6112 Front and 5100 Back lift question
Discussion in 'Suspension' started by zlaneb, Apr 13, 2017.
  1. Apr 13, 2017 at 11:36 AM
    zlaneb
    zlaneb [OP] New Member
    Austin, TX
    All-
    Last week I had my 17 CM leveled with 6112 Fronts(second from highest section) and 5100 for the back.
    I love the ride and the look.
    My question: I noticed after the lift my gearshift seems 'stiffer' and not as fluid. Could a lift put pressure on the tranny linkage and cause this 'tightness or stiffness"?
    Thanks
    Zlaneb
  2. Apr 13, 2017 at 11:52 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    It shouldn't.
    zlaneb[OP] likes this.
  3. Aug 11, 2017 at 7:16 AM
    scornwel
    scornwel New Member
    2017 Limited 4x4 CM
    6112/5100 Go Rhino RB20s
    I'm getting the exact lift today. I haven't driven it yet, but did you ever figure out why your truck shifted differently?
  4. Aug 11, 2017 at 11:29 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    think it's in your head. I have 5160's and did 5112's on top setting and just 5160's in the rear.
  5. Aug 11, 2017 at 4:27 PM
    scornwel
    scornwel New Member
    2017 Limited 4x4 CM
    Shifting is the same after my lift as well.
  6. Aug 11, 2017 at 4:58 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Mine as well. Same as day 1
  7. Aug 13, 2017 at 11:12 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    I agree mine's a bit different in shifting. Im thinking I might need a zero point calibration.
  8. Aug 14, 2017 at 7:13 PM
    Abrams65
    Abrams65 New Member
    Cliff
    WV
    16 Tundra MGM SR5 CM OR/15 Corolla S
    ICI Magnum RT Steps, 18' LED Foglights
    Looking at getting the same set up. Question though what kind of lift did you all get with the 6112's in the highest setting. Does it level the truck or there a need for a 1" block in the rear.
  9. Aug 14, 2017 at 7:31 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    6112's in front on top setting, 5160's in rear, no blocks. Top pic is rear IMG_0844.jpg IMG_0845.jpg
  10. Aug 14, 2017 at 7:53 PM
    Abrams65
    Abrams65 New Member
    Cliff
    WV
    What was the total lift front and rear?
  11. Aug 15, 2017 at 3:59 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Rear stayed same. Front about 2.5". I didn't measure beforehand. Those are the stock rims and tires.
    Abrams65 likes this.
  12. Aug 15, 2017 at 11:16 AM
    scornwel
    scornwel New Member
    2017 Limited 4x4 CM
    I used the 3rd clip setting on the 6112s to achieve a 1.9" lift in the front. I put 5100s in the rear, that's all - no rear lift.
    Mine is level relative to measuring from the center of the wheel to the fender. Some folks measure from the ground to the fender. You'll get different results depending on how you measure.
    I'm very happy with my results.
  13. Aug 15, 2017 at 11:29 AM
    scornwel
    scornwel New Member
    2017 Limited 4x4 CM
    Yep, slight rake as measured from the ground, the gap between the tire and fender is pretty even at all four corners, if I recall.
    I'll measure and post later.
    SouthBoundSteve likes this.
  14. Aug 15, 2017 at 4:58 PM
    scornwel
    scornwel New Member
    2017 Limited 4x4 CM
    Ok....no pics but I did measure.
    From the center of the wheel to the fender
    All were 24".
    From the ground to the fender
    LF and RF = 38.5"
    LR and RR = 38.75"
    So, wheel travel is roughly the same all around, but the truck has a 1/4" rake. But I can't really see the rake.
  15. Aug 15, 2017 at 5:32 PM
    BOBONTUESDAY
    2016 Limited Trd
    I don't have measurements but my front is an inch higher than my rear on 3rd setting. I forgot to factor in all of my static weight and my already flat springs.
  16. Aug 15, 2017 at 5:34 PM
    scornwel
    scornwel New Member
    2017 Limited 4x4 CM
    Wow mine is actually level. What else are you packing! Did you get 700lb springs?
  17. Aug 15, 2017 at 5:37 PM
    BOBONTUESDAY
    2016 Limited Trd
    I was going for the less than level look just a bit of lift up front. They're the regular springs well atleast I think so. I've got a crossover toolbox packed, plus all of the crap in my bed. Then most of my power tools and daily grab tools are on my back seat.
    I've had people ask me if my truck was leveled before I even messed with the suspension. I'm also assuming my leaf springs are bit worn from 96k of towing. I order some shackles. But currently I'm running extra air in my airbags to make up for it. I added the airbags after my leveling screw up.
  18. Aug 15, 2017 at 5:40 PM
    scornwel
    scornwel New Member
    2017 Limited 4x4 CM
    That must be it. I got nothing in the back. Well maybe 100lbs total.
    Your truck looks great man!
  19. Aug 15, 2017 at 5:43 PM
    BOBONTUESDAY
    2016 Limited Trd
    Yeah I've emptied my bed before and I usually gain an inch or two. I'm probably pushing 600lbs if not more.
    Thanks I like your flares.
  20. Aug 15, 2017 at 5:48 PM
    BOBONTUESDAY
    2016 Limited Trd
    Here's mine at 1.9 with an empty trailer hooked up lol.
    scornwel and SouthBoundSteve like this.
  21. Aug 15, 2017 at 6:16 PM
    scornwel
    scornwel New Member
    2017 Limited 4x4 CM
    Looking good man. I'm getting some RB20s tomorrow so I'll see how that looks.
    I came from a Tacoma and I'm super happy with the tundra. It's a beast.
    Abrams65 and SouthBoundSteve like this.
  22. Aug 15, 2017 at 6:19 PM
    scornwel
    scornwel New Member
    2017 Limited 4x4 CM
    Hilarious...autoanything bumped my ship date out, but I noticed today that they shipped from Laredo this morning. Must be hencho in Mexico.
  23. Aug 15, 2017 at 6:20 PM
    scornwel
    scornwel New Member
    2017 Limited 4x4 CM
    And we're both named Steve. Not sure I want to know more:D
  24. Aug 15, 2017 at 6:22 PM
    scornwel
    scornwel New Member
    2017 Limited 4x4 CM
    Quick question...Did your tundra come with chrome steps? Mine did and I quickly removed them.
  25. Aug 15, 2017 at 6:23 PM
    scornwel
    scornwel New Member
    2017 Limited 4x4 CM
    Brother from another Mother!
  26. Aug 15, 2017 at 6:27 PM
    scornwel
    scornwel New Member
    2017 Limited 4x4 CM
    You did well then. I have a factory chrome step sides in my garage.
    There's another guy here in DFW trying to sell an identical set so I'll have to wait.
    I'll post up my rb20s tomorrow night. How funny. The World is a small but wonderful place.
