6112's and 5160's installed
Discussion in 'Suspension' started by Dejohnson8034, Feb 26, 2018.
  1. Feb 26, 2018 at 6:56 AM
    Dejohnson8034
    Dejohnson8034 [OP] New Member
    Prosper, Texas
    2017 Tundra Limited
    20180225_161231_resized.jpg Installed Bilstein 6112's on the front (top setting) and 5160's on the back, NFab bars, BF Goodrich AT2's w/ Warlord Rims, R/C light bar on the front, driver side Holy ^%$ handle, work in progress
    ARES, zcarpenter92, soarvet and 9 others like this.
  2. Feb 26, 2018 at 9:25 AM
    [DELETED]
    [DELETED] New Member
    Jeff
  3. Feb 26, 2018 at 9:25 AM
    [DELETED]
    Jeff
    Blows my mind there's no handle on the drivers side...:mad:
  4. Feb 26, 2018 at 12:07 PM
    BayRunner
    2017 Tundra Platinum
    Mine has a dual purpose handle. I can also use it to steer the truck :D
  5. Feb 26, 2018 at 12:16 PM
    [DELETED]
    Jeff
    Yeah... copy that.
  6. Feb 26, 2018 at 12:19 PM
    BayRunner
    Thought it was a little funny for I have this running contest with my daughter as to see how close I can park the truck to the garage wall and still get in and out. That steering wheel comes in real handy some days.
  7. Feb 26, 2018 at 12:31 PM
    [DELETED]
    Jeff
    Hahaha... I hate that game. Makes me feel so fat and old.
  8. Feb 26, 2018 at 12:46 PM
    TheBeast The Beach
    what size tires ? :spy:
  9. Feb 27, 2018 at 5:57 AM
    Dejohnson8034
    Prosper, Texas
    2017 Tundra Limited
    275/65/20, wanted a little bigger however; every day commute is 90 miles.
    zcarpenter92 likes this.
  10. Feb 27, 2018 at 6:06 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Nice looking ride. I’ve got the same suspension set up. It rides great. Get rid of that sway bar next. You won’t miss it.
  11. Feb 27, 2018 at 6:20 AM
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    Did you do UCA's as well?
  12. Feb 27, 2018 at 7:08 AM
    BayRunner
    With a 90 mile daily commute, I'd say the benefits of the sway bar would be immense. For highway driving, IMO, the sway bar is one of the best mods one can do. Only reason to ditch it is if there is a lot of off roading where the flex is needed.
    boostedtrdpro likes this.
  13. Feb 27, 2018 at 7:29 AM
    dj13
    dj13 New Member
    2014 Tundra Silver Sky 1794
    TRD Exhaust, Sway Bar, Pace Edwards
    Looks great! I am considering the same suspension setup. Sounds like everyone likes the ride. Can you describe how the handling is in corners compared to stock?
  14. Feb 27, 2018 at 8:44 AM
    Dejohnson8034
    Prosper, Texas
    2017 Tundra Limited
    Rides a little more stiff, seems more responsive as compared to stock. Did not replace the UCAs as I was told they were not needed, lift was kept under 3 inches. New alignment from off road store and rides awesome.
  15. Feb 27, 2018 at 10:22 AM
    Kwikfish
    Tri cities,WA
    16 CM SSM
    Any rubbing with that setup?
  16. Feb 27, 2018 at 10:49 AM
    Dejohnson8034
    Prosper, Texas
    2017 Tundra Limited
    yes, had to trim some of the plastic in the front wheel wells
  17. Mar 2, 2018 at 11:50 AM
    judge
    judge New Member
    2017 Black Limited 4x4
    Line-x bed liner, bilstein 6112 front/ 5160 rear, Century Royal Cap, 3m crystalline tint, Weathertech rear mat (large), Yokohoma G015 AT 275/60R20
    I think there is a lot of difference in the stock ride year to year and model to model. My 2017, crew, platinum, 4x4 had the hardest ride of any vehicle I have ever driven, x4. It was nuts, but one I had just tested was a good bit gentler. My kidneys hurt driving it home... and I never ever had felt them before! And I was only 45, not 145! I called Bilstein and asked for help making the ride on road better (not offroad) but they said 6112 position #2 (about 1.5 of lift) and 5160's. I found the set of 4 online for just under a grand, got some 2" blocks to keep the truck level, and presto (that would be $500 to my mechanic). My ride is now 10x better than stock. If we use a 10 point scale from comfort to stiff my truck is a 5 now, and it was a 10 (my 05 and 06 Tundras were a 3 on that scale). I read about the guys that max out the 6112's saying they are stiff, which seems odd, you would think there would more travel to absorb bumps. But apparently Bilstein knows of what they speak. And my truck also does 10x better offroad or on washboard (than stock), so for me it's win, win. In corners it is better too, especially if there are bumps or corrections needed. With the suspension soaking up more, minor corrections are more accurate. And it more than makes up for the higher center of gravity, which I never notice.
    dj13 likes this.
  18. Mar 2, 2018 at 11:57 AM
    Kwikfish
    Tri cities,WA
    16 CM SSM
    Ive read that they are a great improvement over stock,but i want a full 3 inchs in the front
  19. Mar 2, 2018 at 12:02 PM
    judge
    judge New Member
    I hear you, but there is more than one way to skin a cat. I picked up 1.75" from the shocks and block (average) and then I put on some Yohohoma G015's in 275/60R20 and it gave me another inch. So I got 2.75-2.875 with no muss, no fuss, and it rides sooooo much better on everything. But hey, do what works for you.
