A/C button on with heat?
Discussion in 'General Tundra Discussion' started by Medic343, Dec 20, 2018.
  1. Dec 20, 2018 at 5:01 PM
    Medic343
    Medic343 [OP] 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    Just wondering if there is any benefit to having either the a/c button or the recirc button on while using the heater?
  2. Dec 20, 2018 at 5:03 PM
    ninjajay
    H-tine TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Volk TE37XT 18x9.5 +0, Nitto Terra Grappler G3
    I think the ac will help dry out the air if you're not defrosting, so less fogging
  3. Dec 20, 2018 at 5:37 PM
    D1227
    D1227 New Member
    Dustin
    Western Washington
    16crewmax
    I use the a/c plus heat alot when I'm fishing I do a lot of hiking in an its usually raining pretty good also usually got a buddy with me and its always raining pretty good so between getting our gear out and putting the gear back plus us just being soaked the truck fogs up pretty good but a/c plus heat clears that up real quick alot faster than just defrost no a/c.
    Medic343[OP] likes this.
  4. Dec 20, 2018 at 5:43 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    Windows fogging up? AC on and it goes away.
  5. Dec 20, 2018 at 6:10 PM
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    Keeps the air dry
    Medic343[OP] and TokerJoker like this.
  6. Dec 20, 2018 at 6:16 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Good to know! Maybe wouldn't have cracked the windshield:(
  7. Dec 20, 2018 at 7:46 PM
    Medic343
    Kenny
    New Mexico
    So looks like a/c and heat with no recirc button is the trick. Thanks for the help!
  8. Dec 21, 2018 at 7:11 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Which would heat the truck faster, having the re-circulation on or off?
  9. Dec 21, 2018 at 9:12 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    In the cab? Then recirc. Because it just recycles the inside cab air and runs it through the heater core. With each pass, it gets warmer. With it off, it pulls outside air in and pushes through the heater core and into the cab. Only problem is that it creates moisture and doesn’t help defrost/defog windows.
    Yzed608[QUOTED] likes this.
  10. Dec 21, 2018 at 9:15 PM
    Jengel451
    The Bitterroot, MT
    AC with recirc helps with the humidity
    dorkinatundra likes this.
  11. Dec 21, 2018 at 10:46 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    That makes sense, thanks!
