18 on KMC’s -Ironman Foam Cell Pro Struts & Rear Shocks 3.5inch lift -Rear air bags
    Hello all,
    Sparks are flying off the compressor on startup with A/C engaged. The clutch is locking up and abrading with the serpentine belt. I am hearing and reading on this subject and getting mixed responses from local shops, tundratalk.com, etc.
    My question is: Should I replace the Evaporator Core, Expansion Valve, and Condenser? Or am I okay getting away with evac/recharge the system and replace the Compressor and Serpentine Belt?
    Insightful suggestions and input would be appreciated fellas -
    :help:
  2. Mar 18, 2024 at 2:39 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    These parts are minimal in comparison and should be done w/the compressor; evacuate the system, replace the compressor, core, expansion valve and condenser at the same time and charge w/new freon.. It's the correct way to do the job and the reason why most shops won't provide warranty unless those other parts are done w/the compressor.
  3. Mar 18, 2024 at 2:56 AM
    Bluutundra
    Oregon
    Thank you sir,
    I appreciate your help and will proceed with the job as you state it to be done. Wish this job wasn’t so cumbersome… Bank might call me up after I pay the shop bill
    Tripleconpanna likes this.
  4. Mar 18, 2024 at 3:30 AM
    Tripleconpanna
    Yeah the starter, A/C compressor and alternator on these rigs are a bit more than a 'standard' job and get a little pricey if you're paying someone else labor or at least spending a full day of your own time to do it yourself; at least they don't come due for quite some time on our trucks.
    I did the compressor job on my '08 about 2 years ago and well over 200k miles on the clock; starter was the year before that, and the alternator finally went last year... those parts don't last forever, but much longer than most other brands. I just wish they were easier to get to and swap out, but all the more reason to not cut a corner or two and then have to go back into it a few months later.
    PS>>> the bank might come callin'; but at least you'll be answering the call w/cold AC blowing in your face :cool:
  5. Mar 18, 2024 at 6:55 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    May be able to get away with just the clutch system, but you're pulling the whole unit out. I would second what @Tripleconpanna stated. Best advise I ever got, probably on here was swipe once, cry once.
  6. Mar 18, 2024 at 8:46 AM
    MartinBlank
    MartinBlank New Member
    Bruce
    Loveland CO
    2008 Crew Cab Limited
    TRD Sway Bars, TRD CAI, Bilstein 5100's, LED's, plus LED rear Plate backup light, Aluminum oil filter housing, ECGS Needle Bearing upgrade.
    I had to do this a year ago. It isn't as bad job to DIY. You have to replace everything though, as little bits of metal go everywhere when the A/C compressor grenades. I bought Denso from Rock Auto and even replaced my radiator while I was in there. Parts were about $800 and then an evac and flush of the cooling system along with recharge was another $150 If I remember right.
  7. Mar 18, 2024 at 1:57 PM
    Bluutundra
    Oregon
    “Swipe Once, Cry Once” I love it! I’m going to take @Tripleconpanna advice and just replace the whole thing and pray it doesn’t happen again!
