6” lift but with the tires and rims fit?!?
Discussion in 'Wheels & Tires' started by WillTaThrill, Oct 9, 2018.
  1. Oct 9, 2018 at 12:34 AM
    WillTaThrill
    WillTaThrill [OP] New Member
    2018 Black Tundra SR5 Crewmax
    I am getting a 6” suspension lift on my 18 tundra. I wanna do 20 or 22’s with a 12 to 14 width? Will I just have to cut more or is it possible? Please help me out.
  2. Oct 9, 2018 at 12:47 AM
    tmart
    tmart New Member
    Travis
    With that wide of a wheel your offset is going to be super negative so it’ll push them out enough to miss the coil overs and everything towards the inside of the truck. But it matters what tire size you’re going to run, assuming 35s you might have some rubbing on the corners of the bumper in front of the tires and will probably have to do the bmc
  3. Oct 9, 2018 at 12:50 AM
    WillTaThrill
    325 amps... bmc? This is all new to me
  4. Oct 9, 2018 at 2:04 PM
    tmart
    tmart New Member
    Travis
    Bmc is body mount chop. You can YouTube it, it’s just trimming a little piece towards the rear of the wheel well
