5MM-10MM Wheel Shim
Discussion in 'Wheels & Tires' started by Supdizzle, Nov 23, 2019.
  1. Nov 23, 2019 at 9:11 AM
    Supdizzle
    Supdizzle [OP] New Member
    Scott
    2008 Land Cruiser
    Tough Dog Lift, Rhino Rack Platform, 275/70/18 General Grabber ATX
    I have not been able to get a very good answer on this, but I was wondering if anyone has used a thin wheel shim instead of a full blown spacer. I ask this because I have a Land Cruiser and my passenger wheel is barely rubbing on a Suspension part at full lock and pushing the wheel out 5MM would solve the issue.
    Any thoughts on placing that size of a shim between the wheel and the wheel hub?
    P.S I posted to Mud and know one commented... hopefully someone here has some experience with this.
    Thanks
  2. Nov 23, 2019 at 9:17 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    The studs on tundras are just long enough for enough thread engagement. A 5mm spacer will present two problems:
    -you will no longer be hubcentric and thus putting the load bearing weight on the studs and not the hub
    - second, you won’t have enough thread engagement using stock length studs.
    Supdizzle[OP] likes this.
  3. Nov 23, 2019 at 9:29 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Terrible idea
  4. Nov 23, 2019 at 9:34 AM
    Supdizzle
    Scott
    2008 Land Cruiser
    Look at that an answer in less than 15 minutes. You folks are great! I assumed that would be a problem, but wanted to confirm. Thanks!
    Black Wolf likes this.
