5k service interval due, questions
Discussion in '2.5 Gen Tundras (2014-2021)' started by eagleguy, Nov 17, 2021.
  1. Nov 17, 2021 at 12:19 PM
    eagleguy
    eagleguy [OP] New Member
    Hey guys,
    Getting ready to bring my Tundra in for its first service and checkup since purchased new in March 2021 as she has just hit 5K. Below is my list to cover everything I have found and wonder if I am missing something to be checked. Obviously the list may be overkill but I only get one shot at the 12 month fix everything warranty part for little things.
    1. DRIVERS SIDE SEAT BACK IS LOOSE. SHIFTS AND MAKES POPPING NOISE WHEN LEANING BACK, ACCELARATING.
    2. A/C MAKES HARSH BANGING NOISE WHEN ENGAGED AT IDLE.
    3. REAR BRAKES SQUEAL WHEN BACKING UP SLOWLY SOMETIMES.
    4. GAS FILLER DOOR DOES NOT STAY CLOSED PROPERLY. I MOVED PALSTIC RETAINER INTO DIFFERENT POSITIONS BUT ITS STILL OPENS BY ITSELF WHEN DRIVING.
    5. POPPING NOISE FROM REAR END WHEN PUTIING INTO REVERSE AND BACKING ON OCCASIONS.
    6. BLUTOOTH NOT ALWAYS WORKING TO RECEIVE PHONE CALLS EVEN WHEN PAIRED.
    7. TRANSMISSION AT TIMES SEARCHES FOR PROPER GEAR AND BANGS FROM SLACK ESPECIALLY GOING DOWN A GRADE.
  2. Nov 17, 2021 at 12:22 PM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    Don’t you get a 3 year 36k bumper to bumper from Toyota on new vehicles?
  3. Nov 17, 2021 at 4:30 PM
    eagleguy
    Petty stuff only covered for first year as far as I understand.
    Black@Blue19 likes this.
  4. Nov 17, 2021 at 5:53 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    "...I only get one shot at the 12 month fix everything warranty part for little things..."
    What kind of warranty is That? That's what I see used cars have...
    Metro14536 likes this.
  5. Nov 18, 2021 at 5:05 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Did they give you documentation on this one year warranty that explains what it covers? Never heard of this.
    Either way, if you have concerns, you don't have to necessarily wait until your 5k service, you could take it in anytime.
  6. Nov 18, 2021 at 5:57 AM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    If my rear diff was popping and my transmission was banging I wouldn’t be waiting to roll over 5k to coordinate it with my first tire rotation.
    Metro14536, JLS in WA and Canebrake like this.
  7. Nov 18, 2021 at 5:59 AM
    Canebrake
    Canebrake New Member
    JP
    West Alabama
    ‘17 SR5 4x4
    Try to film the guys’s face as you read off this list. He’s thinking this is just a tire rotation and he’s done. Then you break out the list…
  8. Nov 18, 2021 at 7:36 AM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    My responses are in the quote block, in italics.
    Jaypown likes this.
  9. Nov 19, 2021 at 5:56 AM
    eagleguy
    Naturally they stated they could not duplicate my concerns but they are getting me a new gas cover! LOL
  10. Nov 19, 2021 at 6:42 AM
    Clemsonman14
    Pretty normal for any dealership. Usually you need to request that a service advisor take a ride with you so you can point out the concerns. Especially if you can produce the issue on command
  11. Nov 19, 2021 at 6:50 AM
    Kung
    KG, VA
    This. I had some issues with my truck (very very minor) and the service tech 'didn't see them.'
    Asked to take a ride with the service manager; he found them right away, got the issues taken care of. :)
  12. Nov 19, 2021 at 6:57 AM
    The Towse Tundra 2.0
    The Towse Tundra 2.0 New Member
    Loy
    2021 Lunar Rock Tundra TRD Pro Crewmax
    TRD Inlay Package, Spray-in Bedliner, Cargo LED Light, Power Tailgate Lock, Center Console Safe, MX4 Bakflip Tonneau Cover, CaliRaised LED Rock Sliders, Nitto Ridge Grapplers 275/70/18, Rigid Industries Amber Fog Light Covers, Coachbuilder TRD Pro lift kit
    This is the best response so far. The AC issue is intermittent between trucks. Sometimes mine does it and sometimes it doesn’t. What I started doing was leaving the auto AC on all the time that way when I start my truck after it sits for a few days it doesn’t make that clunking noise. I haven’t heard it do that in months using this method. I bought my 2021 back in March as well. I only have about 7K miles on it.
  13. Nov 19, 2021 at 10:30 AM
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    2019 Toyota Tundra TRD Pro (Midnight Black)
    leather wrap steering wheel, front window tint, ceramic coating, AMP research power steps, Toyo open country at3 35”x11.5x18, Volk Racing te37xt 18 9.5 0 offset, Rays formula II lug nuts Warn fender flares, Coachbuilder +3, bilstein 8112 front and 8100 double bypass rear, Kenwood excelon 996xr stereo +7” speakers Westcott designs front lift, RAS rear leafs, yota leds, NSV Lightbar
    you should also get them to check bumper gap most likely each side is different, mine still has a bigger gap on the passenger side that I still haven’t fixed since i bought mine 2019 which is a little annoying and still haven’t made an appointment because I refuse and scared to bring it to a dealer :cool: I also do all my own servicing because of that:rofl:but all i can say is that I don’t have any problems i can’t deal with;)
  14. Nov 19, 2021 at 10:42 AM
    GT87
    GT87 New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    My 2021 does this and it absolutely drives me crazy. I'm definitely addressing it next time I take my truck in.
  15. Nov 19, 2021 at 10:47 AM
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    My dealer has a) cut my windshield washer fluid line next the the hood hinge, b) left a flathead screwdriver under the hood over the radiator plastic cover piece, c) broke an $80 ham antenna on my tailgate mount in their car wash (I’ll take half the blame here I should have taken it off before I went there but lots of Toyotas have antennas they take off before they wash them), d) quoted me diagnostic charges to find out why my truck was making noises even though it’s under warranty
    I do all my own maintenance now
